Question about Gaiam Exercise & Fitness
How can I reset my pedometers+ panic alarm - Gaiam Exercise & Fitness
2 Suggested Answers
SOURCE: How do you set the gaiam pedometer alarm?
yes - after setting time for alarm, press mode and set to get alarm icon on screen
Posted on Jun 05, 2009
I can't turn it on
Mine wouldn't turn on either....what they do not tell you is that inside, (take out for four screws and open the meter), is another battery under a silver round clip. Take that bettery out and replace it....works like a champ now!.
Sep 01, 2012 | Gaiam Walking Fit Kit Pedometer...
I have a maxi aid Talking pedometer and can't figure out how to turn the alarm off
You can cycle threw all the Alarm sounds buy pressing the "UP and DOWN" buttons simultaneously until you hear the "Alarm off" voice, also you will see the little "Bell display" above and between the hours and minutes go away.
Sep 14, 2011 | Maxi Aids Talking Pedometer
My Tanita 3 Axes Pedometer Pd724 got wet n the alarm started to go off . I had to take the battery out to stop and every time I put the battery In the alarm starts again and I cannot do anything else help...
Hi honeyrauniar
The alarm goes off when the pedometer is pulled away from the pin (at one end) to which the strap is attached. Just push the pin back in and it stops the alarm!
RM
Dec 08, 2010 | Tanita 3 AXES PEDOMETER (PD724)
Lost the directions need to know how to set all the buttons
Here see if this helps....
http://www.gaiam.com/product/pedometer+fitness+kit+-+intermediate+level.do
How to use the pedometer:
Take out battery insulator pull tab.
Set the metric / imperial system.
  • Press the S5 (Up/Mode) to enter step mode.
  • Press S3 (Set) and hold button for 3 seconds.
  • Press S5 (Up/Mode) to toggle between metric / imperial.
  • Press S3 (Set) to select.
  • Basic operation buttons:
    Time mode
  • The display shows the current time.
  • Press S6 (Down) to toggle 12/24 hour display format. If 12-hour display format is selected, PM times are indicated with a P.
  • To set time: press and hold S3 (Set) to adjust mode. Hour will flash and display.
  • Press S5 (Up/Mode) of S6 (Down) to adjust the flashing digits. Hold the button for fast scrolling. Press S3 (Set) to confirm and move to minute. Adjust the minute.
  • Press S3 (Set) to confirm, and return back to the time mode.
  • Step mode:
  • Press MODE key to enter step mode.
  • The display shows the steps you have dones.
  • Press and hold S2 (CLE) to reset the step count. All information regarding the step counter/distance/calorie will be erased.
  • Distance mode:
  • Press mode to key enter distance mode. It shows the distance traveled.
  • To set personal stride: press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and / or S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to distance mode. Set stride: 30-180CM (12-70 inch).
  • Calorie mode:
  • Press mode key to enter calorie mode.
  • It will show the calories burned.
  • To set personal weight: Press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to calorie mode. Set weight: 10-15kg (20-330 lbs.)
  • Measuring your own stride:
  • An individual's stride may vary in length. Input the appropriate length by measuring the distance of 10 steps and dividing by 10 to get your own stride length.
  • How to adjust:
    Motion sensitivity slide switch
  • Attach the unit correctly and walk 100 steps. If the reading is 105 steps or more, slide the Motion sensitivity switch to the left. If the reading is 95 steps or less, slide the motion sensitivity switch to the right.
  • How to wear your pedometer:
  • Your pedometer clips easily and snugly to either side of the hip portion of your pants or shorts. For best results, keep the unit in line with the crease line of your pants.
  • The pedometer must be directly perpendicular to the ground. The pedometer needs to be at a 60 degree angle to the ground. Dragging your feet, walking with sandals or uneven footsteps in a crowded area can affect the accuracy.
  • The pedometer only works when walking, jogging, or walking up/down stairs.
  • How to use the panic alarm:
  • Pull out the panic alarm pin S7 (Panic Alarm) from the unit to trigger the alarm.
  • Press and hold S1 (RES) to stop sound temporarily.
  • Insert the panic alarm pin back into the unit to stop the alarm instantly.
  • Battery replacement:
    Panic alarm and LED Torch battery:
  • Open the battery door by unscrewing the secure screw.
  • Flip out the exhausted battery and replace with two new *CR2016 (3V) batteries. Make sure the polarity is correct. Close battery door and fasten the screws.
  • heatman101
    Oct 02, 2010 | Gaiam Walking Fit Kit Pedometer...
    Hit panic alarm on fob accidentally and wont turn off unless key is in ignition and turned on. as soon as key is removed from ignition panic alarm starts again. fob seems to be not working. can i manually...
    reset the computer by disconecting the posative cable for 3min reconect it should cure the problem
    if not have a disnostic run most auto parts will do this for free
    hope this helps
    Please leave feedback
    Mar 21, 2010 | 2002 Saab 9-5
    How do i reset the panic system? the alarm has
    You should be able to unlock the door on either side twice in a row and it shold turn off but the door needs to be closed when you do it all the doors have to be closed. and unlock twice should reset it if it does'nr\t the other doors switch may work and sometimes even the trunk switch will too
    Dec 05, 2009 | 1996 Chrysler Cirrus
    I can't figure out how to turn it on.
    I checked this forum this morning because I was having the same trouble. I tried pushing buttons, pushing and holding buttons, pushing buttons together, shaking it, shaking it while holding buttons... nothing worked. Out of frustration more than anything I whacked it on the palm of my hand... and presto! It works. I guess you just need to use the Fonzie method.
    Jul 28, 2009 | VIA Pedometer - Via Panic
    Voicezone talking pedometer instructions, turn off alarm
    Push both the up and down buttons at the same time. You might have to repeat this two or three times. It will tell you when the alarm is off.
    Jun 22, 2009 | Exercise & Fitness
    Jun 04, 2009 | Gaiam Walking Fit Kit Pedometer...
    Exercise & Fitness Logo
    Top Gaiam Exercise & Fitness Experts
    Electro Med Services...
    Sportsmith LLC
    Sportsmith LLC
    Tom Chichester
    Are you a Gaiam Exercise and Fitnes Expert? Answer questions, earn points and help others
