Question about Honeywell HE220A1019 Whole House Humidifier Humidifier
No increase in humidity after installing whole house humidifier
I recently installed a Honeywell HE360A1027, before I installed it the house was at 16% humidity and 3 days later still 16% I placed the humidy sensor over a register and no increase, I know the meter works by breathing on it. I installed it acording to instructions fan is turning, water is flowing through the filter. I even pulled the cover off to make sure the filter is geting wet and watched the fan spin. I would assume that if I know the humidifier is runnning and I put my humidity sensor right on the register there should be some increase. Not sure what could be wrong.
  • del_01 Feb 24, 2009
    No increase in humidity for me either. Tested that the humidstat is
    calling for humidity, water flow is good, installed on the hot air vent
    side common area (before my zone dampers). We have good well water,
    but it is cold, could this be part of the problem?
    Any help would be great...
    Novelist:
  • 88 Answers
Have you checked the damper ? is the motor running the right direction ? have you increased the water supply to it ? you need to be sure that it is coming on only when you have a call for heat, normally your humidistat should be installed near the return, or on the return duct, for proper sensing, you could try holding a pan of steaming water, placing the stat above it, not to close, to see if the stat shuts off the hum, a little trick, that way you will know if the stat works ok, hope these helped, thanks for the question, mr.grzz
Posted on Jan 22, 2009
Can honeywell 360 humidifier be installed on return plenum
Yes. Make sure to connect to HOT water line for better performance.
Nov 21, 2013 | Honeywell HE360A1027 Whole House...
Water runs continuosly on my Honeywell Envirocaire Elite system, no matter what setting I have the automatic humidity control set at, should I try replacing the Kip valve #3703?
Try to disconnect the main power to the unit and if the water valve is still open and water is running, you have a bad valve (the valve stuck open). Tap on the valve body it may help on sticking it, if not replace it.
Feb 17, 2013 | Honeywell HE360A1027 Whole House...
How long should it take a licensed plummer to install this unit on a new furnace?
Hello, typically it should take about a hour and a half to install a humidifer, usually takes me an hour and a half to two hours to install one. Anything over two hours is too long.
Feb 24, 2011 | Honeywell HE360A1027 Whole House...
How long should it take a licensed plumber to install a new HE360A1027 on a new forced hot air propane furnace?
Hello, typically it should take about a hour and a half to install a humidifer, usually takes me an hour and a half to two hours to install one. Anything over two hours is two long.
Do I have to put water in my honeywell whole home humidifier?
Your humidifier has a water line ran to it from the installation look for a little 1/4" tube it should be on the bottom of your humidifier trace it back to its tie in point and see if it is turned on it will look like a little T handle turn it counter clockwise till it stops and water will be on.controlltech_10.jpg
Dec 06, 2010 | Honeywell HE360A1027 Whole House...
Water not flowing into HE360A
If you used the plastic tubing to the humidifier(I recomend copper) there should have been a little brass tube with a flare on it. This goes in the plastic tubing to grip the the sleeve better. See if this helps
Tinner
Sunsetmech
Dec 14, 2009 | Honeywell HE360A1027 Whole House...
Honeywell Envirocaire Whole House humidifier not elevating humdity in home. Installed sev. years ago by HVAC contractor. Can't get the humid. above 30% no matter how high I turn it up. It is fed by hot...
This may not be a solution, but a couple things you might want to look at. First, the humidifier may not be big enough for your house - just because a contractor installed it doesn't mean he sized it right. Second, humidity may only be 30% locally by the humidistat, but higher in other parts of the house - it depends where the humidistat is located. Finally, look at your hot water line - I'm surprised he ran it off hot water and not cold - seems like a waste of energy to me, but the feed line may be clogged by sediment from the water heater
Dec 05, 2008 | Honeywell HE360A1027 Whole House...
Humidity not going up
I have a similar problem with mine too. I am interested to see if anyone can diagnose this problem
Nov 30, 2007 | Honeywell HE360A1027 Whole House...
Honeywell HE220A1019 Whole House Humidifier Humidifier Logo
416 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Ken Thomas
Soulvisitor
Soulvisitor
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
