Question about Sharp Brown & e Digital Micrometer Micromaster Mm2000
Dead readout After replacing a dead battery, I still get no readout. I'm suspecting the ON/OFF button isn't making good contact.
My hannspree hannspad won't turn on at all
I would suspect the battery is dead . plug it in to the charger
Jan 18, 2013 | Hannspree HANNS pad SN10T1
Black and Decker Battery Charger BCS25EB does not charge dead battery which is new
The fact the battery is 3 months old means zip, I have replaced dozens of batteries under warranty, many less than 3 months old. have it tested with a load tester.
May 21, 2017 | Tools & Hardware - Others
Ac compressor not clutching
time for a new compressor. It's a magnetically controlled belt driven compressor. If it isn't clutching anymore, it's dead. pretty soon it'll start squealing or making other funky noises if it isn't completely dead yet, then soon you'll press the "ac" button and nothing will happen.
Jun 09, 2012 | 1992 GMC Suburban
Door locks not responding to radio-control key
Start with battery in control, then look at owners manual and reset as per instructions. Good luck.
May 22, 2012 | 2001 Ford Focus
Can't turn it on. Power digital readout doesn't work.
Mine would not turn on at all, found the contact pads for the buttons was corroded. Used an eraser and cleaned them, working good now. Of course the whole thing has to come apart to get to the contact pads.
Nov 30, 2011 | Bemis 821 000 Humidifier
2005 sedona won't start all of a sudden. Doesn't make a sound except for a tiny whirring sound like the feul injectors. Replaced starter...still won't start. checked all fuses...they are good....
you could just have dead cell in the battery which isn't getting enough amps to the starter,, have the battery LOAD checked,, that will tell you if the battery is actually good, just because it registers 12 volts isn't necessarily an indication that the required amps are present.
Sep 27, 2011 | 2005 Kia Sedona
Daughter called me ..car wont start. checked battery at Autozone...it is good. someone stopped to help them and bang on startere and it starts up. Bad starter. Starter replaced. Next day daughter...
it sounds like you have blown fuse to the Alternator.. I don't know what car you are talking about but they charging systems vary.. But if alternator isn't getting all the power it needs it won't charge. this should be checked.
good luck
Sep 02, 2011 | 2000 Oldsmobile Intrigue
Hello I have a problem with my Pontiac 2002 Trans Am - Collector Edition. It does not want any more to start, there is the indicator SECURTITY which east lights, and since average making it...
Check the battery voltage with a multimeter. If the battery can't deliver a full 12 volts, the starter solenoid won't even activate. It may be that a cell went dead, causing a direct short inside the battery. Replace the battery if your battery is older than 3 years, or take it to an auto parts store to have it tested. The security light on is an issue many people have when the battery is low and the car won't start.
It is also possible that the security chip on the ignition key is worn. If it isn't making contact properly, the computer won't 'read' the resistor, and won't start. You will need to replace the key to see if this fixes the problem.
Aug 17, 2011 | 2002 Pontiac Firebird
LI misplaced my handset How does the "locate
The locate handset button will make the missing handset ring for 60 seconds. This will usually give you time to find it (assuming the handset battery is good, the handset is not out of range, and/or the handset ringer isn't set to OFF). Once you have the handset, press the Page/Handset Locator button or place the handset on the base.
You can press the locate handset button again if you haven't found the handset in one minute. The manual for the Vtech 2451 is available from Retrevo: http://www.retrevo.com/support/Vtech-t2451-Telephones-manual/id/470ag516/t/2/ . You will need to enter a code to download the pdf.
I hope this helps.
(If you have a large area or several floors to check, those 1 minute intervals aren't enough time to search for one person. Enlist assistance if you suspect the missing phone isn't just under a throw or pillow near the couch (for example).)
Jul 01, 2011 | Vtech 2451 Cordless Phone
My door lock is beeping like crazy like somebody is pushing buttons and then it sets off the alarm resets itself and then does it all over again. I know this isn't a battery problem. I suspect the...
This is the link to the troubleshooting instructions for your lock:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
If you can't resolve the problem, contact Customer Support; you will find the contact info on this page:
http://www.weiserlock.com/en/CustomerService/ProductSupport/SupportContact.aspx
May 05, 2011 | Weiser Lock Powerbolt 1000 Lock
Sharp Brown & e Digital Micrometer Micromaster Mm2000 Logo
64 people viewed this question
Top Sharp Tools & Hardware - Others Experts
Are you a Sharp Tool and Hardware - Other Expert? Answer questions, earn points and help others
