Samsung HLP4663W 46 in. Rear Projection HDTV Television
Problem for Samsung HLP4663W 46 in. Rear Projection HDTV Television
Samsung HLP 4663W DLP TV 3 lights blinking
By mattfuller30 on Jan 22, 2009
Lamp light flashed then tv restarts a few times then all 3 lights flash. No picture or sound.
I replaced the lamp with no success, then the ballast today. I stuck a voltmeter on the ballast power plug while it was plugged in and the tv powered on and it read 320 VDC so I assume the lamp, ballast and power supply are good. Would that be right?
I did notice about a month before it quit working a winding noise when the tv was powered off after running for several hours, more like half the day. That was probably the color wheel showing signs of normal wear and tear?
What should I check? I dont know what the DMD board does but I see it's brought up allot with this fault.
Comments:
Jan 26, 2009
- Terry,
I'm not getting any voltage to my color wheel. I checked the power plug coming from the DMD board and it's 0vdc and I think I've read somewhere that it should be 5-7.5 vdc.
Would this mean the DMD board is at fault?
Same Problem
Jan 27, 2009
-   I just replace my bulb today and still have the error for lamp. Last bulb was replace in May 08. Color wheel was Sept 08. Now in Jan 09 the no picture no sound. Lamp error in on after replacing with new bulb-   wlk3920
Solution #1
posted on Jan 24, 2009
Somewhat Helpful)
Terryfic
Rank: Guru  Samsung Televisions & Videos  Expert
Rating: 87%, 1731 votes
Color wheel is the biggest failure part in Samsung DLP...
A little technical to replace...............T.
Comments:
Jan 26, 2009
- DMD is very pricey to sub, unless you can find a good used one.
Color wheel is not expensive & you said it was "whining" recently,
so subbing it makes some sense................T.
Was this helpful?
Yes
No
Popular Solutions for Samsung HLP4663W 46 in. Rear
Questions and Unsolved Problems for Samsung HLP4663W 46 in. Rear
Do you recommend Samsung HLP4663W 46 in. Rear Projection HDTV Television?
Answer
Answer
ghosting of picture and slight move to right its a samsung sp42w5hfx rear projection tv
Answer
When I watch HDTV it works great, but when I switch to regular digital channels (from the cable box... (More)
Answer
went from high speed cable to verizon fios, and now my game system is very cloudy, flickering and... (More)
Describe your Projection Televisions problem:
Related Products & Issues:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
in Burnsville, MN
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
