Question about M-Audio Studiophile BX8 Main / Stereo Speaker
M-Audio BX8 blows a fuse
Hi I've had a pair of BX8s for three years. One of them now blows its internal fuse when it's powered up. For a week or two before that, it was crackling slightly as though the sound was clipping. The other one is still working perfectly.
  • Anonymous Nov 04, 2007
    Monitor crackles and finnaly fizzes from high to low pitch and then you hear nothing.
  • scottme May 13, 2008
    Same here.
Http://1200s.com/Store/PARTS-SPEAKER_PARTS-M-AUDIO/c271_572_573/p330000/M-Audio_BX8A_Replacement_Woofer/product_info.html
Posted on Jan 17, 2009
  • 515 Answers
If your monitor is crackling and fizzing, that is not a fuse issue, unless the fuse you have installed is underrated. It sounds like you have a bad driver/woofer, and need to get it replaced. CLICK HERE FOR THE REPLACEMENT DRIVER for this model.
- DJPA
Posted on Mar 01, 2008
SOURCE:
How to take the big speaker out of a studiophile BX8 speaker
As you can see, there are 8 screws holding the woofer in. Remove them, lift the speaker up, but before you disconnect it....Mark + and - onto the wires...red + and black -. .http://i46.tinypic.com/14l3j0z.jpg
Aug 18, 2014 | M-Audio Studiophile BX8 Main / Stereo...
Jvc Kds88bt Cd Receiver keeps blowing fuses
short circuit internally (maybe) or if old units ,u are using an undersize fuse. for old units 10 years above power consumption increases
Jun 04, 2013 | JVC Car Audio & Video
Cambridge sound works extreme 2.1
Fuses blow when there is an overload. This is most likely caused by the main power amp part of the sub. Or it's power supply. What's happening is that some part is acting like a piece of wire instead of doing it's job.
It's possible that the previous repair people fitted the wrong part and if you are using it at say high levels it goes again. It could also be caused by faulty speaker wiring. So check that after replacing the faulty part. It might be visibly burnt or broken if you look inside it.
Oct 04, 2017 | Audio Players & Recorders
Cracklin/popping with m audio bx8 d2's thru fast tack mk2
Check for flucuations in your power supply. If none then put a shield sleeve on your cord.
May 03, 2012 | Avid M-Audio BX8 D2
M audio bx8 blows a fuse
best solution wrap the blown fuse with a piece of tin foil and put it back into the fuse terminal and you shouldn't have a problem.
Mar 03, 2012 | M-Audio Studiophile BX8 Main / Stereo...
I've got a Adam A5X studio monitor. the problem is that fuse blows after about 15 sec. it works but you can hear background hum and the transformer gets very hot in 15 sec. then fuse blows. i wonder...
Transformers RARELY fail. It is likely that either one side of the amplifier has shorted or there is a failure in the rectifier/filter circuit of the power supply. Take it for repair unless you are adept at electronic repair. Do NOT continue to replace the fuse as you MAY cause futher damage. Use a 25 or 40 watt lamp in series with your power cord to limit current while troubleshooting.
Jul 05, 2011 | Adam Audio A5X Pair 2-way 5.5 inch...
I have a 20 year old GE JCM140H over the range microwave which has always worked just fine. Last week everything just "died" no lights, no fan, no display, no microwave. I thought that I had...
You'll have to remove the cabinet cover to access the fuse. It is in line with the power cord. 20 Amp, slow blow.
One of the screws on the back of the cover may be a security TORX (the kind with a pin in the center of the head). Usually, if you tap on it with a hammer, you can remove it with a pair ov Vise-Grip pliers.
Jan 05, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Sony DSC H5 runs down batteries very rapidly. Much faster than when the camera was originally purchased. A pair of new AA batteries only lasts for 12 - 24 photos. Brand new rechargeables fully charged are...
Hi there please reset the camera 1st . THen pair your battery with your camera. Go in menu then battery type option. Select the type of a battery. After that save the setting. Now try . If you face the same problem then the camera internal power transformer are damaged or week. So you need to replace that transformer after that it will start work properly. You use that camera so long, that's why there is a chance of that damaged. Thanks if its helpful then rating me.
Mar 15, 2010 | Sony Cyber-shot DSC-H5 Digital Camera
Clarification for jl amp problem
sounds very much like resistance was an issue and no they dont have an internal fuse sorry
Oct 12, 2008 | Jl Audio 500/1 Car Audio Amplifier
M-Audio Studiophile BX8 Main / Stereo Speaker Logo
1,055 people viewed this question
Top M-Audio Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Don Hart
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
