Question about Destroyit 2604CC Shredder
On the destroyit 2604 the door open light remains on when door is closed and the shredder will not run.
3 Suggested Answers
HansPP
  • 2510 Answers
SOURCE: we have a destroyit 2602 cross cut shredder, when
The paper sensing switch lever has bent or broken or the switch is faulty. Check between the wheels about in the middle of the shredder to see if you see if the little plastic finger. If the finger is visible and can be moved, the switch is faulty. REMEMBER TO UNPLUG IT BEFORE DOING ANY INVESTIGATION.
Posted on Feb 20, 2011
  • 5 Answers
SOURCE: i need a parts manual for destroyit 2502cc
That shredder is obsolete, but you can probably get parts from shredderparts.com
Posted on Mar 08, 2011
Door open warning destroyit 4002cc fix
Maybe the door switch is bad or the part on the door that activates it is broken off or otherwise misaligned or missing.
May 25, 2014 | Achiever SCS-6 Strip-Cut Shredder
Destroyit 5009 Shredder No power to the oil pump.
Investigate the operation purpose of the Oil Pump. Did you measure the voltage across the terminal or observe that the pump was not operational. It must have an auxiliary function that is not related to main operations. Investigate the purpose of the Oil Pump and deduce what would make it operate then check that switch if their is no voltage measured across the pumps terminal when it should be operating. This deductions may help lead to the problem and a solution.
Aug 27, 2013 | Destroyit 5009 Shredder
A staple was run through the shredder. The staple was removed but now the blades don't turn.
If you want to fix, I would remove power and take the cover off and the try to turn the blades, they should turn. there maybe something else in the blades or a belt could be off if belt driven or there are normally gears that are designed to break if a heavy bind is caused. these machines can cause damage to fingers and ect if not careful. make sure unplugged.
there are several sensors that could have problem, one is on the door (door has to be closed) and there is a photo sensor down where the paper in inserted.( this can get covered with fine paper dust)
also see if it will run in reverse. this will test most of the motor and belts,gears.
hope this helps
Jul 12, 2011 | Destroyit 2603 SMC Shredder
I need a parts manual for destroyit 2502cc shredder
Feb 25, 2011 | Destroyit 2502 Shredder
Where do i get replacement gears for this schredder?? dertroyit 4002 thanks
I have a Destroyit 4002 cross cut paper shredder. I have ordered parts twice from shredderparts.com
Both times they were friendly and sent me the correct parts.
Jun 12, 2010 | Destroyit 4002 SMC Shredder
Destroyit 3102 drive gear part number
The part number you need is 2601 062 as long as your looking for the gear that meshes with the motor shaft. The price is around 25.00 dollars and phone number for destroyit or as known MBM corp. 800-223-2508
Hope this helps leave feedback if so. If you have trouble getting part contact me i'm a dealer and can get you the part.
May 14, 2010 | Destroyit 3102 Shredder
4605 CC wont turn on
Did you verify wall power? If good Then you might have button problem. I have 3 of these machines in the field.
Apr 26, 2010 | Destroyit 4605 Shredder
Destroyit 4104 manual
I know that shredderparts.com has parts for it, but I don't know about the manual for this machine.
Aug 21, 2009 | Industrial Paper Shredders IPS16D
I have the 2602 model and the indicator for the door being open stays lit even when the door is closed is there a way to fix this
Yes. There are two electromagnetic sensors (front and back). If defective, the main board will show a yellow or red light. These sensors function with the cabinet which is magnetized in the center (front and back).
Dec 29, 2008 | Destroyit 2602 Shredder
Destroyit 2604CC Shredder Logo
24 people viewed this question
Top Destroyit Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Destroyit Office Equipment and Supply Expert? Answer questions, earn points and help others
