Question about Radio Communications
G5rv lite installation instructions - Radio Communications
  • 3,287 Answers
A G5RV antenna is a popular ham antenna due to its cost, weight and ease of installation. The G5RV is a really a dipole type, that looks like a "T" with the top of the T as the main radiator consisting of a single conductor main radiator and the bottom of the "T" (also radiating on certain bands) consisting of a 2 conductor 450 - 600 ohm "ladder line" that terminates in a fitting that converts ladder line to a coaxial connector.
One of the most popular configurations is the inverted "V". Depending on the version of the antenna, the main radiator will be either 102, 92 or 51 feet long. The ladder line will be 32, 42 or 16 feet (respectively) in length and will require a coax feed length of 70, 70 or 40 feet minimum (again, respectively) to present the proper range of impedences to your manual or auto tuner (the G5RV REQUIRES an external tuner to present an acceptable SWR or impedence match to your transmitter on all bands).
The inverted V requires a mast as high as you can erect, located as close as centered between support sources (trees, buildings, etc.). Ideally, there should be enough room between the mast and the main radiator supports to allow the main radiators to be fully extended. Also, the ladder line should be able to hang straight down without being coiled on the ground at the base. This means you'd need a 32 ~ 42 foot mast at minimum.
The top of the mast will be needed to be fitted with an anchor or hook that will support the center insulator that provides strain relief, splits the ladder line and allows connection of the ladder line conductors to the single conductor main radiators.
Unroll the antenna on the ground. Connect the center insulator to the top section of the mast by the hook. Install "antenna lead stand offs" every 3, 4 or 5 feet. Secure the ladder line to the stand off to keep it from touching / wrapping around the mast.
Use UV resistance parachute cord to connect to and support the main radiator insulator, and pull the slack from the line, from a point as high off the ground as possible. Do the same to the other radiator, trying to match the height above the ground as the first radiator. Go back and forth between the two radiators (or have a helper - so each can be pulled slowly, and evenly together. Inspect the mast to be sure it is still straight. Loosen or tighten the radiator support lines as needed to allow the mast to stand straight.
Secure all lines, connect and run coax to the connector at end / bottom of the ladder line. and connect the opposite end to your antenna tuner connector labeled "ANT". Connect a short coax cable between the transmitter's "ANT" connector and the tuner's "XMIT" connector.
Set xmit power to 5 - 10 watts, transmit and operate the tuner - or set up your radio to use an external auto tuner. Tune for lowest SWR or reflected power. The internal auto tuner on many radios is only good for correcting up to a 3.0:1 mismatch or SWR. The G5RV will present mismatches far in excess of 3.0:1 on certain frequencies and bands.
Posted on Jan 15, 2013
How do I to open tripp-lite omni1000 LCD to change battery
Go to http://www.tripplite.com and enter model and search for battery installation instructions.
Feb 11, 2014 | Tripp Lite Tripplite Omniplus 1000 LCD UPS...
How do I install trimmer line?To a Homelite Lite 26vt trimmer. Can i download a manual?
The detailed instructions, plus diagrams are in your manual. You can go here to view it. You will need Adobe Reader installed on your computer. This is the closest I could get to your model.
http://lawnandgarden.manualsonline.com/mdownloads/7d2e081d-9dc3-4ad6-b637-f6f946e2283e.pdf
Feb 13, 2011 | Homelite Mighty Lite Lawn Trimmer
Where can I find the wiring diagram for truck-lite light assembly for myers plow to a ford bronco?
Truck-Lite has installation instructions on their website at www.truck-lite.com. Go to their catalog section and search for the part number 80800, the product will have a downloadable installation instruction available. Or, call Truck-Lite Technical Support at 888-562-5012.
Jan 06, 2011 | Ford Bronco Cars & Trucks
Nintendo ds lite
It's not easy at all. My company does repairs on PSP, XBox 360, PS3, Wii, and PS2. But we don't touch DS Lites. The following company will do it for you at a reasonable cost:
http://www.consoledude.com
They do all of our DS Lite repairs!
Also make sure you get an OFFICIAL Nintendo shell case. Some of the aftermarket ones don't fit properly. The following website sells the shells:
http://store.richspsxparts.com/newcoornidsl.html
Apr 14, 2010 | Nintendo DS Lite Console
External cd-rw with no instructions may be missing a cord?
You need the USB cable to use it. Go to a computer store, show them the drive and tell them you need the cable
Nov 05, 2009 | Lite On Lite-On: Lite-On 52X32X52 External...
Games on R4 card have stopped playing on my ds lite
Ah yes, please reformat the card and install moonshell; system cirrectly according to instructions.
yoou might want to back up you nds files first to PC.
I recommend installing latest moonshell 1.18.
May 03, 2009 | Nintendo DS Lite Console
Icom 756PRO2
What kind of antenna tuner do you use? (automatic or manual)
Personally I use the LDG AT-7000 and a G5RV. I have absolutely no problems on any frequency.
May 23, 2008 | Radio Communications
Radio Communications Logo
230 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
