Question about Roper Washing Machines
Will fill and drain, not agitate or spin though
The water in the wash and rinse will fill and drain but my agitator is not working and the barrel isn't spinning either. Any ideas? Motor does hum though.
I am having the exact same problem with the same brand machine.  I put in a load of clothes to soak till the morning, but in the morning, the washing machine would only fill, spin, and drain.  The agitator would not wash the clothes, so they came out with the soap of course still crusted in.
Posted on Jan 22, 2009
Why does not agitate on rinse cycle
It shouldn't agitate on rinse cycle. ''Quick wash'' is the last type of ''cycle'' you can select that the machine will ''agitate.'' On ''rinse'' cycle, it will fill with water and then simply drain & spin.
May 18, 2015 | Washing Machines
My 5 year old Roper washing machine fills up, washes/agitates the cloths, drains them when the washer get to the rinse line to start the rinse cycle it stops, and all I hear is a humming. The machine will...
I'm not familiar with roper washing machines so I'll ask the question does it have two fill hoses. Most European machines now only have one fill. If it has two then it sound like the machine takes the initial water from the one fill and the rinse cycle water from another. The humming sounds like the valve for the other fill needs replacing. These are quite inexpensive and easy to fit. Power off.. remove lid ....switch of water...take out valve when you establish which one is affected and replace
Oct 17, 2013 | Whirlpool WTW5700S
My Kenmore washer (series 90) stopped working in between the rinse and spin cycles. It will not drain (half full as we speak), agitate or spin. It will fill with water but once it reaches the proper water...
Something stuck in Pump. Pump on your model is driven by washer motor, so if Pump can't turn, motor can't work and will hum until it overheats and shuts down.
Sep 28, 2017 | Washing Machines
Frigidaire FWT647GHSO when it gets to rinse first rinse cycle, it doesn't stop filling with water. It won't agitate or spin. It works well in the wash cycle, agitates and spins and advances
probably you've got something blocking the water pump from doing its job properly so check that the water pump is free running emptying all the water if not then there is a blockage in the pump normally ist a button, paper clip or other debris out of a trouser pocket eric
Dec 25, 2017 | Frigidaire Washing Machines
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Whirlpool top load washer no low-speed agitation. The unit fills, starts the wash cycle with normal agitation, but after a few minutes it just sits there soaking until the it's time to drain/spin. Drains...
    Either the wire going to motor for non working speed is loose or damaged, or motor is bad. It could also possibly be timer not sending power to motor for that speed.
    Sep 27, 2017 | Whirlpool Ultimate Care II LSQ9549L Top...
    It wont complete cycle and empty the water just hums for a while and then turns its self off
    The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
    Jan 17, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
    Does washer drain before the spin cycle starts?
    Normally yes. There are around 12 to 20 gallons of water in the tub after the wash cycle, which will be anywhere from 63 to 110 pounds of weight in addition to the weight of the clothes. For the machine to start the spin cycle to remove this water would place a heavy load on the motor, gearcase, pullys, belts, gears, ect. With the water drained, the load is lighter, and much easier to start spinning the excess water out of the clothes. The normal cycles are: Fill, Agitate, Drain, Spin, Rinse Fill, Agitate for rinse, Drain, Spin Cycle and off. Imagine trying to spin a 5 gallon bucket of water over your head, full of water, and then empty. Which one do you think would be easier to do? And safer for you.
    Sep 26, 2009 | Admiral AW22 Top Load Washer
    Washing Machines Logo
    653 people viewed this question
    Top Roper Washing Machines Experts
    Dan Webster
    Dan Webster
    Mike
    Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
