Question about Gigabyte GA-6VXC7-4X-P Motherboard
Error beep codes on GA-6VXC7-4X
I turn on my computer and I hear five or six beep. My RAM and VGA is good, I tried replace on another board and ok.
    President:
  • 2,351 Answers
Hello kemas_franky, your Gigabyte GA-6VXC7-4X-P motherboard uses the AMI bios. Each bios has a listing for beep code errors. Click on the link provided for AMI's beep codes; http://www.bioscentral.com/beepcodes/amibeep.htm
You need to be 100% sure of how many beeps you are hearing.
5 short beeps means, the system CPU has failed. If you still have your manual, go to page 30. There you'll see the bios name is AMI.
Below is Gigabyte's web site link for your GA-6VXC7-4X-P MB.
http://www.gigabyte.com.tw/Products/Motherboard/Products_Spec.aspx?ProductID=1432
Not everyone has a spare CPU laying around so dissemble your CPU. Clean the heat-sink & CPU surfaces. To help you do this I am including a uTube video; http://www.youtube.com/watch?v=1dCa7CZ_3sI&feature=related
Try cleaning & reapplying thermal grease. (If your old grease is hardened or dried out. (Try this before replacing your CPU).
If you need a CPU & want to buy a new one you'll find a couple listed on this next link; http://www.thefind.com/computers/info-pentium-iii-socket (Prices between $10.00 & $13.00 US).
CPU Socket 370 Pentium III 100/133MHz.
If you find you heard 6 beeps & not five. Try replacing your keyboard. If that does not help than the motherboard controller is bad & you'll have to replace the board. The controller can not be repaired.
Thank you for using FixYa kemas_franky!
If you find this information helpful, please vote.
Have more questions, post here.
Mike
Posted on Jan 22, 2009
Turns on blank screen with 4 beeps
This is a list of beep codes for a different Dell laptop, but the chances are they will use the same codes for each product.
4 Beeps indicate a RAM issue. Try taking it out if you are able. If you have two memory strips, alternatively remove one and leave one in, see if its just an issue with one of them.
If you only have the one, the only way to see if this is the issue is to get a replacement in. Might be worth going to your local pc shop
Beep Code indicators
One - Possible system board failure or BIOS ROM checksum failure
Two - No RAM detected
NOTE: If you installed or
replaced the memory module,
ensure that the memory module
is seated properly.
Three - Possible system board failure or Chipset error
Four - RAM read/write failure
Five - Real Time Clock failure
Six - Video card or chip failure
Seven - Processor failure
Aug 22, 2013 | Dell Inspiron 1545 Notebook
Dell studio 1749 has 4 short beeps when trying to start
One Beep (Possible system board failure - BIOS ROM checksum failure)
Two Beep (No RAM detected)
Three Beep (Possible system board failure - Chipset error)
Four Beep (RAM read/write failure)
Five Beep (Real Time Clock failure)
Six Beep (Video card or chip failure)
Seven Beep (Processor failure)
Eight Beep (Display failure)
Feb 12, 2013 | Dell Studio 17 (1749) Laptop black -...
When i turn on dell inspiron m5030 it beep 3 times then go off???
Looks like the motherboard died.
Beep codes from m5030 manual found here: http://support.dell.com/support/edocs/systems/insM5030/en/index.htm
Beep Code Possible Problem:
failure
NOTE: If you installed or replaced the memory module,
ensure that the memory module is seated properly.
Eight - Display failure
Jun 25, 2012 | Dell Inspiron M5030 2800B3D 156Inch Laptop
I have recently built a new PC with an Asus P8H61-M and upon turning the PC on I am recieving no Visual on either of my monitors
Hello
If this is the first time to turn you on your computer check first the power supply of your computer if connected to their proper connector. Check your memory if clip properly in there memory slot. If you are using Video Card check it if it is properly connected to the connector. Then connect your VGA connector at the back of your computer when you have video card connect the VGA Cable of you monitor to the video card VGA output if does not have connect it with the onboard VGA output. Then press the power switch if the unit is still no visual in monitor try to search or hear a beeping sound in your computer by its on board buzzer. Find which beep you hear from your computer.
No Beep- No Power, Loose Card, or Short.
One Short Beep- Normal Post,, Computer is OK.
2 Short Beep- POST error, review screen for error code
Continues Beep- No power, Loose Card, or Short
Repeating Short Beep- No Power Loose Card or Short
One Long And Short Beep- Motherboard Issue
One Long and Two Short Beep- Video (mono/CGA Display Circuitry) Issue.
One long and three short beep- Video (EGA) Display Circuitry
Three Long Beep- Keyboard/ Keyboard Card Error
One Beep, Blank or Incorrect Display -Video Display Circuitry
Hope this help with your problem. Keep on touch in fixya
Jul 19, 2011 | ASUS P8H61M Intel H61 TX Motherboard
I have just installed a 478 socket MSI MS-6526 ver 3 motherboard to my computer and all it dose is bleeps when i turn it on any help would be apricated
check for the error beep if you hear continues beep it means issue with the memory. check the RAM if it is properly inserted to the slots and if it is compatible to the motherboard. if you hear 2 or 3 beeps it means issue with the video. your video card maybe not compatible or not properly inserted to the slot. your motherboard has a built in VGA/Video card try using that first. try connecting the main components memory/RAM, power supply, KB and mouse, VGA card(optional you have a built-in) then check if there is a display or if it booted. then one by one add your other components you want to add. just to trace the problem.
May 19, 2011 | Intel Motherboard
DDR2 Ram allergic problem....
When using different kinds of RAM together in the same computer, there is a general rule that the Slowest Ram has to occupy the first slots (the ones closest to the CPU and usually numbered on the Motherboard)
This is possibly the cause of your ram error although they're both 400Mhz, just try re-arranging them.
I think the Ram Error Code is two long beeps and the video error is one long beep and three short beeps.
Also, watch the Ram counter when you first turn the computer on, or check the "My Computer" properties to see that all the RAM installed is recognized.
Jan 18, 2010 | Gigabyte GA-K8VM800M Motherboard
At start up, before windows loads, a consistent series of annoying beeping occurs....
If they're occurring right as you turn the computer on, it's your Power On Self Test (aka POST) letting you know. Since I can't be more specific, here's a synopsis of POST beeps:
One single beep followed by three, four, or five beeps -- System-board problems, possibly with DMA, CMOS setup chip, timer, or system bus. The computer usually won't boot when this is the problem.
Two beeps -- The POST numeric code is displayed on the monitor, usually nothing to be concerned about, but you might google the code on another computer and see what you get.
Two beeps followed be three, four, or five beeps -- First 64K of RAM has errors. Solution is to replace RAM.
Three beeps followed by three, four, or five beeps -- Keyboard controller failed or video controller failed. Either you won't be able to see or type with this error.
Four beeps followed by three, four, or five beeps -- Problem with serial or parallel ports, system timer, or time of day. Check your BIOS settings (usually F2 at start up) to make sure everything is correct.
Continuous beeps - problem with power supply. Probably won't do much with this error. At the very best, your computer will boot and run very, very slowly.
Hope that helped.
Sep 01, 2009 | Compaq Computers & Internet
When I turn on my computer i hears a few double beeps and I don't see anything on my monitor while computer sounds like it running
Here is a link for with some information for the GA-M55plus-S3G motherboard:
http://china.giga-byte.com/FileList/Manual/motherboard_manual_ga-m55plus-s3g_3.x_e.pdf
The below was taken out of the document:
The beep codes below may help you identify the possible computer problems. However, they are
only for reference purposes. The situations might differ from case to case.
�� AWARD BIOS Beep Codes
1 short: System boots successfully
2 short: CMOS setting error
1 long 1 short: DRAM or M/B error
1 long 2 short: Monitor or display card error
1 long 3 short: Keyboard error
1 long 9 short: BIOS ROM error
Continuous long beeps: DRAM error
Continuous short beeps: Power error
Jul 07, 2009 | Gigabyte GA-M55plus-S3G Motherboard
Display problem
The most common beeps that you will encounter 95% of the time in repairing PC's are:
1 beep - computer ok
continous beeps / long beeps - memory error
continous short beeps - bios boot block/corrupted bios
1 long beep followed by 3 short beeps - video card error
or this might help
you can check out this list
AMI BIOS
1 short - Computer ok
2 short - RAM failure
3 short - Parity RAM failure
4 short - System timer failure
5 short - Motherboard failure
6 short - Keyboard controller error
7 short - CPU failure
8 short - Video RAM failure
9 short - ROM BIOS error
10 short - CMOS read/write error
11 short - Cache RAM error
1 short, 3 long - Memory failure
1 short, 8 long - Video adapter failure
Check board/chipset makers website for more infomation.
AWARD BIOS
1 long - Memory error
1 long, 2 short - Video error
1 long, 3 short - Video failure
Continuous beeps - Memory or video failure
note that AWARD relies on motherboard manufacturers to develop their own beep codes - the above are only their own internal codes. You will need to refer to your own manual for an explanation of precise codes.
Standard IBM beep codes.
No beep - Power supply or motherboard failure
1 short - System is ok
2 short - POST error (code displayed on screen)
Repeating short - Motherboard failure
1 long, 1 short - Motherboard failure
1 long, 2 short - Video display adapter failure
1 long, 3 short - Video display adapter error
3 long - Keyboard error
Pheonix beep codes
1-1-3 CMOS memory failure
1-1-4 BIOS failure
1-2-1 System timer error
1-2-2 Motherboard error
1-2-3 Motherboard error
1-3-1 Motherboard error
1-4-1 Motherboard error
1-4-2 Memory error
2-x-x Memory failure (any number of other beeps)
3-1-x Chipset error (any number of other beeps)
3-2-4 Keyboard controller error
3-3-4 Video adapter failure
4-2-4 Expansion card failure
4-3-4 Time of day clock failure
4-4-1 Serial port error
4-4-2 Parallel port error
4-4-3 Math co-processor error
the vga board has failed, its a very common problem in acer laptops, you can get a replacement part from www.acerparts.com im not sure if they ship into us but for europe thats where I get my parts.
my acers vga failed two times, ones within warranty and 12months after that, I have to say that acer products are really bad quality, I'm not sure about the latest models but from what I've seen the vga chipsets have real issues with the motherboards and keep failing over and over again.
I have not looked inside your model but the vga is either integrated into the motherboard = that means the repair will cost the whole motherboard, better to buy a new one.
if your model has a removeable vga like mine does, then you can consider changeing it to a new one. contact acer parts.
One of the covers in the bottom is the memory, one is network and last one I don't remember.
here are the contact details if your acer is out of warranty
http://www.acerparts.com/contact_us.php
The parts for your model are at http://www.acerparts.com/index.php?cPath=561_562_1064
you will have to contact acer parts directly, it may be that the vga is build into the motherboard or then the vga parts are not listed.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Jul 29, 2008 | Acer Aspire 5570-2758 Notebook
PCVRS620G won't turn on
i feel this is not a big problem. if u hear a beep of ram on beap on boot then ram is ok just short it and check for displaay. check ur cpu socket it may be loose. if u don hear a beep on boot change the ram and ur problem will be solved
Feb 07, 2008 | Sony PCV-RS620G PC Desktop
Gigabyte GA-6VXC7-4X-P Motherboard Logo
533 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
