Question about YouTube Videos
China xx videos - YouTube Videos
Where can i find the serial number of acer aspire 4315
Dear Paulpwajok,
In the case of a laptop (notebook), turn the computer upside down, as if you was going to take the main battery out. Near the product key, you should see a large square white sticker with the following
Acer aspire xxxx
model # xxxxxxxxxxxxxxxxxxxxxx
made in china xx:xx:xx
(x is a bunch of alpha numeric characters).
Your can also find the serial and model number of the machine in two more places.
one is within the system bios/ cmos (get to this by F2 on bootup)
other one is within windows. . . go to start>control panel>system.
If you are feeling technical, then you could always go into a cmd or command.com interface and run systeminfo, that will tell you everything about the computer.
Note: if the serial/ model numbers dont match the sticker, then chances are you have potentially a stolen machine or a pirated/ counterfeit operating system installed.
I hope this is the fixya for you and look forward to hearing how you get on.
yours sincerely
Ouszen
Feb 07, 2012 | Acer Computers & Internet
When I receive text messages, only the number shows up, not the name of the sender
HelloThis kind of problem normally comes in non branded/china mobiles, the only remedy is, put the contact number with full country and area code like +XX-xxx-xxxxxxx, then it will give you the name with contact number.
Hope it helps, good luck
Dec 11, 2010 | Cell Phones
My sansa e250 having video option, but it not supot any video file to play on the player.
When your operating system on the computer is Windows:
Run the Sansa Firmware Updater to get the Sansa Media Converter: http://kb.sandisk.com/app/answers/detail/a_id/101/related/1
When your operating system on your computer is Mac, or when you want to update manually:
go to the Sansa forum: http://forums.sandisk.com/sansa/board?board.id=e200
note
Only when you have the e200 series version 2 player, videos can be viewed from the microSD card.
Accessing the microSD card:
http://kb.sandisk.com/app/answers/detail/a_id/167
Highest capacity of the microSD card:
Verify the version of the player. To check, go to Settings > Info.
For 01.xx.xx firmware (e200 version 1) - up to 2GB microSD cards
For 03.xx.xx firmware (e200 version 2) - up to 16GB microSDHC cards
Differences between e200 version 1, 2 and Rhapsody player:
http://kb.sandisk.com/app/answers/detail/a_id/193
For supported files, see:
http://kb.sandisk.com/app/answers/detail/a_id/21
and
http://kb.sandisk.com/app/answers/detail/a_id/32
Aug 13, 2010 | SanDisk Sansa e250 MP3 Player
Videos. china
Youtube is now blocked in China. http://unblockyoutubeinchina.info has information about 12vpn, a service which hides your IP address and lets you access blocked sites. I use it. I'm in Fujian and have been in China for three years.
May 01, 2010 | YouTube Videos
What does code C:32:20 mean
5-digit display Cause and/or Corrective Action C:04:xx You are using a battery pack that is not an "InfoLITHIUM" battery pack. Use an "InfoLITHIUM" battery pack. C:21:xx Moisture condensation has occurred. Eject the cassette and leave your camcorder for at least one hour to acclimatize. C:22:xx The video heads are dirty. Clean the heads using the Sony V8-25CLD cleaning cassette. C:31:xx
C:32:xx A malfunction other than the above that you can service has occurred.
  • Eject the cassette and insert it again, then operate your camcorder.
  • Disconnect the power cord of the AC Adapter or remove the battery pack. After reconnecting the power source, operate your camcorder.
Hope this helps
Apr 14, 2010 | Sony Handycam DCR-TRV250 Digital Camcorder
Sony h8 video camera problem
Try depressing the "Reset" button with the camera powered on using a pencil/ball point pen - the camera's logic may have got out of sync. This often helps to remove C:xx:xx error types as well.
Jan 12, 2009 | Sony HDR-HC1 Mini DV Digital Camcorder
None of the words are showing
Put the files on the root of the P2's folder. Unplug the P2. Leave it off for 2 mins, and power up.
Now, if this does not work, you probably need a config.dat file which you copy with the 2 firmware files onto your P2.
Open notepad
write:
YP-P2
XX XX UMS
Replace XX XX with the 2 letters in front of your P2's firmware (Settings>System>about). Example: EU EU UMS
and save as config.dat (remember all files)
Sep 11, 2008 | Samsung Yepp YP-P2 Digital Media Player
Psp
First Tell me about your PSP firmware Version. If its a orginal SONY firmware you can't play the games from the memory stick. If you are in custom firmware follow this procedure.
1.press the SELECT button so you will get the M33 VSH MENU
CPU Clock XMB - Default
CPU Clock GAME - Default
USB Device - Memory Stick
UMD ISO MODE - Sony NP9660
ISO VIDEO MOUNT - NONE
Make sure that its showing as per the above values. if not change it to the above values.
If still the problem continues check these too..
Go to the recovery menu.>>> configuration >>> Game folder homebrew (currently: 3.XX or 4.XX kernel)
if its showing 1.50 change it to 3.xx or 4.xx
also
Go to Recovery >> Advanced >> Advanced Configuration
and make sure that both the options are Disabled.....
Jul 24, 2008 | Sony PlayStation Portable (PSP) Console
Trying to remove a ip route on the 5871.
normally on router commands, in order to delete something you do not write del, but instead write out the command you would type to add the route with the word no in front of the line.
so if the command to add was eth ip addroute xx.xx.xx.xx xxx.xxx.xxx.xxx xxx.xx.xx.xx 1
the command to take it off would be, no eth ip delroute xx.xx.xx.xx xxx.xxx.xxx.xxx xxx.xx.xx.xx 1
May 09, 2008 | Efficient Networks SpeedStream 5871 Router
CODE REGION
Turn the player on and open the disc tray. Press [CLEAR] followed by [1][3][6][9] and one of the keys [0]...[8] corresponding to the region you want to set the player for (1 for Region 1, 2 for Region 2 and so on, press 0 for Region 0 or Region Free). Turn the player off then on again for the changes to take effect.
To verify the region code, press [SETUP] followed by [1][3][7][9]. A screen will then pop up with the firmware info and the current region code setting. Using [SETUP][1][3][6][9] did not work for me.
Or
To modify the region, turn on the unit and open the disk tray. Using the remote, press [CLEAR][1][3][6][9][zone code] and cycle power on the unit (not necessary to unplug the unit, simply use the front left <POWER> button. Example: Turn on; open tray; [CLEAR] [1][3][6][9][0]; unit OFF, unit ON and you'll get a zone free DVD player.
To confirm the zone code, turn on DVD player, (unit may or may not have a disc, check that the disc tray is closed, and press [SETUP][1][3][7][9]. You'll have all the firmware information (Version xx.xx.xx.xx SUB-VER xx.xx.xx.xx;
8032 xx.xx.xx.xx; Servo xx.xx.xx.xx; RISC xx.xx.xx.xx; DSP xx.xx.xx.xx; Region Code 0) That's that final "0" that you are looking for!
Mar 17, 2008 | RCA DRC247N DVD Player
YouTube Videos Logo
29 people viewed this question
Top YouTube Computers & Internet Experts
Michael Terence...
Michael Terence...
Mike
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
