Question about Directed Electronics DV2602 Car DVD Player
My dvd player wont power up in my 2004 suburban
I already checked the fuses under the hood and they are good.
No power to fuse box under dash. 94 lincoln town car
Better take the dash back apart , you didn't connect something , something came apart . Your answer is behind the dash .
Jan 24, 2017 | Lincoln Town Car Cars & Trucks
2004 escalade o power at code reader pport
Common problem.Most likely a blown fuse.Whenever I do an emissions test on an Escalade or Suburban with this problem I always check the fuses.Ten out of ten times that is the problem.This fuse also powers the cig lighter/power ports.If it blows again check the outlets.Especially center console one.A lot of times a coin is dropped into it and shorts out the port.Get a test light and with key on check all the fuses.Should be located in the engine compartment on the drivers side.To check fuses connect the test light to a good ground and then touch the lead to each side of the fuse.If only one side lights up then that is the bad fuse
Dec 14, 2014 | Cars & Trucks
DVD player dont work
The fuse for this is in the block under the hood. In the lower right hand corner a blue 15 amp fuse marked "info" . (check under the lid of the fuse box)
Jan 25, 2014 | 2004 Chevrolet Silverado 1500 Crew Cab
2004 suburban headlight wont come on
check your fuse,if your fuse is good check your connections
Mar 22, 2013 | 2004 Chevrolet Suburban
No tail lights on 04 suburan
Get a test light/ fuse tester and check every single fuse you have (including the ones under the hood). You're on the right track. It's very, very likely to be a fuse somewhere, if you've verified every one of your bulbs are good.
Sep 02, 2012 | 2004 Chevrolet Suburban
Where are fuse blocks on a 2004 suburan
I've got a 2003 Suburban that has two fuse panels, one inside under the steering wheel and another under the hood, drivers side behind main battery. All lighting fuses are under the hood, Plastic cover with battery symbol pulls up to remove, should be a panel schedule inside the cover. The tail light fuses are in upper left section labeled RR Park and LR Park.
Wipers quite working on my 95 wrangler fuses look good what else can it be?
Bad wires connections, Multiswitch go to bad or finally wiper motor.
Apr 27, 2011 | Jeep Wrangler Cars & Trucks
Heater is blowing cold
First check all your fuses if you haven't already, the ones under dash and the ones under hood, if they are all good it is more than likely your heater core, if you need instructions on how to replace this part let me know and I will send you the info!
Jan 13, 2011 | 2002 Lincoln LS
All blinkers not working as well as hazard lights. I checked all applicable fuses and they were fine
now that the fuses are eliminated you need to check the flasher relay which is located under the hood. there is also a secondary relay located on the fuse panel you already inspected. if neither of these fixes it then it is likely that the switch may have gone out. good luck.
Dec 28, 2010 | 2006 Ford F 350 Super Duty
Turn key and nothing happens
I am assuming you checked your battery already. Go under your hood to the fuse panel, Pull out the IOD fuse for about 10 minutes and replace. Try starting your car after that. If that doesnt help you may need to check your distributor or power coil, If thats good check the crankshaft sensor.
Jul 11, 2010 | 2000 Kia Sephia
Directed Electronics DV2602 Car DVD Player Logo
Top Directed Electronics Car Audio & Video Experts
xxxxxx xxx
Are you a Directed Electronics Car Audio and Video Expert? Answer questions, earn points and help others
