Question about Vizio VL470M 47 in. LCD TV
Vizio VL470M 47"/power fuse size?
What size power fuse does this TV take in amps?
  • 2976 Answers
SOURCE: need to register vizio tv
Here's the link to register
http://www.vizio.com/support.aspx
Posted on Feb 06, 2009
  • 92 Answers
SOURCE: vizio 47" lcd no picture no sound has power
this could be one of two problem. first, check if you have back light. If you do then the problem is with the M/B. Second, if you don't have back light then the inverter is bad and needs to be replace.
Posted on May 20, 2009
  • 3 Answers
SOURCE: the screen on the my Vizio 47
are you sure it is on the correct input?did you have a power surge? have you reset it?did it go while you where watching it or when you turned it on?does it have audio?
Posted on Jun 09, 2009
SOURCE: no picture or sound, light comes on in the front and have to unplug tv to turn it off.
I had this exact problem on my Vizio 47" HDTV. I removed the speakers and all the screws on the back cover. Took the cover off and located the fuses on the largest circuit board. The are in the upper right hand corner of the board. There are 3 of them in a row labeled LF 1.5, LF 3.0 and LF 3.0. The are white in color with copper ends. I took a volt meter and measured continuity across all fuses individually and found the LF 1.5 to be blown. The guy at the electronics store sold me a barrel 1.5A fuse and told me to soldier it across the top of the blown fuse. It took an extra set of hands but the TV works perfectly.
Posted on Jun 23, 2009
  • 148 Answers
SOURCE: need screw specs to attach base assy to tv
I
Hi there, if you are trying to just remove the base, then on your model there is one screw in the center of the underside of the base. If you want to remove the neck of the base to then remove the 8 screws on the back of the tvs neck too. I hoped this helped, please rate thank you!
Posted on Feb 05, 2010
Size of fuse for a power supply board on a Philips 42" tv model number42pFL6704D/F7
The amp rating of the fuse is written on the metal cap on the fuse.
Dec 21, 2012 | Philips 60PP9200D Television
Fuse amp size for 32" bush iD
If you mean the mains input fuse then usually 3.15A Fast Blow.
Other fuses vary.
Dec 24, 2010 | Bush 5693D 24" TV
What size fuse do I need on the power cord from the battery to the amp? thanks
It depends on the size of the amp. The best route to take is to purchase an amp installation that includes the power and ground cables, RCAs,remote turn on wire and...fuse holder with fuse. You choose the amp kit base upon wattage ofthe amp and they come in 0,4 and 8 gauge sizes.
Sep 23, 2010 | Legacy Audio LA930 Car Audio Amplifier
Will not power on
Check the main A/C fuse. These sets are famous for blowing the fuse. It is usually a 6.3 amp. Look at fuse to confirm size. Thanks for using fixya.
Feb 27, 2010 | Panasonic CT-34WX54 34" TV
We had a power surge in our area a little while ago and our tv went. I took the cover off the rear and saw a 6.3 amp 125v fuse right inside where the cord went and ir was burnt. I replace it with the same...
1.Check the power outlet where your TV is plugged.
Also your power panelboard for tripped off breaker.
2. If ever, your TV won't power on, then, it needs to
check your TV circuits. You can start at the power
supply IC for busted part., then to the other section,
(transceiver, audio, and video section)
Sep 30, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
No power for rca tv had wire on garage short out then tv stop working
check first the Fuse inside the TV, its usually a 3.15 amp 20mm size. If the is good. The Power side need to repair its the STR or IC got problem. But make sure the AC voltage is present in power side of the TV. Use a Multimeter to check.
Sep 13, 2009 | Televison & Video
Tv getting no power
HI
MOST TV'S HAVE A SMALL FUSE INSIDE TO PROTECT THE CIRCUITS.
OPEN THE BACK CAREFULLY AND LOOK FOR A GLASS SEE THROUGH TYPE FUSE ABOUT 5 AMP SIZE.
REPLACE THIS AND TRY YOUR TV
Jul 05, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Don't know what size and amps fuse to use for T4E250V (#on the fuse)
4 amp slow blow -- any fuse with those characteristics will suffice.
May 30, 2009 | Philips 27PT6441 27" TV
Sony Bravia LCD TV is tripping the fuse in the house
These things draw a huge surge current when turned on. What size fuse are you blowing? These things can surge 10-12 amps on turn-on. What about a fuse with a reset button. They will take alittle more surge before they go. Don't matter about the insignia working before because the cheaper sets tend to stay powered up more when off....thus not surging on from a dead start. Could you try a different plug on a different circuit/fuse? and see if that makes a difference. If you have a 15 amp fuse, then your pretty close with other stuff plugged in. What size is your service? Do you still have an original 60 amp box with screw in fuses? Is it an old house?
Sep 08, 2008 | Sony Bravia KDL-40S4100 40 in. LCD TV
Vizio VL470M 47 in. LCD TV Logo
75 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
