Question about Kenwood Kr 9600 Filter Capacitor 10,000mfd 80v
Which circuit board is the kenwood kr 9600 filter capcitor 10,000mfd 80v located
3 Suggested Answers
  • 319 Answers
SOURCE: problem with playing my Kenwood KR-X1000
Unit apparently has problems. Check/replace batteries in remocom
Posted on Aug 14, 2008
dunnbiker
  • 8546 Answers
SOURCE: kenwood kr-v888d after "ON", through 3sec.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on May 18, 2011
Kenwood kr 5050 volume stuck on high cant change
These days the circuit of the volume control is controlled by an IC in modern amps. These can go faulty preventing adjustment of the sound by the volume control. The only cure is to find the IC and replace it. You can start in the area where the volume control is located. If it's not mounted direct on the PC board, follow the connections to the board. Hopefully the board might have writing on it to indicate the area where the faulty IC is.
Aug 04, 2015 | Kenwood Audio Players & Recorders
When i turn on my kenwood kr-v990d it powers up for about 2min then shuts down
It is possible that the amplifier had encountered a fault with a higher current drain which had triggered it to a protection fault condition. The fault can be with your output drivers. Please check for short on the outputs fitted for both the channels. Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise which can be a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board. Maybe the protect circuit by itself is shutting off due to a faulty bias or there is a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the amplifier comes out of the protect mode then check for short on the speakers.
Oct 23, 2011 | Kenwood KR-V990D Receiver
Can the Kenwood KR-4600 connect to an ipod?
Hi,yes you can connect Kenwood KR-4600 to an ipod.
Instruction..
You will need an coolken_9.jpgRCA cable .
Connect the RCA (red and black to the input of the Kenwood KR-4600...You have options of inputs to use..
Either input at the back of the Kenwood KR-4600,or tape A and tape B..which ever you wan to use..
After connecting the red and black RCA to Kenwood KR-4600, then connect the other jack end to the ipod, and go the front of the Kenwood KR-4600 to activate the input selection knob to the desired input being selected at the back of the Kenwood KR-4600..
And don't forget to turn on the volume of the Kenwood KR-4600 and also the iPod volume..
And after that your done..
Good luck to you..
Aug 10, 2011 | Kenwood Audio Players & Recorders
Loud pop then no picture
Hi
The power supply regulator board inside your TV is fauty. The 'pop' sound you heard will be due to capacitor breakege. In the power supply board, there are large filter capacitors, to smooh the rectifed AC voltage. If there is any rise in AC voltage, above the normal voltage capacity of the fulter capcitors, it will burst ofr, or get leaked with a 'pop' sound. You have to open your tV to view this. Look at the power regulator board, which can be easly located, as power chord goes direltly to it after a filter circuit. It will have three or more large bulky capacitors, and these are the main filter capacitors. Repairing this board must be done with care, as this is a dangerous board to touch because most of the components in this board will be live and touch it will be fatal. In most cases it will be best to replace the board as a card basis. OK
Jul 15, 2011 | Mitsubishi WD-65738 DLP TV
Kenwood kr-v6030 master volume wont go down
To zyclon3, I've got a KR-V6030 that the volume knob some how got broke and had to take the receiver apart and get the knob out and play with it with the remote untill I got control. but I have to becareful cause it will go full blast if I'm not carefull going down in volume have to be especialy carefull since theres no stop.
Mar 08, 2010 | Kenwood Audio Players & Recorders
Have a kenwood KR-V990D and can't seem to bring the volume up
kenwood has always showed negative numbers 00 is as high as it will go
Jan 06, 2008 | Kenwood KR-V990D Receiver
Problem with playing my Kenwood KR-X1000
Nov 19, 2007 | Kenwood KR-X1000
KR-X1000 Power Problems
Sorry, no freebies from what I see online. But, when you power up, does it play before it shuts down? This will help me formulate a better answer for you...accordianman
Oct 25, 2007 | Kenwood KR-X1000
Kenwood Kr 9600 Filter Capacitor 10,000mfd 80v Logo
269 people viewed this question
Top Kenwood Electronics - Others Experts
Are you a Kenwood Electronics - Other Expert? Answer questions, earn points and help others
