Question about Acer Aspire 5610-4648 Notebook
Acer l100 will not boot up
Seems to start up when it wants to. It's not overheating because it has been off all night.
  • Frank James May 11, 2010
    What is it doing when it will not start up? Do you hear one beep from the case or more when having problems? And what operating system is on it? That is a newer model pc so I'm sure it's Vista, but I would just like to make sure.
To all of those out there with an Acer Aspire L100 SFF that has decided it will no longer boot -
Symptoms: fans spin up, DVD spins up, possibly HD spinning up - no power, HD or network lights on front panel.
Previous Fixes: Changing out 3 capacitors on the mainboard, re-seating memory and processor.
I tried all three of the fixes above and still no joy. I discovered to my surprise that this PC, due to it's heat "issues", had developed a malfunction similar to the XBOX 360 and Ibook G3...it's video chip had developed some connection issues with the mainboard. Due to the heat, the BGA solder connections under the chip has either flexed and become disconnected or corroded with the same result;
Try this: Remove the DVD/HD "sled" - Using 3 fingers, put pressure (not enough to break the mainboard, but a fair amount) on the heatsink for the video chipset. While doing this, press the power button. If it powers up, this is your problem. You might have to try a couple of times with varying amounts of pressure on the heatsink.
Tools: Needle nose pliers,philips screwdriver, small flat blade screwdriver, new heatsink compound (I suggest AS5), a heat gun
The fix: Firstly, the mainboard must be removed from the case, and the heatsink removed from the video chipset. To remove the push-pins, use a pair of needlenose pliers from the back of the mainboard to squeeze the expanders to release the pins. If yours is like mine, after removing the heatsink, you will find that the thermal compound has hardened and is no longer effective...have some AS5 handy. Second, place the mainboard on a flat work surface. Make sure memory, cables and mini-pci wireless card have been removed. Starting about 4 inches above the video chip, put your heat gun on low setting and ove a period of about a minute, move slowly down until you are about an inch above the video chip (this is to heat it slowly and not cause damage) hold there for 30 seconds - you should notice the solder on all the connections around the chip change sheen from dull to shiny - over about 30 seconds to a minute, slowly lift the heat gun away - letting the heat dissipate slowly. Turn the heat gun off and let the board cool for 10-15 minutes. Third, put a thin layer of AS5 on the video chip core and reapply the heatsink, being careful not to chip the core. then proceed to reassemble the machine.
I did this repair myself 2 days ago...still working great!
Posted on Jul 06, 2009
  • amir900 Jan 06, 2011
    Thanks a lot for this detailed solution, it saved my computer!! (well, at least so far)
    I had the same problem (in addition to bad colors from the VGA port), so I followed you advice. But I decided that before using the heat gun I'll try to just clean the hardened thermal paste and apply a new layer. And so I did - I cleaned off the old thermal paste gently with a small flat screwdriver, applied a new layer and assembled everything back. It worked like a charm, and fixed the VGA colors problem as well!
  • 142 Answers
In your settings , you may have a program or two, that wakes the computer to get updates or perform scheduled tasks.
Posted on Jan 26, 2009
Acer aspire l100 will not boot but fans run
Try removing/disconnecting the hard drive and see if the BIOS boots up, if it does the HDD is causing the problem. Are you getting any beeping codes on start up, if so how many and hoe long in between?
Dec 06, 2011 | Acer Aspire L100 PC Desktop
I need boot files on a USB to boot up my acer aspire L100 can help with this. Paul
secure an os that is capable of using usb boot like windows xp portable.
Apr 18, 2011 | Acer Aspire L100 PC Desktop
None stop Continue long beep, fan slow little while and start normal repeatedly
What's this start normal repeatedly thing, you mean after a while it starts the boot process again, and you never get a BIOS screen?
You probably overheated things.  Test everything in isolation if possible, otherwise just inspect and reseat RAM, the videocard, the CPU, and try again.  When it happened to me last I had a burnt-out videocard.
May 18, 2010 | Acer Aspire L100 PC Desktop
My acer aspire l100 keeps shutting off. it sometimes will stay on for like two minutes but most of the time it shuts down after like 30 seconds. it works fine in safe mode. most of the time it shuts off...
this seems like a software issue . if you can not run your system but ift works fine in safe mode try to run a system restore from factory disks and see where that gets you,
May 14, 2010 | Acer Aspire L100 PC Desktop
No desktop view
The L100 series has a bad reputation for overheating. I worked on a friends and had to reseat the heatsink for the processor with new thremal paste to keep it running
Jan 26, 2009 | Acer Aspire L100 PC Desktop
Acer Aspire L100 overheating
You could try a new cpu fan and heatsink. They are normally inexpensive. if this does not work make sure all the case fans are working and check to see if your ram is overheating
Dec 22, 2008 | Acer Aspire L100 PC Desktop
L100 overheating
In most of the cases the cooling radiator inside the computer is full of dust, clean it as well as the fanblades and things will improve.
Try to find a place nothing is blocking the inlet on the back and the outlets on top and in the front, open the part which covers the usb and other connections on the front.
Sep 30, 2008 | Acer Aspire L100 PC Desktop
Acer l100 cuts out for no reason
I suggest to remove the program for itunes, i think it did make a mistake  to the operating sistem
Dec 06, 2007 | Acer Aspire L100 PC Desktop
Unwanted System Shut Down
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} ok guys this is the problem i work for Acer and basically if you own an aspire L100 then you have to be prepared to modify your little bad boy because of acers poor design and a crappy little fan the anything inside the case feels like its on holiday in the tropics what you have to do is side mount 2 extra fans with separate 12v supplies and your system will never overheat or die on you if you have any questions on how to do this just email me :-) me
Aug 10, 2007 | Acer Aspire L100 PC Desktop
Acer Aspire 5610-4648 Notebook Logo
506 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
