Question about Garmin StreetPilot C330 GPS Receiver
Street Pilot 330 battery dead?
What is Garmin's policy if the battery appears to be dead and the unit is still under warranty...Must it always be sent back to them, or do they have any type of repair service available? Thanks for your help.
  • Marie Robinson Jul 05, 2007
    I just noticed yesterday that the battery isn't charging. I checked the fuse on the adapter and that is fine. The unit will work when it is plugged into the cigarette lighter in the car, but only then. I tried charging via the computer(which the manual says can be done) and also tried in with another adapter (in my son's car) and it wtill wouldn't charge. I'm assuming it's the battery since it does work when plugged in. I've had the unit since Christmas. Thanks for your help.
  • Anonymous Jun 18, 2008
    Unit is approx. 3 years old works fine but battery will no longer charge. Can it be replaced without sending back to factory? I use it everyday for business..Called tech support but cannot get through as wait is
    Problem Solver:
  • 19 Answers
It would be strange for the lithium ion battery to be dead so soon. what have you done to charge it up? there are ways to kick start the batterys but i need to know a little history on what has occured up to now.
Posted on Jul 05, 2007
SOURCE:
Our garmin street pilot c330 tells us the battery is dead when it's plugged in and then goes blank. Can this type of battery be replaced?
yes the battery needs to be replaced, even when the GPS has external power the battery must be good for it to work,
May 15, 2010 | Garmin StreetPilot C330 GPS Receiver
Help me unlock my gps i do not remember my pin # all i can remember is there is 6 # in the pin please help me
Take it back to the 'secure location' as indicated in your service manual. It will automatically unlock when it gets a full satellite signal. You have to enter the PIN number twice when setting up the unit. You should always use a number which is familiar to you so you can remember it. If you can't remember it, and if your secure location doesn't unlock the unit, you will need to send the unit to Garmin to unlock it. You will need your receipt for Garmin to unlock the unit.
May 31, 2009 | Garmin StreetPilot c530 GPS Receiver
Will not charge or activate the screen. (c340 Street Pilot)
It sounds to me that the unit is defective as well. no voltage at the battery does mean its dead but not defective. I would call in on the warranty.
Jan 20, 2009 | Garmin StreetPilot c340 GPS Receiver
Garmin street pilot c340 battery appeared low, used USB cable to hook up pilot with my computer but device doesn't appear to turn on, computer cannot locate device on Drivers, can I rechare steet pilot...
I followed the instructions of the Online manual for the Garmin Street Pilot c-340, I removed the faceplate of the Street Pilot and then using my thumb pressed down on the reset button. I then pressed the power on button on the side of the device- the screen lit up, I then plugged one end of the USB cable into my computer and the other end into the device. The information on the screen of the device indicated the Lithium Battery was charging properly.
Jul 14, 2008 | Garmin GPS
My garmin street pilot 330 will not power on
I've had a couple of Garmin C330 units and a C340. They're good quality except for the flimsy power plugs. My first one out of the box had a defective plug which made intermittent contact when I plugged it into the lighter. Tightening the knurled nut on the tip of the plug helped somewhat, but didn't fix it completely. It became a non-issue after I bought a friction mount which came with a better cord and plug. The friction mount also stopped the problem of the suction cup constantly falling off the windshield.
Lee
Jul 08, 2008 | Garmin StreetPilot C330 GPS Receiver
StreetPilot C330
Go to www.garmin.com and read about "Map Updates" Enter your unit's serial number and see if there's a newer map available. It will explain about how to buy and install the update.
Jul 01, 2008 | Garmin StreetPilot C330 GPS Receiver
Update 2009 for Street Pilot c330
2009 upgrade data is too large for garmin 330 must have sd card
Jun 08, 2008 | Garmin StreetPilot C330 GPS Receiver
Cracked screen on Garmin street pilot 330
Given the cost of buying a new LCD with touchscreen is about $130 USD + shipping. Your best solution is to sell the existing unit and buy a new Nuvi or recondition C330.
Garmin will repair the unit for $150 and provide the lastest update and map.
Jan 01, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin 330 street pilot keeps shutting down, only had it 1 year
Have you tried charging the unit on the computer? If not, try doing this for a few hours. Sometimes it can help.
Nov 04, 2007 | Garmin StreetPilot C330 GPS Receiver
Street pilot
There is a reset button on the unit
Aug 14, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
190 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
