Question about CIPHERLAB 8000 Series Handheld Mobile Computer
Screen on cipherlab 8000 is blank
I turned on the scanner for the first time today. The dipaly came on and I was able to view the options on it. I put it down for a few minutes, came back to it and now I have a blank screen. The buttons are making sounds and it i hit the right button, the infared light will come on. Very frustrated!!! and I can't seem to get the driver to download properly so my computer will recognize the device.
5 Suggested Answers
  • 106 Answers
SOURCE: CIPHERLAB 1000 (serial ) Driver for WinXP
you dont`t have a driver for serial comm.open hyper terminal on com port where is the scaner.read a code and you wilkl see the numbers on the screen.If you want to work with some windows programs change that barcode for usb or ps/2 variant.
Posted on Feb 05, 2008
SOURCE: My cipherlab 8000 has the
Hi, there are two possibilities, One the main battery has gone bad, this is common, the only way to tell is to replace it. Two, on the main board, there is sometimes a small battery, this battery can sometimes leak, etc, or have gone bad. Replacement, if there is one, usually fixes it.
Posted on Dec 14, 2010
  • 52 Answers
SOURCE: Faut-il installer un driver avant
FIXYA ADMIN CHECK. Q APPROVED.
Posted on Jan 15, 2011
Mustgo
  • 2359 Answers
SOURCE: i have a Cipherlab scanner 8001, when i connect it
OK,you indicated COM1 serial port is working on the a Cipher scanner 711.
Please check the communication setting on the Cipher scanner 711.
The most popular setting are
AUTO BAUD RATE
or
9600 bps 8 bits N for no parity check and 1 for check bit.
Short for as
9600 8 N 1
Check the setting on the Cipher scanner 711 communication speed and make set the Cipherlab scanner 8001 to the same rate.
MAKE SURE YOU RE-BOOT the Cipherlab scanner 8001 before re-try.
Please keep me up to date on the fix via email.
Posted on Jan 30, 2011
My CipherLab 8000 not scan the barcode.laser are open but can't scan.Could you please find out the solution.Thank you.
May be some one doing by mistake disable for all types of bar code ( not enabled ) or all sympologies.
Apr 25, 2016 | CIPHERLAB 8000 Series Handheld Mobile...
How do I insert comma into the scanned data of a cipherlab 8000?
If you using Forge, you could chose between comma or dot for decimal inputs in the latest versions of Forge.
Earlier just a dot were available.
May 30, 2014 | CIPHERLAB 8000 Series Handheld Mobile...
How do I get the craddle to turn on
It depend of model of your cradle:
If cradle is without charge capability (suits CPT-8000), it get power from USB for internal logic and irda.
Cradles with charging capability ( two charging pin in cradle socket) need a powersupply to power both the charging of CTP-8001 and the internal logic/irda.
The driver need to be installed before connect the cradle to computers USB-port.
Mar 03, 2014 | CIPHERLAB 8000 Series Handheld Mobile...
Cipherlab cl8200 timeout error? when exporting to hand held?
9f76079d-6fa0-4db9-9587-a2e27f8ce81a.jpg in the lookup section . select the following
that should solve the timeout problem
Sep 19, 2013 | CIPHERLAB 8000 Series Handheld Mobile...
I have a Cipherlab scanner 8001, when i connect it to a linux computer, it doesnt download it gives me a Time out error, but when i connect a Cipher scanner 711 to the same COM port it works. Please advice...
AUTO BAUD RATE
or
Short for as
9600 8 N 1
Jan 30, 2011 | CIPHERLAB 8000 Series Handheld Mobile...
Hello! I have a problem when programing the CipherLab 8001-C Application Program (AG8000N.exe). The download start (terminal bip) and after 3-4 sec show "Download Complete" but the terminal show the...
Cipherlab has technical support available - I'd recommend getting in touch with them. The Cipherlab global site is: http://www.cipherlab.com/default.asp - you can choose your region, then support or the contact link.
Oct 19, 2010 | CIPHERLAB 8000 Series Handheld Mobile...
Jan 15, 2008 | CIPHERLAB 1000 Handheld Barcode Scanner
CIPHERLAB 8000 Series Handheld Mobile Computer Logo
117 people viewed this question
Top CIPHERLAB Computers & Internet Experts
David Payne
David Payne
Are you a CIPHERLAB Computer and Internet Expert? Answer questions, earn points and help others
