Need to reset display counter/meter on a bizhub 750
Need to clear main display/digital counter
If your are speaking of the total counter of the machine, the main counter when you press the "utility/counter" key this can not be reset except in the case of replacing the main board.
Posted on Jan 23, 2009
How do i re-set fuser unit replacement message on bizhub c253
SIR/MAM
TROUBLE RESET
FIRST, If this code comes back. Have a technician look at it DO NOT CONTINUE TO RESET the code!!!! AS this is for the Hot Part called the FUSER. It can catch on fire! And that will ruin a perfectly good day!!!!
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Jun 27, 2016 | Konica Minolta Bizhub C253 Copier
W to reset web supply of bizhub 750 konika minolta
First has the web been replaced. if not going to get bad image problems, have to go to service mode then counters a clear web roller.
Mar 03, 2015 | Konica Minolta bizhub 750
How to clear error code C 3421 on Konica Bizhub C360
if the code comes back after this procedure, DO NOT RESET AGAIN you are dealing with the Fuser the hot part it can catch on fire that will ruin a perfectly good day.have tech come out and look at it.
4. Check to make sure that [OK] is displayed and it has been reset.
Apr 24, 2014 | Konica Minolta bizhub C250 All-In-One...
How do you reset drum and developer counters
Press the Utility/Counter button then meter count then details then stop 00 stop01 to access service mode then clear drum and developer do not exit out all the way once counters are cleared touch end then power off the main PWR ON/OFF switch located on the left hand side of the machine in the rear then remove the Drum Cart and replace drum and Developer then reinstall drum cart. Enter service mode again Run Function F-8. Do no print or copy before doing this. So disconnect FAX line and Network cable.
Apr 08, 2014 | Minolta bizhub 350 Black and White Copier
Bizhub 750, i put new developer, is there any setting that i have to do after this job?thx
After you change the developer enter in service mode press Utility key- Meter count- Details-Stop-0-0-Stop-0 -1press Counter select Special(optional)parts counter select Developer and reset the Developer counter value by pressing C.After reset the developer counter enter in Imaging Process adjustment mode select Drum pecularity mode and select Cartridge installation mode press the Star button.The process duration is 2-4 minutes.Whwn thw ok appears press Exit and return the copy mode,make a test page.
Mar 24, 2014 | Konica Minolta Dv710 O2xk Black Developer...
Touch screen on minolta bizhub 200 not working all the time
Need a new touch screen.One other option. Push utility/counter meter count then press stop 00 stop 02. Places machine in maintenance mode. Then press the utiltiy/counter will see maintenance mode press that find touch screen adjustment. follow the screenthen press start. T clear maintenamce mode and flashing start button. Power off machine main power left side of the machine to the rear.
Feb 07, 2014 | Minolta bizhub 200 Copier
How to reset c3803 code bizhub750
If the code comes back, you need a Fusing unit ( DO NOT KEEP TRYING TO RESET THE MACHINE! THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!! A Fire could occur and that would ruin a perfectly good day!!!!
1. Turn ON the main power switch (SW1).
2. With the Utility/Counter button pressed, turn ON the power switch (SW2).
3. Press [Trouble reset] to release a trouble with [OK] displayed.
4. Turn OFF and ON the power switch (SW2).
Jan 08, 2014 | Konica Minolta bizhub 750
How to clear error code c 3421 on konica bizhub c253
C-3421 = Fusing heaters trouble
To Reset:
If error code returns a technician is needed to replace fuser section. Call local dealer with error code and tell them to make sure a tech brings a fuser assembly.
May 19, 2010 | Konica Minolta bizhub C250 All-In-One...
The machine says "replace ozone filter" i did that but the message won't reset itself. is there something i can do to reset it?
On most models of Color Bizhub machines, to reset the ozone filter message you must go into service mode. Press the Utility/Counter button on your operation panel, select meter count, then detail, press stop,0,0,stop,0,1. This will put you in service mode. Find and press counter button, Locate life counters, and clear ozone filter. You will not be able to clear some of the counters in this menu. They are automatically cleared when the items are replaced.
Apr 23, 2010 | Konica Minolta bizhub C351 All-In-One...
Need to reset the drum counter on the AL 1740 sharp while changing to a used drum
Entering in the simulation mode:press Clear - Interrupt - 0 - Interrupt -Main code - Start -Subcode - Start.
When the clear all key is pressed the simulation mode is cancelled.When the interrupt key is pressed,the proces is interrupted and the screen returns to the subcode entering display.After cancelling the simulation mode be sure to turn OFF/ON the power and check the operation.
Main code 20 subcode 1 =Maintenance counter clear.
Main code 21 subcode 1 =Maintenance cycle settimg
subcode 2 =Mini maintenance cycle setting.
Maincode 22 subcode 1 = Maintenance counter display
subcode 2=Maintenance preset value display
subcode 3=Jam memory display
subcode4=Total jam counter display
subcode 5=Total counter display
subcode 6=Developing counter display
subcode 7=Developing preset counter value display
subcode 9=Paper feed counter display
subcode 12=Drum counter display
Maincode 24 subcode 1 =Jam counter clear
subcode 2=Trouble memory clear
subcode 7=Drum counter clear
subcode 8=Copy counter clear
Maincode 26 subcode 22=Language setting
Maincode 42 subcode 1=Developing counter clear
Maincode 43 subcode 1=Fusing temperature setting
Maincode 46 subcode 1=Copy density level adjustment
subcode 19 AE mode picture quality change
Nov 20, 2009 | Sharp AL-1641CS Laser Digital Copier
478 people viewed this question
jasbo
jasbo
