Question about Lexmark C762 Laser Printer
83 itu maintanece
83 ITU Maintenance
You replace the ITU it has reached its end of life cycle.
Posted on Jan 30, 2009
Tengo un error en una impresora lexmark c762 error 83 mantenimiento util
Posted on May 19, 2009
  • 916 Answers
83 ITU Maintenance
What this message means:
The counter that tracks wear on the image transfer unit has reached its limit.
What you can do:
Press Go to continue printing.
If print quality is unacceptable, replace the image transfer unit.
Posted on Jan 22, 2009
Dimana letak bagian vertikal dari Sony KV-XJ29M50, atau apa tipe IC di bagian itu ?
halo
Output IC vertikal dari himpunan ini dapat terletak di A dewan itu sendiri. Ini adalah SMD [Permukaan Gunung Tipe] ic, mengacaukan ke heatsink meatus untuk memancarkan panas dari itu saat bekerja. OK
Jul 29, 2011 | Sony KV-XJ29M50 29" TV
Does compaq nx6310 have in built modem?
Hi!
Yes, it actually has a built-in modem, here is the specifications:
Max Transfer Rate 56 Kbps
Modem Fax / modem - MDC
Protocols & Specifications ITU V.21, Bell 212A, ITU V.22, ITU V.22bis, ITU V.29, ITU V.32, ITU V.32bis, ITU V.34, ITU V.17, ITU V.23, ITU V.27ter, ITU V.8bis, Bell 103J, ITU V.92, ITU T.30, ITU T.4, ITU V.250, ITU V.251, ITU V.80
Fax Compatibility G3
You can also check all hardware details about that laptop at: http://www.laptopdrivers.net/specs/hp_compaq_nx6310_laptop.htm
Hope this helps.
Apr 17, 2011 | HP Compaq nx6310 Notebook
100.01 Services ITU Error, Lexmark C782
From the Lemark Service manual
A 100.01 ITU error indicates that the printer did not detect the ITU belt home sensor. Before proceeding with this
service check, make sure that the Second Transfer Roll is correctly installed. After you reinstall the Second
Transfer Roll, check to see if a 100.01 ITU error is still displayed. If a 100.01 ITU error is still being displayed,
continue with this check.
The ITU has an optical sensor that watches for a piece of reflective tape on the inside of the image belt. This
tape is read every revolution of the belt. If a signal is not received from the belt sensor within a certain time
period, the printer posts an error due to the loss of signal. There are several causes for the loss of signal. First,
the belt has tracked too far to the front or rear of the printer. In this case, the belt is still turning, but the reflective
tape is no longer passing within view of the belt sensor. This is considered a belt tracking error and is initially
posted as a 100.02 ITU Error. The other causes of a signal loss could be a belt stall, meaning the belt is not
turning, or a true signal loss, which would be due to a bad sensor, broken cable, loose connection, or bad
system board. These other causes post as a 100.01 ITU Error.
To assist the printer in determining the cause of a signal loss, there is a buffer that records the belt position for
the last 50 revolutions. If the printer loses the belt signal, it refers to the buffer. If the buffer shows significant
mistracking before signal loss, it will post a 100.02 ITU Error. If the buffer shows that the belt has been tracking
in the center before signal loss, it posts a 100.01 ITU Error. Due to memory restrictions, the buffer is not saved
during POR. This means if a printer posts a 100.02 ITU Error, so the belt is tracked off, and the customer or
servicer turns off the printer to clear the error, when the printer starts up, it will still not see the belt signal and will
now post a 100.01 ITU Error because the buffer is empty. When servicing a printer for a 100.01 ITU Error, it is
important to view the error log. See "Display Log" on page 3-29. The error log can only be displayed at this
point. Do not try to print the log. Look for past occurrences of 100.01 ITU Errors preceded by a 100.02 ITU Error.
Apr 13, 2011 | Lexmark C772dn Laser Printer
Webcam kalau dibuka ada tulisan no camera divence
Jikalau "no camera device" makna nya driver your webcam anda belum install atau salah versi driver installed! Oleh sebab itu Operating Sistem tak dapat detect device itu.
Kalau nak minta tolong, beritahu, model webcam dan Operating Sistem yang terdapat dalam PC/Laptop anda.
Sekian & terima kasih untuk mengunakan Fixya.
Apr 04, 2011 | Computers & Internet
30 ITU MISSING
ITU is missing or defective. Try reinstalling the ITU. If this doesn't work you'll have to replace it. The ITU is the black "belt" at the bottom of the printer.
Oct 18, 2010 | Lexmark C752 Printer
STREAK ON ITU OF LEXMARK C782
The only thing that helps is replacing the ITU.
Jul 09, 2010 | Lexmark C782dn Laser Printer
Error Code 23.05 ITU Missing
ITU is missing or defective. Replace the ITU and the problem should be solved.
Gerrit Jan
Nov 04, 2009 | Lexmark C780dn Printer
COMPAQ NX9020
1 Gig.
General MPN: PG567EA#ABU
System Type: Notebook
Built-in Devices: Stereo speakers
Width: 32.9 cm
Depth: 27.2 cm
Height: 4.2 cm
Weight: 3.1 kg
Processor Processor: Intel Celeron M 320 / 1.3 GHz
Data Bus Speed: 400 MHz
Chipset Type: Intel 852GM
Cache memory Type: L2 Cache
Installed Size: 512 KB
Ram Installed Size: 256 MB / 1 GB (max)
Technology: DDR SDRAM - 266 MHz
Memory Specification Compliance: PC2700
Storage controller Type: IDE
Storage Hard Drive: 30 GB - 4200 rpm
Optical storage Type: DVD-ROM - integrated
Read Speed: 24x (CD) / 8x (DVD)
Display Display Type: 15" TFT
Max Resolution: 1024 x 768 ( XGA )
Widescreen Display: No
Video Graphics Processor / Vendor: Intel Extreme Graphics 2
Video Memory: Shared Video Memory (UMA)
Audio Audio Output: Sound card
Compliant Standards: AC '97
Input device(s) Type: Keyboard, touchpad
Telecom Modem: Fax / Modem
Max Transfer Rate: 56 Kbps
Protocols & Specifications: ITU V.21, Bell 212A, ITU V.22, ITU V.22bis, ITU V.29, ITU V.32, ITU V.32bis, ITU V.34, ITU V.17, ITU V.23, ITU V.27ter, ITU V.8bis, Bell 103J, ITU V.8, ITU T.30, ITU T.4, ITU V.250, ITU V.251, ITU V.80
Fax Compatibility: G3
Networking Networking: Network adapter
Data Link Protocol: Ethernet, Fast Ethernet
Compliant Standards: IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3x
Mar 17, 2008 | Computers & Internet
Lexmark C762 Laser Printer Logo
1,660 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
