Question about Dell Inspiron 6000 Notebook
Trouble booting past the BIOS Screen
I'm have trouble fully booting on my dell inspiron 6000. Recently, the battery ran out and the computer, obviously died. However, when I went to start it again, it wouldn't fully boot. Basically it starts up gives me the dell booting screen with the BIOS wording on the bottom, finishes and goes black. I've run a system diagnosises by pressing the F2 key as well as the F12. I've alos tried pressing the F8 to start in safe mode. The F8 key thing failed, but I'm able to run the F2 and F12 for the diagnostics and everything seems to be alright. So, Where do I go from here?
  • verrillo_ser Jan 22, 2009
    Is that the main power battery? If so I left it out over night, leaving the laptop with zero power source. Everything else is seated properly
    done and done. but no difference.it just tells me that its an invalid configuration and that the time and date is not correct.Then it asks to chose f1 to continue and f2 to enter setup. I've done it both ways and no change. still black screen. Its almost like its frozen at that stage. The computer is running as normal
    Sergeant:
  • 367 Answers
Remove the cmos battery and unplug comptuer for about 15 to 20 minutes. install battery working battery. make sure you didn't knock any cables loose
Check ram is seated
Check video and audio cards are seated properly
Then try booting pc.
Posted on Jan 22, 2009
  • Rob Houg
    Rob Houg Jan 22, 2009
    The main battery as well as the cmos battery it is usually a small round (flat) battery that is on the motherboard of the laptop itself. Remove this battery for 20 minutes then install and install big battery then turn machine on
Com quitar password del bios dell inspiron 6000 service tag F4F8H91-595B
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-6000-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
May 25, 2011 | Dell Inspiron 6000 Notebook
Purchased a new Dell Inspiron 6000 (9 cell) battery
You just want to refresh battery from the BIOS. There problem will be solve
Mar 15, 2010 | Dell Inspiron 6000 Notebook
Won't Load
boot using the operating system disc. then use recovery console, perform chkdsk /p if it is done type exit then restart computer normally
Feb 20, 2010 | Dell Inspiron 6000 Notebook
When running diagnostic for Dell computer was given error code OF00:1A44. I ran the diagnostic becasue I was unable to get past the blue screen in Windows - error there is Unmountable_boot_volume.
Boot to the XP CD, Enter recovery console by pressing "R" at the 1st prompt, run the command CHKDSK /P and see if the system will boot normally after the command finishes running. If nothing changes, then the hard drive will need replacement
Jun 18, 2009 | Dell Inspiron 6000 Notebook
Screen on Dell Inspiron 6000 turned sideways. How
Power off the laptop.
Power it on and tap F2 at the Dell logo. check if the screen is sidways in the BIOS or not. If it looks normal in the BIOS restart the computer and go to control panel and uninstall the Video drivers. Restart the computer. It will boot up with basic drivers. Install the video drivers and the issue should be fixed.
If the display is side ways even in the BIOS try a BIOS update from support.dell.com and if you dont have an update reflash the BIOS with teh version availbale on the website.
Jun 18, 2009 | Dell Latitude D600 Notebook
Dell Inspiron 6000: No Boot Up after BIOS loads
You can download a small program called memtest 86 which is an ISO for creating a bootable cd that will test the ram. You can get it from: http://www.memtest86.com/download.html
Also the HD may be the problem even if the BIOS can see it. Pull the HD and try booting from the xp disk again.
Hope this helps
May 01, 2009 | Dell Inspiron 6000 Notebook
Bios post doesn't show at boot up
Try hitting F12 as soon as the computer starts to turn on. This should give you a Boot Selection Menu where you can choose which device to boot from.
To get into the bios, this machine requires you to hit F2 just as it starts to boot.
You do not need to rapidly press it, but do try several times until you get your menu.
Feb 10, 2009 | Dell Inspiron 6000 Notebook
Inspiron laptop Battery won't charge
Hi
Update laptop bios go dell.com check for update of your laptop model....
Thanks
Jul 10, 2008 | Dell Inspiron 6000 Notebook
Problems with Dell Inspiron 6000 Battery ? DELL Inspiron 6000 laptop battery is popular, why ?
You can also pick up the batteries less expensive than most computer places at batteries plus. And yes it sounds as though it is the batteries charge is getting low, especially if it runs fine when the battery is out and you have it plugged in.
Mar 13, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Notebook Logo
246 people viewed this question
Alun Cox
