Question about RCA R52WH73 Projection Television
RCA model R52WH77YX58 shuts off after a few minutes
FBT fuse blew, replaced now shuts off after a few minutes, someone said autoconvergence issue but not sure what it is or how to fix?
  • terrymurray Feb 19, 2009
    Should have updated. Found a broken sodder joint works like a champ now. Thanks.
  • ladywinn
    ladywinn May 11, 2010
    Do you still need help with your TV? And which fuse did you replace?
  • RCA Master
  • 5,138 Answers
Thank you for the reply so why not post what your problem was and how you Fixed it to help others/had.poor solder connections and where to solder.
Posted on Feb 19, 2009
My R56WH78 tv has lost convergence overnite,I can not access any convergence menu with the remote control,What should I try next.
This RCA tv model have a dead convergence fuse at FL231 at the right side of a FBT- a big black plastic block with a wire hook to a board.Must resolders the FBT-(Flyback tranformer too).U have all the tools and also can do basic soldering work too?Yes,try website like Ebay.com to by the RCA tv convergence fuse to replaced at location FL231 and and also resolder FBT-Flyback tranformer too.Will solved this tv RCA model convergence problems.
Aug 02, 2011 | RCA R56WH76 Projection Television
Hi I have a convergence issue. Is there a place in NYC where I can purchase these replacement items: (1) FL231 micro fuse (1) DL231 Diode (1) CL230 radial Capacitor I repaired the initial...
This DLP model RCA tv have convergence menu disappearing is very easy to fix just replaced the convergence fuse FL 231 near the FBT also must be resoldering FBT too.U can buy this FL231 covergence fuse at Ebay.com.No,but u must have to have a soldering iron,a desoring pump or desoldering braids and know how to basic soldering?To replaced this FL231 convergence fuse near the FBT and also must resodering the FBT too for protecting the new FL231 convergence fuse.
Mar 02, 2011 | RCA R52WM24 52" HDTV Projection Television
How do I access the menu to get to the auto convergence setting. My screen has lost its autoconvergence.
Than this RCA DLP tv have convergence fuses.Convergence fuse is dead.U have a soldering iron, desoldering pump or desoldering braid and can u do basic soldering? Replaced convergence fuse FL231 that near the right FBT.The one in the Middle out of the three useally dead.Try Ebay.com to buy the FL231 convergence fuse.
Jan 21, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I can find where to line up the pluses for the colors
No,convergence screen set up menu appear,Mean convergence is dead.Replaced the FL231 all three of these caps convergence fuse,near the FBT,big black block of plastic,flyback tranformer.Resolders FBT also.Done this will solved ur convergence problem in this RCA tv model.Ebay.com to buy the FL231 convergence fuse for the replacement.
Mar 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Colors separated, distorted picture, autoconvergance not available from the menu anymore
Replaced the FL231 fuse cap near the FBT.The one in the middle out of three fuse caps ,and reaolders the FBT also.
Jan 15, 2010 | Televison & Video
R56WH78 RCA TV FlyBack
Resolder all the pinns on the FBT chances are FBT is Bad they go out alot Call UED for Parts 1-800-648-6657
Oct 19, 2009 | RCA R56WH76 Projection Television
How do I preform an autoconvergence on my tv when that option is no longer avalible in the tv's menu?
Any time convergence is not listed on Menu you have a open Fuse FL231 there is 3 of them in a roll on deflection Board on right hand side of FBT flyback transfomer Fuses are small brown rectrangler looking caps But are Fuses it will be the 1 in the middle of them you can take a pair of piers to pull top off it just snaps back down on top.This should fix your problem, repair cost in TV Shop 235.00
Sep 21, 2009 | RCA R52WH73 Projection Television
Autoconvergence option is GONE!
There is a blown fuse and diode located next to the flyback transformer I believe the location is DL231 and the fuse is FL231
Sep 23, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Convergence nightmare
If this is a ITC222 chassis then you need to check the fuses that are near the flyback. I would also unsolder all the pins on the flyback and re-solder them as the factory lead free solder tends to crack and cause issues with the convergence. Re-solder it with common 60/40 solder you can pick up from Radio Shack or other places.
Jun 25, 2008 | RCA D52W19 52" Rear Projection Television
D52W23 colors not aligning
replace FL231 400ma located in front of FBT.This is what is wrong with your tv.
Mar 03, 2008 | RCA D52W19 52" Rear Projection Television
RCA R52WH73 Projection Television Logo
110 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
