Question about Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive
WD Passport 3200 isn't assigned a drive letter when plugged in
The safely remove hardware icon starts up when this external drive is plugged, but I don't get a drive letter. I can't access the drive with manage drives. I have uninstalled all usb drivers and let windows re-install then tried the drive again. The computer actually is slow to respond, and will not properly shut down even after I unplug this WD Passport drive. I connect the drive to an external powered hub to solve the low power issues. Any suggestions what I can do next.
    Problem Solver:
  • 8 Answers
Try to right on my computer and click on Manage
then click on Disk Management
Observe if you are able to see Drive 0 <- which is your internal drive in your computer.
Observer also if you are able to see Drive 1 <- this will indicate that the system recognise that an external USB drive was attached to it.
Right click on the area right next to the box that says Hard Drive 1 and see if you can find the wordings "Change Drive Letters and Paths".
If you manage to go that far, click on any of your preferred drive letters, for example Z: and then click OK. And then go to Windows Explorer or My Computer and see if Z: existed there.
Posted on Jan 22, 2009
  • ShamSg Jan 22, 2009
    Are you able to resolve it?
How do I disconnect (uninstall) a WD External Hard Drive from my computer? I am using a WD 3200AAK WD External Hard Drive and want to install a 1 TB WD External Hard Drive. I would like to use the old one...
External hard drives don't need any program installed on your computer to run. Your operating system Windows, Linux should handle it as soon as you plug the usb in your computer. The programs included in your WD external hard drive are tools to backup your data.
If you try to hook up your hard drive to a Windows prior to XP, maybe your computer will not handle it.
It is always safer to safely remove your drive using the green arrow icon in the lower right corner of your screen. This way, the drive is shut down properly and you minimize chances of fails when you plug it again on another computer.
Hope this helps!
Feb 08, 2011 | Western Digital My Book Essential Edition...
The WD my passport is not recognized by the computer .. It was wroking fine couple of weeks ago and am pretty sure it didn't fall or something.. its not recognized and not showing on my computer .. please...
Assign a drive letter for the External drive.
  • Right Click on My Computer
  • Scroll to Manage
  • Select Disk Management
  • Locate the External drive in the lower bottom Right corner, Right Click, Select Assign Drive Letter. Ok/Close
Open up My Computer, and you should see your External drive with your new drive letter assigned to it.
Dec 31, 2010 | Western Digital My Passport Essential...
How do i use this. to backup my files. were to plug it in to my dell laptop.
Open "My Computer", and look at each icon, e.g,. 'A:' and 'C:' and 'D:'.
The cable from the Passport will only fit into a 'USB' port on your computer. Your computer may have more than one such port.
Just pick one, and connect it.
Once it is connected, look again at that 'My Computer' window.
There should be another drive-letter, assigned by Windows to your Passport.
Open 'My Documents'.
Click 'Edit'.
Click 'Select All'.
Right-mouse click on one of the selected objects.
Point at 'Send To'.
Click the drive-letter assigned to the Passport.
The selected files will be copied from your 'My Documents' folder onto the Passport.
Oct 30, 2010 | Western Digital WD Passport 250GB Portable...
In hurry, I unplugged my WD Passport (400U017-RTE), I had a folder open which I thought was from PC "My Documents" but unfortunately no. When I plugged my WD Passport, it could not be recognized i.e. I...
Plug in the drive and, on the status bar next to the data and time there will be an USB icon Click on "Safety remove hardware and eject media". Once its says its safe to remove media, unplug the hardware and plug it in again after a few minutes and it should start working again. If it still does not work you need to delete your USB driver from system setting and reinstall the driver.
Feb 11, 2018 | Western Digital Passport WDXML800UE...
WD External Drive-USB recognize, but no icon, can't access
1. Right click on My Computer > Manage;
2. On the new window click on Disk Management, on the right side, right click in the USB Volume and chose "Change Drive Letter and Path..."
3. In the new window click on "Add..." to assign a letter to your USb drive.
Best Regards
Jun 24, 2009 | Western Digital Passport WDXML800UE...
Getting an old Dell Dimension to recognize a WD Passport
In the end, I assigned a different drive letter to the device and it worked.
There's a lot of info out there on how to assign a letter. Here's one link:
http://lifehacker.com/software/windows/change-windows-drive-letters-167525.php
Feb 17, 2009 | Western Digital WD Passport 250GB Portable...
SimpleTech 320 GB hard drive not recognized by PC
Windows likes to play with drive letter assignments, especially when you remove a device without using the "safely remove hardware" icon. When you plug it back in, Windows may think that you've plugged in a new one and assign it a new drive letter. Try this:
Your computer can use up to 26 drive letters, from A through Z. Use drive letters C through Z for hard disk drives. Drive letters A and B are reserved for floppy disk drives. However, if your computer does not have a floppy disk drive, you can assign these letters to removable drives.
Before you modify drive-letter assignments, note the following items:
  • Changing the drive letter of the system volume or the boot volume is not a built-in feature of the Disk Management snap-in.
  • Many MS-DOS-based and Microsoft Windows-based programs refer to specific drive letters for environmental or other variables. If you modify the drive letter, these programs may not function correctly.
uparrow.gifBack to the top How to assign a drive letter loadTOCNode(2, 'summary'); To assign a drive letter to a drive, a partition, or a volume, follow these steps:
  1. Log on as Administrator or as a member of the Administrators group.
  2. Click Start, click Control Panel, and then click Performance and Maintenance.
    Note If you do not see Performance and Maintenance, go to step 3. Performance and Maintenance appears in Control Panel only if you use Category view. If you use Classic view, Performance and Maintenance does not appear.
  3. Click Administrative Tools, double-click Computer Management, and then click Disk Management in the left pane.
  4. Right-click the drive, the partition, the logical drive, or the volume that you want to assign a drive letter to, and then click Change Drive Letter and Paths.
  5. Click Add.
  6. Click Assign the following drive letter if it is not already selected, and then either accept the default drive letter or click the drive letter that you want to use.
  7. Click OK.
The drive letter is assigned to the drive, to the partition, or to the volume that you specified, and then that drive letter appears in the appropriate drive, partition, or volume in the Disk Management tool.
I hope this does it for you. Thanks for using Fixya!
Dec 11, 2008 | SimpleTech SimpleDrive 160 GB External USB...
Bought extrenal hard drive WD
Right click on my computer.
Choose manage.
Then choose disk mangement.
Then you will probably have to assign it a drive letter.
Aug 11, 2008 | Computers & Internet
No drive letter
When remove the drive do this steps properly first when you want remove the drive remove safley than remive it
Jul 13, 2008 | Western Digital My Book Essential Edition...
Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive Logo
769 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
