Question about Health & Beauty
How do i get the red beeping sound off the oxygen concentrator
My oxygen concentrator has been beeping with a red light signal. I would try and make sure the oxygen was being afloat like make sure there are no kinks in the oxygen cord. Then I would trun it off then turn it back on....then it would go beeping again in like ten minutes. Please I NEED YOUR HELP. THANKS!!
leecom72
  • 4806 Answers
SOURCE: hp xw6200, 6 beeps, and red power button...failed start up.
6 long beeps indicates that there is a problem with the memory, take them out, clean the contacts and the DIMM slots and reseat them.
Hopefully this will resolve the problem, if not new memory may be required
kind regards
Posted on Dec 14, 2008
SOURCE: I need instructions for DeVilbiss 5 ltr. Oxy Concentrator
I believe I can, Please contact me at
hollyg916@yahoo.com In subject put oxygen. will be looking to hear from you.
Posted on Jun 04, 2009
  • 8457 Answers
SOURCE: TV just turned off while watching. standby light flickering red 7
Ur power board have dead capacitors.U Know how to solders?Take the tv aparts,check these capacitors in the power board for dead capcitors like puff up or burst open.Replaced these capacitors to get power back.Or buy and replaced the whole reburbish power board at Shopjimmy.com,Ebay.com.
Posted on Jan 21, 2010
SOURCE: Beeping Noise/Blinker Noise
I thought the same thing. In the past with this car that was the case, it needed a lightbulb replaced somewhere on the car. So after replacing 4 lightbulbs on the car, it still makes the noises...question for someone: I did notice that when i open the doors on the car, the dome light does come on but there are no lights down by the floor in the front of the car...if these bulbs are burnt out too then I will need to replace these and maybe the ticking noises will stop? Are there lights for the floor area on the 2003 Alero model?
Posted on Mar 24, 2010
  • 1139 Answers
SOURCE: My PlayStation 3 turned off
Unfortunately what you are describing is known as the Yellow Light of Death (YLOD). This indicates a general hardware failure normally due to overheating. When these PS3's were produced Sony decided to use lead free solder. The problem with lead free solder is that it is not as flexible as leaded solder but it is cheaper and more environmentally friendly. When the console gets hot and cools down hairline cracks appear within these solder joints and a good electrical contact cannot be made. This then causes the console to fail. It could be on a number of different components including the CPU, GPU or memory. There is a temporary cure that may or may not work but ultimately the console will need to be repaired professionally or replaced. If it is out of warranty Sony will not replace it but will offer a refurbished unit for around £130. If you look on Youtube for Yellow light of death fix there is a way that you can re-heat the solder joints using a heat gun but if you are not confident taking apart electrical items then this really may not be something you want to try.
I am sorry I cant give you any better news but unfortunately it is a very common problem with the PS3
Hope this helps and thank you for using FixYa
Posted on Oct 30, 2010
Testimonial: "Unfortunatley, that's not what I wanted to hear, but your advice seems to be very educated and helpful. So thanks a lot!"
RED LIGHT COMES ON AND ALARM SOUNDS
Check fluids and filters, make sure there is no restriction on tubing, air intake. some times take out the filters etc. then reinstalling them will help. Also unplug for a while then plug it back in and see where that takes you.
Apr 22, 2014 | AirSep FreeStyle Portable Oxygen...
Where is the ELD on honda crv 2008
P1289 - Cylinder Head Temp Sensor High Input
The A/F sensor is a planar dual-cell limit current sensor. The sensor element of the A/F sensor is the combination of a Nernst concentration cell (sensor cell) with an oxygen-pump cell, which transports ions. It has a heater in the element.
The sensor is capable of precise measurement a= 1, but also in the lean and rich range. Together with its control electronics, the sensor outputs a clear, continuous signal throughout a wide range (0.7 < a< air).
The exhaust gas components diffuse through the diffusion gap at the electrode of the oxygen pump and Nernst concentration cell, where they are brought to thermodynamic balance.
An electronic circuit controls the pump current through the oxygen-pump cell so that the composition of the exhaust gas in the diffusion gap remains constant at a = 1. Therefore, the A/F sensor is able to indicate air/fuel ratio by this pumping of current. In addition, a heater is integrated in the sensor to ensure the required operating temperature of 700 - 800?C (1,292 - 1,472?F).
The response (from LEAN to RICH) of the A/F (Bank 1) signal computed by ECM from A/F sensor 1 signal takes more than the specified time.
Symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
Possible causes
# Harness or connectors (The A/F sensor 1 circuit is open or shorted.)
# Air fuel ratio (A/F) sensor 1
# Air fuel ratio (A/F) sensor 1 heater
# Fuel pressure
# Fuel injector
# Intake air leaks
# Exhaust gas leaks
# PCV
# Mass air flow sensor
Thank you.
Jun 07, 2012 | 2002 Honda S2000
P-B Companion 590 Oxygen Concentrator is beeping. What should we check and fix to repair the unit? Can you provide a link to the manual or troubleshooting guide for this unit? Thank you for your...
When these units are beeping it indicates they are basically not running. So you first need to ensure who ever is using it has access to o2 if they require. There isn't much you can do to fix these at home. You can first try going over the following. Not really that helpful but might help you sort it out. If you can't spot anything obvious ie unplugged no power etc then first contact anyone local such as the medical supply place. That would get you the fastest repair or help. If you don't have one of those to call then don't be afraid to call the 1-800 number below and ask the company.
The local company or even your doctor might be able to help you get bottled O2 while your unit is getting fixed.
If there is an audible alarm -- concentrator is not running: • Is unit plugged into a working outlet? • Check circuit breaker -- Right side of unit, behind a small door on the Companion 590 and 429a -- Back of the unit on the Companion 492 -- Between the on/off switch and flow meter
If there is an audible alarm -- concentrator is running: • Concentrator cannot be fixed by consumer • Call 314.362.0720 or toll-free 800.456.9366
There is a visual alarm on the Companion 590 with oxygen concentration indicator: • Green Light -- Normal -- Oxygen concentrations are correct • Yellow Light -- Below Normal -- Oxygen concentrations have fallen below an acceptable level • Red Light -- Not Operating -- Oxygen is no longer being produced; audible alarm will sound and concentrator will shut down
Apr 04, 2011 | Health & Beauty
How to fix code p1289
The sensor is capable of precise measurement λ= 1, but also in the lean and rich range. Together with its control electronics, the sensor outputs a clear, continuous signal throughout a wide λ range (0.7 < λ < air).
An electronic circuit controls the pump current through the oxygen-pump cell so that the composition of the exhaust gas in the diffusion gap remains constant at λ = 1. Therefore, the A/F sensor is able to indicate air/fuel ratio by this pumping of current. In addition, a heater is integrated in the sensor to ensure the required operating temperature of 700 - 800?C (1,292 - 1,472?F).
Symptoms
Possible causes
# Fuel pressure
# Fuel injector
# Intake air leaks
# Exhaust gas leaks
# PCV
Hope helps.
Jan 28, 2011 | 2001 Honda Civic
Hi I'm using the devilbiss 5 lts Oxygen concentrator from past 4.5 years. Recently from past 2 months it is giving some problem, during night while using machine within 2 hrs it is showing low oxygen (with...
please check if the model of Concentrator is 515HKS or aks if u have any idea to open the screw it can be very easily opened ,check if the fan which will be under compressor is running ,or any leakage from the tube point which starts from the copressor or there will be muffler connection to the compressor which will be ball shaped,
if u have any doubt after checking with this please mail me to delltazameer@gmail.com
Jan 03, 2011 | DeVilbiss 5 Liter Oxygen Concentrator with...
Unable to power on computer
When you here this signal sound beeping this is an RAM memory error. Try to open your CPU casing and remove the RAM, clean the RAM with rubber eraser.
After that insert the RAM and try to turn on the unit. Once you can hear again the loud sound beeping the RAM are bad or faulty already. So you need to replace the RAM.
Jul 25, 2010 | HP Compaq d530 SFF PC Desktop
My PC gives no signal and a red light blinks
check first the Monitor if properly connected..check reset switch if in good not press...
check the beep soud of your PC while booting...if you heard 2 beeps sound try to remove the RAM the put it back but careful in handling it...and pls dont reverse the RAM pcb...
if continious beep ..try to remove the video card and put it back...
do this procedure your PC is off..
May 25, 2010 | Intel Motherboard
Unit has only 6000 hours, Works fine for about an 1/2 hour, then signals low oxygen. Turn off and back on, repeats.
Make sure flow rate is greater than 1LPM and no more than 5LPM. May need filters changed or possibly new sieve beds.
May 03, 2010 | DeVilbiss 5 Liter Oxygen Concentrator with...
Other than not passing or producing oxygen flow is it possible for a concentrator to produce carbon monoxides or other gasses? After looking at and reading the information provided on your site it seems...
You are correct. This concentrator is oxygen specific. Therefore it only concentrates the oxygen, not other gasses. Joe
ps please rate my answer as very helpful.. thanks
Mar 29, 2010 | DeVilbiss 5 Liter Oxygen Concentrator with...
Health & Beauty Logo
66 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
