Question about Koss C928 System
Need image showing how to connect kossc928home theater to cable tv
SLOW UNFOCUSING AND BLURY PICTURES ON MY HISENSE TV AND LG HOME THEATER
Single speed between new tv and old player may be causing latency. Double check specs on the newest component and make sure they are upward compatible.
Dec 30, 2014 | LG Audio Players & Recorders
Help
Depends on what kind of connection you are using,
Try unplugging power cord from all equipment, also unplug audio and video cables, wait ten or fifteen minutes, cable everything back together and restart.
Let me also know what cables you are using to connect the TV.
Sep 15, 2008 | Protron PHT-300X System
How do I hook up my new HT-X50 home theater system to my Verizon HD "Motorola" cable box that my sony wega hd tv is hooked up to, so I can get tv shows and dvds to work with my home theater...
Hi evilfan,
If I may add to the postings of Ekse and TampaNative......
Depending on what available cables and connectors that you may have the basic idea is from the cable company in to your Motorola receiver then to your Samsung HT-X50 then to the Sony Wega as below image shows. All other additional devices such as another DVD player or an iPod Nano with Video Dock or anything else would have to be connected to the Samsung.
All external devices would have to be plug in the the different INPUTs as you may decide which is to which. What is important to remember is that everything goes through the Samsung be it incoming or outputs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 18, 2008 | Televison & Video
WHY IMAGE BECOMES GREEN WHEN CONNECTED ON CABLE TV ?
If it's on HDMI input, then the wrong setting of RGB/YCrCb
Sep 06, 2014 | Panasonic PT-AE8000U Full HD 3D Home...
How do you hook up multiple av cables
http://images.philips.com/is/image/PhilipsConsumer/MX6050D_37-IMS-global?wid=225&hei=225&$jpglarge$
There are several options for these hook-up depending on your TV outputs. So I refer you to the owners manual for the Phillips system. Read through and study the section which shows connections. I think it's page 18.
May 31, 2014 | Philips MX6050D System
I just bought Panasonic SC-PT480P-K DVD home theater and TC-P46ST30 TV. I connect DVD HDMI output to TV HDMI input port #1. But when I try to play DVD, I just got sound out to the home theater speakers...
Let us take things step by step.
1) If you have an AV cable ( Yellow /Red/White ) try connecting the DVD players composite out (Y/R/W) to the TV's composite in. Select AV input instead of HDMI on the TV and see if you are getting an image. This is to confirm that the DVD video circuit is OK.
2) If all is OK in step one you can try buying a good HDMI v1.3 cable. You do not need a v1.4 cable which is only good for 3D bluray players.
Revert back for more.
Mar 07, 2011 | Panasonic SCPT480 Theater System
How to hook up my TV,home theater system, and digital receiver
To guide you on the exact cabling, I need to know more details like the model of the home theater and the TV model ..
However, to keep the things very simple; All you need to know is the direction of the signal. Now, we want the sound signal to travel "OUT" from the TV and travel "IN" to your Home theater home theater so that the signal gets amplified and is heard through Speakers of Home theater system so the cables run from
"Audio OUT" of TV ---------> "Audio IN" of Home Theater
All the cables are color coded.
Now Similarly.. You want the signal to travel OUT of your camera and IN to the TV so that you can see the larger image and louder sound .. so.. connect the cable that you received along with the camera into AV/TV "OUT" on camera to corresponding "INPUT" color coded ports on TV.
Please let me know if that was too complex to understand and I would try to simplify that further.
Regards,
Srinivas.
Apr 03, 2009 | Canon PowerShot A430 Digital Camera
It does not play on tv screen
DID you connect a phono cable to the tv then to your systems input?
CABLE GUY.
Feb 24, 2009 | Panasonic Home Theater System System
How to connect Panasonic TV, DVD Recorder & Home Theater together
missing one connection connect stereo rca jacks behind tv labelled audio out then connect to any available input in home theater receiver i dont think you need the optic cable connected to anything
Jan 27, 2009 | Panasonic Home Theater System System
Samsung LN37A550P3F shadow image
It seems new TV.
But that kind of problem is related LCD panel.
If you can replace LCD inverter first.
then not working need to replce LCD panel.
Jul 22, 2008 | Samsung HP-P3761 37 in. HD-Ready Plasma...
Koss C928 System Logo
24 people viewed this question
Top Koss Audio Players & Recorders Experts
Steven Wander
Steven Wander
Carlos L. Burgos
Carlos L. Burgos
Michael Galve
Michael Galve
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
