Question about Sharp LC-M3700P 37 in. HDTV-Ready LCD Television
Monitor comes on for a few seconds then goes blank.
I have a Sharp LC-M3700 Monitor/TV When you turn on the set, in this case its attached to the computer, the screen comes on but only lasts for a couple of seconds then goes blank. The power light in the lower right corner that was green turns to a flashing red light. If you shut it down and start again I get the same results. I appreciate any help you can offer. Tony
  • 405 Answers
Your looking at profesional repair. It could be DC/DC convertor, Monitor unit or PC/IF unit. (last two are expensive)
Posted on Oct 25, 2009
Tv keeps turning off
Go into setting and see if you have the timer set
Feb 26, 2016 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
When i push volume
Without more information, it sounds like someone might have set the parent protection code. Was your TV a demo unit maybe? You should be able to reset to factory default settings, but you'll need the manual for the TV for this. If you have more details on when and where you see this message, please elaborate.
May 07, 2014 | Sharp Aquos LC-M3700 37 in. HDTV-Ready LCD...
I recently fixed the blinking green light problem following advice here. Now, about a week later, when I turn on the tv, I get image for a few seconds and then the screen goes blank/dark. Green light...
i have the same problem. i just replace the power board because of the "green blinking" light. now, light stays green, picture comes on for a few seconds, then blank....
did you fix your problem.
Aug 31, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
I have a sharp LC-M3700 monitor I purchased used. It has a Pc code on it and will not let me open the monitor without the code. A yellow icon comes up that looks like a remote control with numbers and...
Page 61 of the manual shows how to bypass the pin if the pin number is forgotten with the remote, however you need the factory remote as a universal won't work. If you knew the pin number a universal remote would work to enter the numbers, but i'm guessing that you don't know the pin number in this case and there is no other way to reset it without having the original remote. These monitors were made for commercial use and have a pin lock to protect the settings in from being tampered with in a commercial installation.
https://www.manualslib.com/manual/151442/Sharp-Lc-M3700.html?page=61#manual
May 04, 2017 | Sharp Aquos LC-M3700 37 in. HDTV-Ready LCD...
Sharp aquos display comes on for a few seconds then blank screen
I have the same problem with my 37" HP which is the same as Sharp Aquos, it's bad backlight inverter boards, the screen comes on for a second then nothing, no menu, no channel change indicator then turn it off and you hear the clicking of the power supply about 10 seconds after.
Jan 01, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Show Microsoft Power point on Sharp Aquos hdtv
try to right click the desktop and choose graphics options, you will have to select the correct output for your setup. i.e. laptop to monitor, etc etc see if that works,...sounds like you have a connection, you will have to play with these settings until it pops up. worked with a similar scenario, sometimes you have to do stufff twice and it works on the second time not the first, electronics are weird.
keep changing the settings in the graphics options until it comes up the way you want it.
Nov 13, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-32D4OU
Comment by Guest, posted on Oct 25, 2008My Aquos has the same problem. I'm not sure how I discovered this, but when I lean the TV forward and hit the power button it will turn on every time. If the screen blacks out and I don't lean it forward when I hit the power button, the screen will just remain blank. It is very weird, but at least repeatable.
- Thank you, Guest. That did it. It definitely seems to be a problem with the TV. Tilting it and hitting the power button helped me get the video back.
Jun 05, 2008 | Sharp Aquos LC-32D40U Television
Sharp LC-M3700P 37 in. HDTV-Ready LCD Television Logo
286 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
