Question about GE Profile JTP56 Electric Double Oven
Replacing the touch control panel on a GE Profile oven
Is it easy to replace the touch control panel? It appears to me you remove all the screws. Pull panel out unplug it and reverse the procedure. A new panel was ordered because of an FO messsage.
Thank you
  • 111 Answers
SOURCE: GE Profile Performance Spectra Range error code F0
F0 - F1 - F7 Stuck keypad may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Posted on Jun 20, 2009
rickzilla
  • 706 Answers
SOURCE: GE Profile double Built-In Oven error Code
According to the GE User manual... any F# error code means you have a function error and they suggest you press the CLEAR/OFF pad and allow the oven to cool for one hour. Then put the oven back into operation. If the function code repeats, disconnect all power from th eoven for at least 30 seconds and then reconnect it.. If it still comes back.. call for service.. however it has been my observation that F0 is usually a shorted off key on the keypad. Hope this helps..
Posted on Sep 22, 2008
  • 3 Answers
SOURCE: ge profile oven loc
hey - I figured it out! hold down the 9 and 0 at the same time for 3 seconds! or it might be another combination depending on your oven - it is probably the 2 keys that the messge is under
Yay!
Island2
Posted on Oct 03, 2008
Sea Breeze
  • 4654 Answers
SOURCE: GE Profile JT952 Touch Pad Button Issue
Try this link
http://www.fixya.com/howto/h155060-dreaded_f7_error
Posted on Mar 28, 2009
mgprice
  • 744 Answers
SOURCE: Is it easy to replace the keypanel of the GE
Hello, The simple answer is yes it's not too hard...Normally you have a couple of screw located underneath the control panel. In most mordern ovens today they just consist of 2 components, the EOC (Electronic oven control) and the touch pad which basically cosists of everything you see(the whole panel). If you are replacing the touchpad..remove screws holding old panel in...pull wire harness from control board (dont worry where they go because the will only fit in one place) remove tape from EOC and relocate the control board to the new touchpad panel...reattach wire harness and tape in the new touchpad panel and hook back on oven ..screws in and your good to go. if replacing the control board (EOC) drop touch pad panel from oven and pull wires install new control then reassemble..easy!. One thing i would check though before purchasing the part, check to see it is the touchpad and not the control board...Here is how to do it...shut breaker off...pull out control panel...remove ribbon for key pad from EOC the re install panel..go switch breaker back on. leave for 24 hours..if within the 24 hours the error messages come back it's the EOC that is bad, if the error messages do not come back then you can be sure it's the touchpad. I would check this before buying the part since they are expencive and offten non returnable. Good Luck!! If you have any other questions or concerns please feel free to comment again. Thanks for using Fixya!! Mike
Posted on Jul 24, 2009
How does one replace the oven temp sensor?
Pretty easy, usually located at rear top of oven, one screw holds bracket, so remove, then you will see wire, pull it out to access connector, replace with new one, plug back in and replace bracket. My GE was easy fix and sensors are low cost.
FREE-PPV.com
Jun 03, 2015 | GE Profile 30" Built-In Single Electric...
How to remove the touchpad on ge profile stove, I have f7 code
On most GE ovens you open the door and across the bottom of the control panel there are 3 1/4 inch screws, one in the center and 2 on either end going straight up into the console. remove the screws and slide the control panel up then out to you. Thats how you do it.
Aug 28, 2011 | GE Profile JTP18 Electric Single Oven
The glass top cracked, can I replace it?
Hello. Yes you can replace it. You need to remove the control assy. Open the oven door, at the bottom of the control assy there are 5 screws, remove those. Now pull off the knobs and unscrew the retaining rings around the switch shafts, should be 3 plastic and one brass. Remove the panel and set aside. Remove the screws holding the metal plate on, should be 4 black 1/4 inch screws. Once those screws are removed, pull the whole panel out and let hang down. This will have all your switches and erc control on it. Now there are 4 more screws that hold the front of the cooktop, unscrew those, disconnect the 2 wire harnesses at the connectors, pull the cooktop twards you and up and it will come right off. FYI some models have 2 screws in the back to hold the cooktop to the rear, but some don't. Now just reverse directions and your ready to go. Joe
Aug 18, 2010 | GE Profile JTP18 Electric Single Oven
Getting F7 code on a ge profile performance oven , oven light will not turn off and control panel will not respone.....beeps when I push CLEAR OFF button.
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Try gliding your finger flat across the keypad rapidly and see if you can unstick the key / touch pad. Usually once this code appears it will repeat.
On self cleaning ovens this is the service check:
Thanks for using FixYa!
Kelly
Mar 09, 2010 | GE Profile JTP56 Electric Double Oven
F7 Error on GE Profile electric oven. No response from keypad.
The F7 error code on your oven indicates the touch pad has failed. To repair it, you will need to replace the touch pad which is listed as a control panel.
If you do the repair yourself, disconnect the power to the oven. Take the 3 screws out above the door that holds the control panel on to the oven. Pull the control panel out at the bottom and lift it up, then pull out the top and drop it down so you can see the back side of the control panel, and you will see a ribbon connector going from the touch pad to the electronic oven control (ERC).
There is a latch holding the ribbon connector to the ERC, raise the latch to release and pull the ribbon out of the ERC.
Replace the part and reverse these instructions to replace the control panel.
Hope this helps.
Thanks for using Fixya.
Dec 15, 2009 | GE Ovens
Jul 24, 2009 | GE Profile JKP56 Electric Double Oven
I have a GE Profile built in oven and the F7 display with the beeping sound. Clear or cancel will not work What do I do
Well, F7 error code occures due to
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Good Luck!!
Jun 28, 2009 | GE JGRP17 Gas Single Oven
F7 error
Good Luck!!
Have a nice Day!!
May 03, 2009 | GE Profile JTP18 Electric Single Oven
My GE profile oven is giving me a code f7 and I can't clear it.  What does this mean?
Best of luck!!
Thanks
Dec 02, 2008 | GE Profile JTP56 Electric Double Oven
GE Profile Oven Model JKP13G0V1BB
f3 is a bad oven sensor, two screws will remove it in the upper left or right hand side of inner cavity.thin metal shaft protuding maybe 3inches or so.
Mar 23, 2008 | GE Profile JTP18 Electric Single Oven
GE Profile JTP56 Electric Double Oven Logo
650 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
