Question about Gaggia Syncrony Compact Coffee Maker/Espresso Machine
The red water light on my gaggia syncrony won't go off despite the fact the water container is filled to the brim.
  • 368 Answers
Hi nmorrisroe
There are two possible conditions that result in the error code you describe (steady red light)
(1) the coffee bean bin being empty, (or that sensor thinks that it's empty) and
(2) the water level sensor thinking there's not enough water in the reservoir. Either sensor may be damaged or is registering a false return due to some condition in the machine.
If there's absolutely nothing blocking/affecting the sensors, then there are three logical possibilities that occur to me.
1) Damaged sensor - shouldn't be an issue if you used an accepted descaling chemical and otherwise followed the manual.
2) Faulty sensor - is it still under-warranty?
3) Control panel is bad (warranty?).
If I can be of further assistance, let me know, and include as much detail as possible (you should be able to load digital pictures onto this space using the toolbar above).
If this solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Posted on Jan 22, 2009
Gaggia syncrony compact digital expresso maker says fill water tank but water tank is full
Check the float in the tank that indicates the water level to the sensor. They often fail to float, solution is to either replace the tank or jam something plastic under the float to lift it to the top of its slot.
Jan 01, 2016 | Gaggia Syncrony Compact Digital Espresso...
Gaggia syncrony logic not dispensing water. Just drops pods and red light comes on. have cleaned brew unit shower screen and dispenser tube. still have the problem
Lubricate the brew unit with a food safe grease this should help.
The brew unit becomes stiff and fail to load up fully this stops the water being dispensed
Jan 18, 2010 | Gaggia Syncrony Logic 74884 Espresso...
Hi, Our Gaggia machine will not disburse water through coffee dispenser. Sounds like its operating normally till water flow should happen. Then the motor slows down to nothing. Have descaled to no effect....
Try this press the button for ground coffee then when it lights up press the coffee brew button, if water flows normally then the grind on the grinder needs to be adjusted coarser, if no water then the screen on the brew unit is blocked.
Sep 07, 2009 | Gaggia Syncrony Logic 74884 Espresso...
Brand new Gaggia Syncrony Compact will not pump water. Red light no. 27 flashes, and machine makes sounds as if trying to pump.
Open the hot water valve, if it flows for a second and stops, then pusi in on the knob if that works, call up support and ask for a new stainless steel valve for your machine.
Aug 01, 2009 | Gaggia Syncrony Compact Coffee...
Low water light stays on
If water light and heating lights go on and off, Try this: Fill water, turn water nozzle on, let water flow out. Water light should go off. Shut off water.
If coffee lights are solid, turn off the machine, let it cool off and try the above again.
Jul 07, 2009 | Gaggia Syncrony Compact Coffee...
GAGGIA syncrony compact coffee grinder motor is
Remove the brew unit and to the left of that is the the discharge area for the grinder, make sure that hole is clear, then adjust grind 1 number coarser, and check machine.
Jun 07, 2009 | Gaggia Syncrony Compact Coffee...
Try to make a cup of water, if you only can get a half cup then the flowmeter has to be replaced.
Jun 22, 2008 | Gaggia Syncrony Logic 74884 Espresso...
Gaggia Syncrony does not get past the grind cycle
Water has probably been spilt in the beans area. The grinder needs cleaning out along with the chute
Feb 24, 2008 | Gaggia Syncrony Compact Coffee...
Gaggia Syncrony Compact Coffee Maker/Espresso Machine Logo
436 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Michael Vincent Cruz
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
