I have a samsung front loader washer model# wf306law/xaa. I do not have any power at all. I have check the fuse box n breakers everything is fine. Do i need to replace the pcb? Or is the life of my washer has ended. Any suggestion or solution please, thank you
2 Suggested Answers
SOURCE: I HAVE A SAMSUNG WASHER MODEL WF306LAW/XAA IT HAS
You can bypass this part and throw it away if you don't use the silver-care feature on your washer. Simply route the longer of the two hoses directly to the soap tray. Use an appropriately sized screw and the existing clamp to plug the smaller hose. Electrical tape and zip tie the two wire ends and their connectors so they don't flop around. El-cheapo solution!
Posted on Dec 04, 2010
Samsung washer model#wf306law/xaa error code tE - temperature sensor problem. what part do i need
This could be either a sensor or a wiring issue, You need to check the wiring that runs from the sensor to the electronics, the wires can break inside the plastic sleeve and cause the electronics to think there is a sensor fault, It could be a sensor fault but i usually find a broken wire in these machines.
May 10, 2017 | Samsung Washing Machines
No power to washer, can't open the washer door
http://www.appliancepartspros.com/parts-for-samsung-wf218anw-xaa-0000.html Look at the video section to see how to get under that machine and open the door and drain it.
Oct 04, 2015 | Samsung WF218AN Front Load Washer
Where is the debris filter in a samsung washer WF328AAW/XAA
you take the plug out
take the back off
it should be between the tub and the pump ((take the hose of and clean it))
Feb 02, 2014 | Samsung WF328AAW Front Load Washer
Samsung washing machine wf306law xaa where is debris filter?
I have a
WF306LAW/XAA Samsung, and no idea where this filter is! Any help?
Nov 13, 2013 | Washing Machines
Samsung front loader washer Model: WF306LAW
The "3E" error code indicates that a high current is detected.
A "3E" error in a Samsung washer indicates that there is an issue with the motor. Restarting the cycle may clear the error, but a service technician should be consulted if the error code appears again.
Oct 17, 2012 | Washing Machines
My WF306LAW-XAA Samsung washer will not stop filling with water and hence will not advance to wash cycle. Do you think it needs a new mixer valve?
No, you have a water level switch problem. Simple solution is to pull the hose from the water level switch and blow into the hose to clear out the debris. DO NOT BLOW INTO THE WATER LEVEL SWITCH!!! It will break!!! Replace the hose back onto the water level switch and it should work fine. Good luck
Jun 17, 2011 | Samsung Washing Machines
How do you install a pump motor on a samsung washer model # WF306LAW/XAA
remove back panel and you should see the pump .remove the clamps on the hoses and there should be 3 bolts securing pump to base, remove with socket, 1/2
Aug 26, 2010 | Samsung WF328AAW Front Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
