MY WATER PIPES BUSTED BECAUSE OF ICE
THE ICE BUSTED MY CYLENOID IN MY COLD WATER OUTLET ON THE BACK OF THE WASHING MACHINE. ITS AN ADMIRAL WASHING MACHINE. MODEL # AAV1000AWW
    Scholar:
  • 39 Answers
You should be able to replace the solenoid valve with an exact or equivalent replacement part.
Posted on Jan 22, 2009
Just purchased a new Admiral Clothes washer. When
Could you check and see if both the hot and cold hoses hooked to the back of the machine are actually putting out hot and cold water? If they are, it may be time to return the washer to where you bought it and get another. Be blessed.
Sep 25, 2013 | Admiral AW22 Top Load Washer
Washer will not fill with cold water only hot
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Apr 19, 2011 | Admiral Washing Machines
When washer machine is filing up with water is it normal for all hot then all cold water to come on instead of even mixing of the two? I have found that the constant back and forth with hot and cold...
Automatic temperature controls for different appliance manufacturers work in varying ways, but respond according to the control board response to the resistance of the thermistor. It is possible that your thermistor is bad; but what you describe is really a plumbing problem. The solution is to securely anchor your pipes; especially near the valves, so the abrupt change in pressure as the water is started and stopped will be dissipated into the structure of the walls, rather than allowing the pipes to vibrate against them.
Dec 23, 2010 | Admiral Washing Machines
Hi there,any advice please on frozen pipes..no water at all,no toilet,shower..can i use my central heating?...im forozen..
You will need to get to the pipes with a torch or heat gun and melt the ice out allot of times when the pipes thaw out you may have busted pipes with long cracks running down the pipe. The best way to handle this is to turn off the water to your house and inspect the pipes I would go and purchase some heat tape and cover all the pipes in exposed areas (crawl space, attic, and basement) and let the heat tape thaw out the pipes. after about an hour turn off all your inside valves ( tubes, shower, sinks and the cold water to the water heater) then turn your water back on and watch the meter at the street if it spins then you may have busted pipes.
1- Turn off water at the meter by the street.
2- Thaw out pipes with torch or use the heat tape.
3- Close all valves in house including cold water valve at the water heater.
4- Turn water back on at meter and mark on the meter where the hand is now then watch to see if the meter is turning.
The heat tape will keep you from freezing pipes in the future.
Hope this helps..............
Dec 07, 2010 | Heating & Cooling
Will not fill with hot or cold water and is connected
You need good water pressure on hot for these machines to work, gravity fed systems may not be enough. I had to attach a pump to mine to improve the hot water pressure (UK)
Switch over the inlet pipes ie hot to cold and cold to hot and try filling the machine when switched to fill with hot water, (machine will fill will cold). proving the valve is opening and it is a pressure issue on you hot water.
Nov 29, 2010 | Admiral AW22 Top Load Washer
Why is my warm water is cold? The hot is hot and cold is cold but warm is cold.
There is too much pressure on the cold feed, reduce the pressure on the cold by partly closing off the tap on the cold.
Or ensure the hot feed is fully open and not blocked, check if there are filters inline - remove the feed pipes at the washer end and look into the inlet valves - clear if blocked.
The inlet valve is common to hot and cold water with only a small pipe to fill the machine, the cold water is being forced back up the hot water pipe due to the pressure you can feel the pipe cool down after running hot then go to warm, if hot water is flowing the pipe will stay hot, if not then cold is going up the hot pipe.
Jun 28, 2009 | Admiral AW22 Top Load Washer
Admiral washing machine no cold water
HI, this is a faulty inlet valve assembly. you should replace this failing component asap if possible.This will fix the issue.
Jun 22, 2009 | Admiral Washing Machines
My Admiral Washing machine only runs the hot water (not cold)
the water temp switch is bad call aplience parts store in the area
Nov 25, 2008 | Admiral AW22 Top Load Washer
Admiral Washer smells like mildew
yes it could . If you are trying to pump the water 7 feet or more above the floor then it will at the end of the cycle get air into the drain hose causing cavatation, the result when the machines stops is the water running back down the drain hose back into the tub and that is what causes the musty smell.
Lower the drain if possible
Apr 10, 2008 | Admiral AW22 Top Load Washer
Admiral washer wont take in cold water
I to have the same problem except it is my hot water that dribbles
Dec 15, 2007 | Admiral AW22 Top Load Washer
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
