Question about Xerox WorkCentre M20i All-In-One Laser Printer
LIGHT COPIES HOW DO YOU DARKEN EXPOSURE SETTING ON A XEROX M20I
    President:
  • 2,072 Answers
You have to do what is called a "shading adjustment".
In order press "menu" #1934 on the machine, You will see a " T " displayed in the upper right side of your display. That means you are in the Tech mode. Some versions of software will also just say Tech.
Press the machine status button and then scroll to maintenance. Once there scroll to Adjust Shading, or Shading adjustment.
Place 5 pieces of clean white paper on the glass, 5 pages thick., not spread out, then close the cover and press start, it will ask you if you want to perform the adjustment , just press yes again. It will print out a page when done, that page displays across it, the pixils the the CCD in the scanner sees. If you notice it had some large deviations in it, the scanner will need cleaned. The numbers on that page will really mean nothing, Even if it says OK on the bottom does not mean the mirrors in the scanner are clean.
Posted on Jan 22, 2009
I have Xerox M 20i .When ever I feed papers from ADf. Print is not coming normal.Some time it shrink the text,I checked the roller are fine.
The Xerox is a business machine and has a setting to reduce the size of scans by percentage.
Read the instruction manual to turn it off or play with the buttons.
WorkCentre M20/M20i Documentation - Xerox Support and Drivers
www.support.xerox.com/support/workcentre-m20-m20i/documentation/enus.html
  1. Cached
  2. Similar
Product documentation for WorkCentre M20/M20i. ... WorkCentre M20/M20i Firmware Installation Instructions. Setup and Installation Guides. Description.
[PDF]WorkCentre M20i System Administration Guide - Xerox Support and ...
www.support.xerox.com/support/workcentre-m20i/file-redirect/enus.html?...en... Xerox WorkCentre M20i System Administration Guide. Page i. Table of Contents. 1 Welcome ................................................................................. 1-1. Introduction .
Xerox 20i Google Search
Nov 19, 2016 | Xerox Office Equipment & Supplies
Have a Xerox M20i Copier/Scanner/Fax. Display indicates "Scanner Locked" Cannot make copies nor fax out. Please help
If you look under the scan assembly you will see a yellow or green tab which locks the scan head. Try locking and unlocking it a few times then on the final unlock reboot your printer.
Jan 18, 2011 | Xerox WorkCentre M20i All-In-One Laser...
Scanner locked
Check your green scanner lock which is under the scanner area right in that area where your copies comes out of the machine. This is the most common cause of the "scanner locked" condition. The lock gets accidentally engaged as it is located right where you reach in to get your copies.
If the lock is not the problem then you may have a scanner drive issue.
Good Luck and Thank You for using Fixya.
May 13, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Xerox m20i scanning problems
its probably set to a low DPI.......change your dpi to like 600 when scanning
Nov 02, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Light bar does not move. copies come out blank
Have you verified that the scanner is not in the locked position? There is a unlock switch located underneath the paper exit. First power the printer down lock and then unlock this switch then repower the printer and try your scan again.
Mar 23, 2009 | Xerox WorkCentre M20i All-In-One Laser...
When trying to print from computers the message comes up paper size mismatch Xerox M20i
double check the paper setting and margins set up on your computer.
check the printer properties
Adjustment for light copies on a xerox m20i
You will need to do a couple of things, 1 remove, disassemble the scanner and thoroughly clean it, and while you have the scanner out, remove and clean the laser.
The toner cartridge may also be defective. that metering blade in that cartridge fails and causes light images also.
If you need instructions on how to remove and clean the scanner and laser let me know, I will type them out to you.
Not hard, just time consuming.
If you print out a report how does that look? If prints look fine and just the copies are light, then the mirrors in the scanner head a re probably fogged up. All the plastic in that scanner causes that same film on your scanner optics as you develop on your car windshield. Same process.
Jan 22, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Copy Problem
Since you cleand the scanner and scans are fine, the other item I seen cause that problem is the power supply.
Jan 07, 2009 | Xerox WorkCentre M20i All-In-One Laser...
XEROX workcenter M20i prints codes at bottom of page
someone has gone into diagnostics and enabled Status Print Engine
Fix
1. press menu/exit key
2. enter # 1931 in that order
3. engine test(diagnostic) should be displayed
4. use arrow keys to scroll to, then select engine test(status print)
5. press enter
6. press the "2" key on numeric keypad to disable (status print)
7. machine will revert to Ready to Copy
8. power off and then back on the M20
9. Your done.
May 02, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Light copies on canon imageRunner 3170i
No, but if you put a yellow plastic sheet under your document you will be surprised by the improved copy quality.
Sep 24, 2007 | Office Equipment & Supplies
Xerox WorkCentre M20i All-In-One Laser Printer Logo
140 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
