Question about Measuring Tools & Sensors
Llbean weather station model OKSV1
Model OKSV1
LA Crosse manual for weather station 308-1414
Most LaCrosse weather station manuals are available here: http://www.meade.com/support/manuals/ or on the product page (see the Support tab). Using the search feature on the support page, I found three models which start 308-1414. Two of these differ in the color of the case of the weather station. Hover over the picture of any of these weather stations and click on the More button to go to their product page. The direct link to the manual for the 308-1414MB is http://www.lacrossetechnology.com/media/catalog/product/3/0/308-1414m.pdf . This product page is http://www.lacrossetechnology.com/308-1414mb-weather-station/ . The manual for the 308-1414W/308-1414B is http://www.lacrossetechnology.com/media/catalog/product/3/0/308-1414.pdf . The product page for the 308-1414W is http://www.lacrossetechnology.com/308-1414w-weather-station/ .
I hope this helps.
Jul 10, 2017 | La Crosse Measuring Tools & Sensors
How to set time and date
We're not the psychic hotline! Model number?
Click on the link, it's La Crosse Tech weather stations. Find your model or one similar to yours. Mouse over and click "more info". Select the "support" tab and then product manual. How to set date and time will be in the manual.
Weather Stations Weather Browse Products
Aug 15, 2016 | La Crosse Technology La Crosse Wireless...
Changed the batteries in both the transmitter and weather station. It doesn't show temperature on the transmitter or show temperature and humidity on weather station
In some of these weather stations, you have to install the batteries in the transmitter first and then the weather station within a certain time limit. Also, the weather station must be within a specified distance from the transmitter when replacing the batteries.
If you look on the weather station, there should be a make and model number. If you have that, you can visit the website (if there is one) and download an instruction booklet for your model.
Jul 21, 2015 | Measuring Tools & Sensors
Is there a sharper image internet weather station download for windows 8, I seem to be only getting a downlaod for Win XP Prp?
Hello, You will have to go back to the weather stations tech or cust. support to get that question answered. Just make sure you have your model and serial number or your weather station written down too tell them.
May 17, 2014 | Sharper Image 5 Day Weather Forecaster
We have bushnell model 960900C it doesn't work now
Toward the middle or end of March 2014, Bushnell and Accuweather terminated their data sharing contract for the Weather FXi, Hunt FXi and Golf FXi internet-based weather stations. Since the forecast information is freely available on Accuweather's website, all Bushnell would have to do is fix/update the software to grab the data a different way. These were awesome weather stations when they worked and now Bushnell has decided to brick them by refusing to update the software. They have our money and now we have electronic waste paperweights to pollute the landfills. What a great business decision for them! I for one have decided to never buy any Bushnell products again and I hope everyone else who Bushnell screwed over by this decision to brick perfectly good weather stations also decides to boycott Bushnell products.
Apr 21, 2014 | Bushnell Measuring Tools & Sensors
How can i tell if the garden tools i buy are good quality?
You can tell by how the handle meets the stick/pole. Do not go by price. You should look for tools with the most support. As far as hand tools, same thing. Keep in mind that various weather conditions and proper handling do matter. I prefer wooden hand tools from LLBean. But if left out eventually the wood will dry out and split.
Dec 05, 2013 | Garden
I have a wweather station model no. CE0681The outdoor control no longer tranmits infromation on tempereture to the inside weather station. How do I solve this problem?
There are a couple of reasons that this can happen. First try replacing the batteries in the outdoor control. Also replace the batteries in the base (inside unit).
You may also need to resynch the two units. (For some models, this requires bringing the outdoor unit inside and removing the batteries. Then add the batteries and let the base station look for the outdoor unit.) With the Davis instruments weather station with the solar powered unit, clean the solar panel. You may need to replace the rechargeable battery.
Sometimes, lightning strikes near the weather station external unit causes a surge that damages the unit. In that case, the entire board may need to be replaced to fix the problem.
Please add a comment with the manufacturer for additional information.
I hope this helps.
Mar 18, 2013 | Measuring Tools & Sensors
Cannot get the weather station model ws-916ou-it to show outside temperature
I have three of these WS-916OU-IT units. After a few years, the outside sensor just fails. You will get dashes and a "TR" low battery signal, even if the batteries are good
just buy another whole weather station (short money) and set both the old and new weather station unit to receive from the single new outdoor sensor.
To do this - just follow the procedure for a single sensor - that is - put the batteries in the new sensor - then within 30 seconds - put the batteries in all the weather stations - they will all pick up the same outdoor sensor.
I now have three units running off of one outdoor sensor.
Seems a bit silly, but it works.
Feb 27, 2012 | Measuring Tools & Sensors
Measuring Tools & Sensors Logo
89 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
