Question about Brother HL-2040 Laser Printer
Printer hey much thanks for the help, however, the problem is, is that the installation seemed to have worked perfectly on my computer, yet on my brothers computer it didnt. i've tried installing the printer manually on his computer but it doesn't seem to work. also, i have restarted the computer on numerous occasions after installing the printer yet it still doesnt appear in "printers and faxes" any solutions?
  • 944 Answers
Which operating system do your and your brother's printer use? Are they the same machine, or are they widely different? are they networked? If you just start your brother's computer without the printer installed, then plug the printer into it and turn on, what screen message if any do you get? :)
Posted on Jul 05, 2007
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
I would like to be able to use the scanner on my Dell 942 All-in-one printer, but the Dell All-in-one center has disappeared and I can't seem to get that to work. I have an idea it has something to do...
Hey!
You can download the software/driver from here. It's recommended to download and install all the 3.
Prior the installation, COMPLETELY remove ALL Dell software (related to the printer, through Programs and Features, then restart your computer. Afterwards, install the downloaded software.
Good luck,
Pelu.
Apr 23, 2010 | Dell 942 All-In-One InkJet Printer
How to print on disc?
I'm embarrassed. I forgot to load the printer software into my new MacBook Pro computer. I'm sure that will fix the problem. Meanwhile, I used a felt-tip pen. Hey, it works! Just because something is technically possible does not mean it must be done that way, especially when you're in a rush.
The HP tutorial was only marginally helpful. It did not mention how to do it on a Mac. Yes, I do have the Mac software disc.
Thanks for replying. Someday I'll get the hang of this. I'm a great-grandmother; most women my age don't even know how to turn on a computer!
By the way, I really like my HP Photosmart D5460 printer. It's perfect for my purposes.
Marty Dover
Dec 29, 2009 | HP Photosmart D5460 InkJet Printer
A940 printer. Diagnostic page looks perfect.
Seems to me a software problem.
Try uninstalling & re-installing the printer drivers & see if this helps.
Dec 19, 2009 | Dell A940 All-In-One InkJet Printer
Drivers for Lexmark x5470 disapear after the laptop is turned on.
Hey,
Fully uninstall the lexmark from your computer, everything, delete the printer from printers and faxes and make sure there is no trace of the printer on the computer.
Then get the files you downloaded and install the printer again.
Everything should work normally.
Thanks,
Ekse
Feb 10, 2009 | Lexmark X5470 All-In-One InkJet Printer
INSTALLATION
If you have Vista then there's no HP software available. But the drivers are already built in so its plug and play.
Software for xp you can download here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&docname=c00909927&rule=13140&product=90809&
Sep 01, 2008 | HP PSC 2175 All-In-One InkJet Printer
INSTALLATION
plz download the drivers from the manufacture website
Aug 13, 2008 | HP PSC 2175 All-In-One InkJet Printer
Left cartridge
Thank you so much for your reply. I have the problem solved. I got one of my old cartridges (from another lexmark computer) and installed it ! It is not the one called for but hey, it works. Thanks again.
Bobbie
May 21, 2008 | Lexmark X5470 All-In-One InkJet Printer
Touchpad problem =[
the only possible reason that i can think of is that ur AC adapter is not the correct adapter for ur computer, if its not the correct charger contact dell.com and u can get the original charger for you laptop for under 60 dollars.
Feb 11, 2008 | Dell Inspiron 6400 Notebook
Recurring error
This answer was almost exactly correct:
>hey guys, for the "printer mispick" problem, try to remove the >toner and look IF there's any paper jam inside,because this >solved my problem,..
>=open toner door
>=remove the toner
>=look carefully IF there's any paper stuck between roller
>=CAUTION - carefully and gently remove the paper if so, as it >will be a nightmare if half tear off and the half end will be more >difficult to remove,...
The only thing I did differently, that worked like a charm, was to =open the door on the other side of the machine, and
=swing down the two green levers (one on each side); this released the roller tension and removal of the paper was easy.
=Once the paper has been gently removed, put back up the two green levers, and
=close everything up, re-installing the toner cartridge as you do.
Nov 16, 2007 | HP LaserJet 3330 All-In-One Printer
Reads the image, but doesn't print
that could be software problem or virus  if you are sure that the printer is full ink make sure that the printer driver is ok i mean you can go to start - control banel and choose printers and make sure there is the printer driver  if that ok try to reinstall the windows from windows recovery but backup your data and your photos first in dvd or cd's because you will lose all information in your compueter after you install the windows install the printer driver and the computer componant drivers
don't forget to rate me thank you i hope you find this solution helpful thank you
Oct 16, 2007 | HP PSC 1315 All-In-One InkJet Printer
Brother HL-2040 Laser Printer Logo
21 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
