Whirlpool washingmachine aweo 9002 was/and is my problem.
  • Washing Mach... Master
  • 17,129 Answers
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Posted on Jan 12, 2013
Lost my user manual for my washing machine model Whirlpool 6100
You can down load an electronic copy at http://www.washingmachine-manual.com/whirlpool-awod-6100.html in a .pdf format. Save it to your computer if you do not require a full printed copy. Once saved, you can print select pages whenever needed.
Oct 14, 2014 | Washing Machines
Hello, I have WHIRLPOOL washing mashine model AWE 2214. Yesterday during squeezing, the masine stoped without noise, no indication buttons.I cheked everything, but the mashine no start. Please, help me!...
Go to www.washingmachine-manual.com/whirlpool-awe-2214.html for the handbook. Make a cup of coffee and have a read up. If that fails to help then its an engineer I'm afraid.
If you have a good diy friend have them check the belt drive if it has one? Be careful of electricity and water, they don't mix.
Jul 21, 2014 | Whirlpool Washing Machines
No key for washer coinbox
Order and new one call Whirlpool 18002531301
Feb 12, 2014 | Whirlpool duet Washing Machines
Where do I find the model number of my Whirlpool washingmachine?
There are several places to look. One is on top of console in the back. Open the lid and look at the back lip. Down near the bottom on front panel.
Jun 17, 2010 | Whirlpool GSW9559LW Top Load Washer
Washingmachine tub spins during the wash cycle
If it's a top loader it sounds like the spin pall on the transmission is stuck, which would mean new transmision
Aug 06, 2009 | Whirlpool Washing Machines
How do you get the top console of whirlpool washingmachine model # LSR8233EQ1
behind the console ,on the right and left ends thres a recess with 1 phillips head screw ,,losen dont take out then flip console back
Dec 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Not spin
check the brushes on the motor it sounds like they need replaced
Dec 18, 2007 | Whirlpool LHW0050PQ Front Load Washer
Karen, start by removing the cold water hose to the inlet valve in back. It will have a screen in the inlet valve. Make sure the screen is clear of sand and debris. Start there and post back. Catriver.
Apr 22, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
