Question about Maytag NMPEB08F2A Air Conditioner
Lack of cooling
This unit was operating fine 2 days ago, but now only emits enough "cool" air for one room (whereas before, we would have to adjust it because it would get so cold). I did empty the water.
  • 105 Answers
Check for blocked filters or coils, both on the hot side & the cool side. It is possible that either is blocked by airbourne dust or debris. This is common in areas with lots of poplar trees.
Posted on Jul 15, 2007
My kenmore window unit AC started blowing a white smoke like substance. It seems to be cooling fine. What is this and is it a concern?
The two things it could be, #1 - evaporator leaking refrigerant - unlikely if unit is still cooling o.k. because window units do not hold a lot of refrigerant and if there is a leak bad enough to blow smoke it would have stopped cooling by now. #2 - the humidity is high and the unit has cooled the air right at the discharge down below the dewpoint, a common occurence in window units and automobiles due to the short duct distance from the evaporator to the air outlet whereas with central air systems having longer duct systems the air gains more heat before being discharged into the room.
Aug 26, 2010 | Kenmore Heating & Cooling
Danby 12,000 BTU Portable Air Conditioner - Doesn't Cool Enough
put a xtra fan on you to blow the cooler air around. this might help. but i think you will find it is to small to cool what your trying to cool. good luck and good day
saw
Jul 09, 2009 | Danby Portable Air Conditioner
Refigerator is not cooling properly. Temp
Refrigerator or freezer is not cold enough check this part:
* Check the temperature setting
* Assure that there is enough room for air flow in the refrigerator or freezer
* Check for air flow restrictions in vents
* Test the temperature control
* Clean the condensor coils
* Check the door seals
* Test the door switch
* Test defrost heater
* Test defrost timer
* Test evaporator fan
* Check for a clogged drain tube
* Check for refrigerant leak
Mar 28, 2010 | GE Profile Stainless Bottom-Freezer...
Emitting a powder residue
its minerals in your water. not harmful at all.
Aug 07, 2017 | Vicks V4500 1 Gallon Humidifier
Frigidare window air conditioner with remote control about 3 yrs old. All controls seem to be working except when the energy saver mode is suppose to shut down the unit / the display goes dark but the...
Hello, I can assist you.
If the unit is supposed to turn off and it doesn't, it will be necessary to check several things.
  • First, is the unit cooling properly? See the section entitled "The air is cool but doesn't seem cold enough."
  • Next, is the temperature of the room adequately cool? If the room temperature is cold enough try setting the thermostat to a higher temperature. If the unit then seems to work properly leave the thermostat set to the higher temperature.
  • If the unit is cooling properly when it is turned on and the room is not cool enough the problem is probably that the unit is trying to cool an area that is too large for its capacity. Use the following chart to find the appropriate size air conditioner to use:
AREA TO BE COOLED / CAPACITY (BTU/HR)
100 to 150 square feet = 5,000
150 to 250 square feet = 6,000
250 to 300 square feet = 7,000
300 to 350 square feet = 8,000
350 to 400 square feet = 9,000
400 to 450 square feet = 10,000
450 to 550 square feet = 12,000
550 to 700 square feet = 14,000
700 to 1000 square feet = 18,000
If the room is heavily shaded, reduce needed capacity by 10%
If the room receives a lot of direct sun, increase needed capacity by 10%
Add 600 Btu/Hr for each person in the room if there are more than two people
If the unit is for a kitchen, increase the capacity by 4,000-6,000 Btu/Hr.
If the room size is too big for the air conditioner you have two possible choices. Either decrease the room size by shutting some doors or partitioning off an area of the room. Or, increase the BTU of the air conditioner for that room by installing a different air conditioner with a higher BTU rating.
Aug 02, 2009 | Heating & Cooling
Danby ALSO does not cool 3 days old
Take it back where you bought it. A 12,000 BTU unit should be more than enough for a 192 square foot room, so there is some problem with the unit.
Jul 10, 2009 | Danby Portable Air Conditioner
My LWHD1200FR AC Unit is not cooling during the
The unit may not be big enough. From the model number I am thinking you a/c is a 12000 btu. Which is usally enough for a large room. However if you have an open floor plan or a really large room you may need a bigger or second unit.
Jul 05, 2009 | LG LWHD1200FR Wall/Window Air Conditioner
Hot Upstairs
A good heating guy should be able to balance your dampers to increase the airflow upstairs. Keep in mind heat rises. 2nd floors are the hardest to cool. You may need to add more returns to pull the heat down the the evaporator so it can be cooled. If you are lucky you may be able to adjust your blower up to a higher speed. You may have to even add some more supply airs. Check with your local building inspector. He may be able to give you a list of contractors in your area that would be good for this type of problem. Good luck>>>
Apr 02, 2009 | DeLonghi Pinguino PACL90 Portable Air...
Air conditioner
If the air flow is restricted or partially blocked (dirty cooling fins, filter etc), ice will form inside becaue the air stays in ithe cooling coil or fils for a long period of time. Lack of freon will not cause Ice formation because there is not enough cooling power.
May 24, 2007 | Goldstar R1003 Air Conditioner
Dehumidify mode also cools
Some units do cool/dehumidify only im afraid why cant you let the unit dump its hot air into the room then it wont heat or cool the room?
Sep 03, 2006 | Danby DPAC9031 Silhouette 9,000 BTU...
Maytag NMPEB08F2A Air Conditioner Logo
159 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Marvin
Marvin
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
