Question about Acer AL1916W 19" LCD Monitor
Acer Model AL1916W A reads no signal after being on for 1 hr
For example , when I run Windows Defender and return to my computer after an hour, the monitor reads no signal. I must restart the computer again, then everything works Ok. I put back my old monitor and everything is OK. Any suggestios?
    Genius:
  • 1,189 Answers
The problem seems to be that the computer, do not recognize “which monitor’s connected?” Follow these steps to correct the problem: Shutdown the monitor, next shutdown the computer. Unplug” the monitor, from the power outlet. Disconnect all cables on the Monitor from the computer. Next, reconnect all cables, and power, in the reverse order. Start computer first! Turn on the monitor, (right) click on an empty area of your Desktop Screen; next click Personalize, click Display Settings, click Identify Monitor. At this point, the monitor should be present, click on monitor. To finalize the application, click Apply! Next, click (OK). To “Fix” the (Resolution): Part: (1) Click Display Settings, adjust “resolution.” Click, Advanced Settings, “click” Properties, click on Drivers, “click” Update Drivers; click “OK!” Part: (2) Right click on “Desktop”, (in the upper area) check if the Graphic ™ Control Center is visibly presents, if so, click to open. You can adjust the Graphic Settings. Click “Apply” next, “OK” when finished! Restart the computer. I hope this Fix it.
Posted on Jan 19, 2010
When i'm playing games in my pc, they run fine.. but after a while like 5min the monitor goes black with that rectangular box saying "Input not supported" i have an acer AL1916W and an AMD...
Update your video car drivers and then look for the specific drivers of your monitor, it happened to me once using windows 7 i just installed the monitor's driver from the manufacturers website. go to acer website and support download page and search for your model, donwload and install and hope that solves your problem.
Sep 06, 2011 | Acer AL1916W 19" LCD Monitor
Microsoft Windows Security Essentials on my Emachine using Windows Vista Home on Start Up shows Windows Defender is turned OFF! I cannot get it to turn on manually or thru Control Panel
hi..you can only choose one antivirus program..usually when MSE is activated you cannot turn on windows defender..in any case that you had your system 2 activated antivirus it will affect the performance..
Jul 19, 2011 | Microsoft Computers & Internet
Anti-theft mode enabled. I just bought this brand new, it's been turned on for less than an hour. i have 5 buttons aside from my power button, they are marked only with small white dots. which one is the...
This is Acer AL1916W is 2008 model year, you just bought it brand new? it should come with the CD for edisplay management software that you need to install in your PC to enable/disable the anti-theft. I would take it back to where you bought it from and have them remove the anti-theft since the seller has activated it.
Please read the user manual that come with this monitor for details.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Aug 21, 2010 | Acer AL1916W 19" LCD Monitor
I was running the program "windon Defender" on it and walked away. When I returned the computer was off and wasn't turn back on.
The Windows Defender Application is the Antivirus Software which will be pre-installed with the Windows Operating System(Windows Vista, Windows 7).
The Computer will always Shut down after any Windows Updates or any Operating System Updates are downloaded and installed.
If you are connected to the Internet and running Windows Defender, the Computer will automatically download the Updates for the Windows Defender Application.
Once the Updates are downloaded and installed, the Computer will prompt for a shut down.
The count down will be for 10 seconds.
After 10 seconds, the Computer will install the downloaded Updates and shut down.
This might be the reason for the Computer to shut down while using the Windows Defender.
If the Computer still shuts down randomly, the issue might be due to overheating.
All the Processors in Notebooks are designed to shut down automatically, if there is any overheating issues.
The overheating issue mainly occurs due to the malfunction of the Cooling fan.
If the Computer shuts down frequently, the issue might be due to the above factors.
It would be better to get the Unit examined at the Service Center.
Jun 22, 2010 | Acer (56.04145.901) (5604145901) Power...
Monitor ACER Model AL1916W Problem
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
Jun 16, 2010 | Acer AL1916W 19" LCD Monitor
Acer AL1916W about 2 years old. Turned on this
Bad caps in the power supply, common problems with 2-year old monitors, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 25, 2010 | Acer AL1916W 19" LCD Monitor
Acer AL1916W pluged into lap top but can't get both to run.
Have you used the Fn button on your laptop and changed the video display Icon on the Blue Function keys. You need to change the display wait a few seconds for it to take affect. There are several modes try them all so you know how to use them.
Mar 20, 2009 | Acer AL1916W 19" LCD Monitor
After loading windows Vista screen says no signal
steve, i dont think there is any problem with monitor. restart ur pc in safe mode, change resolution to 1440X900.
Mar 02, 2009 | Acer AL1916W 19" LCD Monitor
Windows XP freezes when botting with the ACER as a second screen
check the hardware compatablity list for windows if the Acer AL1916W 19" LCD is included then get the appropriate driver and install it
May 07, 2008 | Acer AL1916W 19" LCD Monitor
No Signal
Probably the settings on the computer graphics card output.
You need to selct the external screen.
Just to be sure it's not a screen fault, are you able to test it on another PC (desktop, not laptop)?
Jan 05, 2008 | Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
111 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
