Question about Reddy Heater 60,000 BTU Kerosene Forced-Air Heater #R60A
Runs a few minutes and quits
Runs a few minutes and shuts itself off
  • stevet883 Jan 28, 2009
    my unit only runs for a few seconds then turns off, it's almost like it's not igniting, since I have a cloud of unlit kerosene coming out of the heateded end.,
  • Anonymous Feb 06, 2009
    Heater will run for a good 7-10 mins. then shuts off with a puff of smoke, I can turn the power off and back on and it will run about the same amount of time and shut off again
    Problem Solver:
  • 5 Answers
Hi this could be 3 problems ? no spark so vapour not igniting so excess vapour coming out as smoke, if it ignites stays on for a while goes out the flame probe is faulty, fuel filter is blocked needs new one , the fuel pipe going into tank has a non return vavle in it ( its a plastic ball in line with pipe ) if this is missing or stuck it allows fuel to drain back into tank and causes a air lock in heater causing vapour into chamber result in smoke coming out of end, as a quick fix for that you can fill pipe with fuel bend it so its traps in fuel like fire place pipe in tank when stopping fire stick mole gripps on pipe so next time fuel is there ready
Posted on Feb 05, 2009
After running for a few minutes the picture abruptly shuts off and turns back on for a few minutes then shuts off. This cycle repeats itself over and over.
Make sure the top and back of it are not dirty or obstructed, it sounds like it is overheating and shutting down to protect itself. Or your main power board is going out.
Nov 29, 2015 | Sceptre 32 X320BVHD 32 LCD TV
Vehicle starts runs for 1-2 minutes then quits, Starts right up. Fuel is being shut down.
Also what no one is mentioning is to make sure you have oil pressure, or that the oil pressure sensor is working, alot of newer vehicles run the fuel pumps off of them oil pressure sensor so if your vehicle stops pumping oil and lubricating, it shuts the fuel pump off to protect itself from damage or further damage
Apr 08, 2015 | 1993 Lexus Es 300
Flat panel TV comes on by it's self
It sounds that the voltage output from its internal power regulator board is not proper. Check it.
Feb 04, 2013 | Samsung UN19D4003 TV
My dryer starts, runs a few minutes, doesn't heat up and shuts itself off
check your sensors on the heater unit, there are two or more, simply us a meter and make sure power is on both sides of the sensor, if not then that specific sensor is bad and you should replace it, pull the sensor and tie the two wire together to see if it will heat, if it does replace the sensor they are cheap and will keep you from burning down the house
Dec 31, 2012 | GE DWSR463EGWW Electric Dryer
Bosch Axxis WTE86300US turns itself off after ten minutes, won't turn back on for a few minutes after that
I would bet you have a bad sensor. There are a couple of sensors that monitor heat. When it gets too hot they shut it down as a safety precaution. Once it is cool enough it will start up again.
Sep 26, 2012 | Bosch Dryers
Reddy Heater 60,000 BTU Kerosene Forced-Air Heater #R60A Logo
319 people viewed this question
Top Reddy Measuring Tools & Sensors Experts
jdthefixer
Matt Olenzek
Matt Olenzek
Are you a Reddy Measuring Tool and Sensor Expert? Answer questions, earn points and help others
