Question about Vizio VBR122
WHERE DO I GET THE .DSO FILE TO UPGRADE MY VIZIO BLU RAY
I am trying to find the .DSO file to download on my flash drive, so that I may upgrade my blu ray player?
SOURCE: my vbr120 blu ray player
I have the same problem. While I don't have the permanent solution, I can tell you a few things. 1) You don't need to unplug, simply hold the power button down on the unit until it does a full reset (it normally just goes into standby mode when you tap the power off button). 2) I've noticed the locking only happens if I try to watch a netflix after I've used an optical disc between resets. IMO, I believe it's a problem with the system memory not updating and won't be solved unless they put out a specific firmware upgrade for it (unlikely on such a cheap player).
Posted on Feb 16, 2011
  • 16 Answers
SOURCE: our vizio blu ray player
Please inspect the HDMI connector on the back of the Blu-Ray player to make sure none of the pins (top and bottom) are not push back inside the connector. If there are return the unit for a another unit.
Posted on Feb 24, 2011
muntejaya
  • 10421 Answers
SOURCE: what is my code to hack the multi-region on my
Please get the code here : www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
www.dvdreviewer.co.uk/Forums/...region_code/page1
Best Regards, Jay__hytg34
Posted on Feb 27, 2011
dss902
  • 16 Answers
SOURCE: I have a Vizio VBR120
The default IP mode is set to Dynamic, which means your player will automatically detect and use
your network settings after you connect your Ethernet cable, but you can manually change these
settings if you are an advanced user and are comfortable with networks.
1. Turn on your player and your TV. If a DVD is not in the disc tray, the Home menu will be
displayed. If a DVD is in the disc tray, press SETUP to display the Home menu.
2. Connect one end of an Ethernet cable (not included) to the Ethernet port on your player
3. Connect the other end of the Ethernet cable to your home network (usually your router
home network must have broadband Internet access such as cable or DSL.
4. Press to select Settings, and then press SELECT.
5. Press to select Network, and then press SELECT.
6. Press ^ or down to select Wired and then press SELECT.
7. Press to change IP Mode to Manual and then press SELECT.
8. Manually change your network settings such as IP Address, Subnet Mask, Default
Gateway, the Primary DNS, and Secondary DNS.
9. Press ^ or down to select Apply and then press SELECT.
Note: If you need additional help setting up your network, please refer to the user manual for your
router or contact the manufacturer of either your router or your Internet service provider if they
provided the router for you.
Your ip settings will look something like this 192.168.2.1
You might be able to find you setting by going to Network Connections -> 2x click on Local Area Connection -> then click on the support tab.
Posted on Mar 05, 2011
t407803
  • 84 Answers
SOURCE: A new "Tangled" movie disc not play in Blu-Ray
As newer bluray movies come out they are constantly tweeking the format. More then likely you need to update your bluray players firmware or software. There should be an option under the menu for the bluray player to update the unit of course this will require that you have it hooked into the internet via ethernet cable or wifi network.
Posted on Apr 11, 2011
Testimonial: "This site was extremely helpful. Received resonse very quickly."
Pandora Activation Code Not Generating
I have the Samsung BD-E5400 Blu-Ray Disc. Pandora did not recognize my log in and I had to go online to Samsung.com and download the latest software update BSP-E5400WWB-1006.0 and save it on my computer in a zip file. Then I had to unzip it and save the RUF file with the same name BSP-E5400WWB-1006.0.RUF on a thumb drive. I inserted the thumb drive in the back of the Blu-Ray and went into settings/support/software upgrade and picked the option to upgrade by usb. This quickly uploaded the updated software and restarted my Blu-Ray. Everything was fine then. I was able to go into Pandora and it recognized my account and email/password.
Dec 27, 2012 | Samsung WiFi Blu Ray Player - Black...
BDP-51FD Firmware Upgrade WILL NOT DOWNLOAD. IT SAYS THE FILE IS CORRUPT..
http://www.blu-ray.com/firmware/firmware.php?id=29
Attempt to get the file manually, if that doesn't work, try using the file in administrative mode before using it. If it is corrupt completely, delete it and redownload it.
Mar 13, 2011 | Pioneer BDP-51FD Blu-Ray Player
Im trying to upgrade my firmware on my samsung blue ray player but I keep getting a message saying that I have data error. I tried differnt files, usb flash drive, ethernet through my laptop, and burning...
Don't upgrade the firmware on your Samsung BD-P1600. The firmware from Samsung is faulty and will most likely crashh your machine, Permanently !!!. I made that mistake last night. Now I have no Video output to my T.V. from any of the video outputs on the blu-ray player. Also the unit turns on but will only display LOAD , OPEN, CLOSE, ON, OFF... Nothing Works now.. This is apparently a common issue and there are several forums discussing this problem.. No fix that I have found !!
Feb 09, 2011 | Samsung BD-P1600 Blu-ray Disc Player
Blu ray not respoding after download the firm update.
Sounds as if you got a bum flash of the operating system. Try flashing it again to see if the software upgrade will take. take a look at the YouTube how to at:
http://www.youtube.com/watch?v=uOr1PSmtCYQ&feature=related
One thing about flashing is you have to get the right file for your player as trying to load another player's file may "Brick" your player.
Jan 23, 2011 | Samsung BD-P1600 Blu-ray Disc Player
Downloaded updates for sharp aquos blu ray, cannot get the file to work no matter what i try if the file is zipped with winzip it is definitely not working it is supposed to be a firmware update, but it...
download zip file to desktop then unzip it then drag it and drop the unzipped file to a zip drive best if its the only file on it turn on dvd player should see it and upgrade make sure player is on just like you were ready to watch a video should work takes about 8 minutes to do it hope this helps
Dec 19, 2010 | Sharp BDHP20U Blu-Ray Player
I was unable to watch a Blu-ray it stated that I needed an upgrade to view - how do I get/install the upgrade?
Go to the following website for more details and instructions:
http://www.pioneerelectronics.com/PUSA/Support/HomeEntertainment/Blu-rayDisc+DVD/PioneerBlu-rayDiscPlayers/ci.BDP-120.Support?tab=B
You will need a USB flash drive to copy the update file and then connect it to your DVD player via USB port.
Good luck.
May 04, 2010 | Pioneer BDP-120 Blu-Ray Player
Need firmware update
Download the file from here
Then upload the file to flash drive/thumb drive ( it has to be usb 2.0 , formatted FAT, capacity 1Gb or below)
Stick the drive into BD player.
Select setup>firmware upgrade.
Follow on screen instructions.
Nov 16, 2009 | Sharp BDHP20U Blu-Ray Player
I have a samsung bd1500 blu ray player, I am unable to play wolverine on it it says i need an update, any advice?
There is a firmware update available on the Samsung website. Try it and I hope it will play your required disc.
You can upgrade it via USB flash drive or CD.
For CD type, download this file. Instructions can be found here.
For USB type, download this file. Instructions can be found here.
If you have trouble with the links given, click here to visit the Samsung website for this BDPlayer.
Oct 29, 2009 | Samsung BD-P1400 Blu-Ray Player
Update with disc model BH100
Download the firmware file and how to document here:
http://us.lgservice.com/index_b2c.jsp
Follow document to create a disk, and update the firmware.
Dec 29, 2008 | LG BH100 Blu-Ray Disc Player
Vizio VBR122 Logo
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
