Question about Car Audio & Video
I HAVE A 1991 JEEP WRANGLER .WONT START JUST TURNS OVER NO SPARK IN DISTRIBUTOR OR COIL . HAVE REPLACED COMPUTER,STARTER RELY, AUTO SHUTDOWN RELY, DISTRIBUTOR ,COIL, WIRE AND PLUGS,CRANK SENSOR THANKS FOR YOUR HELP .
    Problem Solver:
  • 7 Answers
On this Jeep there is a mo dual box on the fire wall or inter fender which makes the spark replace this also another type has small one on the distributor
Posted on Jan 22, 2009
95 wrangler will not turn off
The Auto-Shutdown Relay: - Jeep Wrangler Forum
www.wranglerforum.com/f218/the-auto-shutdown-relay-437697.html
Dec 15, 2013 - 12 posts - ‎4 authors
2) Fuel pump won't shut off the instant the battery cable is ... 1991 Jeep YJ 2.5L Ax-5 Fuel Pump Not Priming OR Running Continuously Brand new JK died while driving. Now won't start.
May 17, 2015
Fairly easy kill switch: write up
May 7, 2012
Jeep won't start, battery/starter good
Mar 29, 2012
Jeep wont turn off
Dec 7, 2011
More results from www.wranglerforum.com
Nov 24, 2015 | Crown Jeep Wrangler yj 95 94 93 92 91 90...
It cranks but wont start. replaced starter, coil, spark wires and plugs. crankshaft position sensor, distributor and cap. still wont turn over. fuel pump turns on fine, and there is pressure at the...
the ignition module probly bad-replaces points and located in distributer area--batt must also read 12.6v and alternator must be healthy--fuses may not all be good--take a light tester to um--make sure inline safety fuse on the batt line is workn
Oct 10, 2013 | 1991 Jeep Wrangler
1999 jeep wrangler problems
Could also be a fuse or relay problem.
You'll need to find out if the coil has voltage and if the pick-up stator in the distributor is sending a signal to the computer.
Might want to check the computer for trouble codes too.
Jul 08, 2012 | 1995 Jeep Wrangler
Jeep wont start.Have replaced ecu,coil,crankshaft sensor and wiring harness.Still no power to coil i have 1991 jeep wrangler 2.5 manual 4x4
Check the wiring going to the coil. If you installed an alarm on that vehicle disconnect the main power wire to the alarm to disable the ignition kill circuit. Locate the ignition relay located on the drivers side fender wall or in the power distribution box under the hood and test it. finally, there is a fuse on the interior fuse panel that will give you this condition. I do not have the exact location so check all fuses in the panel and replace any blown fuses.
Dec 08, 2011 | 1991 Jeep Wrangler
1988 Jeep Wrangler starting problems. I replaced the ignition module, spark plug wires, coil, distributor module, and my jeep will not start. It gets fuel, turns over, but still not starting. It is a 1988...
you are saying it is getting spark, and fuel, right? If it is getting spark, and fuel in to the throttle body, check compression-make sure the Mass Air Flow sensor is plugged in, and double check your spark-you say you replaced all those ignition items, but do not say that you have spark.
Jul 01, 2011 | 1988 Jeep Wrangler
I have a 94 jeep wrangler 4.0L and it wont start. I have changed the coil ecu and auto shutdown relay. The coil receives the correct voltage and has a good ground but no spark from the coil. Any ideas?
Two other thing's control the spark, the pick up coil assembly, sit in the distributor or your crankshaft sensor, sit on top of the transmission over by the driver side, held on with a 10mm bolt.
Jul 02, 2010 | Cars & Trucks
91 jeep yj wont start
check your coil, plugs, wires, basically your entire ignition system - test a plug wire by sticking a new (known to spark) sparkplug onto the end of the (known to work) wire and see if there is spark, if not, change out your coil and test again - if neither, check the timing of your distributor
Jan 28, 2010 | 1991 Jeep Wrangler
1991 jeep wont start
Did you replace the coil because it wouldn't start before? If it ran before, there must be a mis-connection somewhere. I assume by your stating that 'it turns but will not crank', to mean that the engine will crank over with the starter but won't start and run. True?
Jun 29, 2009 | 1991 Jeep Wrangler
1991 JEEP WRANGLER WONT START
Take the distributor cap have someone crank the car and look if rotor turns, look at rotor conditions, I am sure that you have replaced it, hot wire from positive on the battery to positive on the coil, if car starts after you have a problem on the key, Is it fuel getting to the injectors? after You replaced so many things,if your rotor is not turning when You crank the engine, your timing chain must be defective or timing gear,
Jan 21, 2009 | 2005 Jeep Wrangler
Car Audio & Video Logo
130 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
