Question about Toshiba 35A44 35" TV
Missing power button
The power button is missing on my Sharp TV. I cannot turn tv on with universal remote. Is my tv problem bigger than a missing power button? Is this problem worth a $135.00 service fee? TV is about 8 years old.
    Sergeant:
    Champion:
  • 318 Answers
There is one thing you can do cheaply,
open the tv by pass the switch, put straps a cross switch contacts.
only two polarities enters your tv live and netrual, each one goes a cross the switch.
program your remote
0156,0060,0154.
or 060,019,014,052,054,075.
Posted on Apr 08, 2009
  • Lucretia Krauser-Doyle
    Lucretia Krauser-Doyle Mar 30, 2012
    how do you put a strap across switch contacts?
I have a jvc 32inch tv and the on and off power button is missing i cant turn my tv wont turn on or off i bought a universal remote and my tv is still not coming on
Program the universal remote following the instructions manual for that model TV. Usually holding the power and TV button until the TV power light comes on. Or, try the combination codes for that model TV.
Nov 25, 2014 | Televison & Video
The remote won't work
Is its a Sharp Remote? or a Generic
A) Check Batteries
B) If a sharp aquos remote there is a function button on the right top side - insure that TV is selected. TV led will light
C) On left side there is a red TV power button press and insure the red led on the remote lights.
D) IF Tv does not turn on then you may have a problem with
the sensor inside the tv.
Only real way of verifying it is not The Remote sensor is by trying another remote. If you have a Cable or Universal follow the instructions for a Sharp TV and try that. If it works problem is with the Sharp Remote if it doesnt its your remote sensor inside the tv.
Hope this helps.
Aug 02, 2013 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
Sharp tv 25g s100 power button doesn't work, no original remote
The remote may or may not be the real problem, it is possible on most of these to gain access with back removed directly to the tiny button switch that is in back of the plastic power button on the set and press it with something not sharp (a micro switch is what the button activates) and if set comes on get the remote programmed.
Your best bet if the set will make it on that way is to get the original remote----if in North America with the model number of the set contact either Sharp or Andrews Electronics---usually the original is under 35 dollars and no headaches with programming.
If set does not turn on manually with the micro button you may now have a actual circuit problem in the set.
Dec 10, 2012 | Televison & Video
I have an RCA tv model # f27159wn, we had a universal remote to turn it on because the power button is missing. Our son lost the remote, when we found the remote it doesnt turn the tv on now. How do I...
RCA tv codes from the original RCA 3-in-1 universal remote.000,181,100,233,203,212,098,005,003 004,006.One of these codes program for the RCA universal remote will work.Sorry but to find the tv wright codes for the tv to work.The tv must be power on and working to find the tv wright codes to program in to turn the tv off to get the tv wright codes.Try website like Rmotes.com to buy the tv original remote,will not require tv on to used the tv original remote.
May 03, 2011 | RCA 4-in-1 Universal Remote Control
Universal remote I need the code to a Sharp TV
Hello
Three digit universal remote code for Sharp TV are:
004/ 009/ 079/ 095/ 111/ 112/ 114/ 122/ 123/ 124/ 173
Four difit universal remote code for Sharp tv are:-
0079 0123 0063 0020 0004 0009 0226 0266 0006 0095 0122
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
NB: Switch OFF and switch ON your TV with its front panel power ON/OFF switch each time before trying an other code.
Mar 01, 2011 | Televison & Video
BOUGHT A USED SHARP TV WITH THE POWER BUTTON MISSING .IT USED TO COME ON WITH REMOTE BUT EVEN WITH FRESH BATTERIES IN THE REMOTE IT WILL NOT TURN ON THE TV. DO YOU THINK THE REMOTE WENT BAD?
To power on the tv with your remote, the tv must be in stand-by. You should look if the tv is in stand by. If it is not, you should use a pen to power on the tv. (press where the button was)
hope it helps :)
Apr 22, 2010 | Sharp 25R-S100 25" TV
Unlock my remote
First of all have you checked the remote with fresh batteries in.
Check there`s no obstruction between remote and tv.
I can get the codes for a universal remote 01 or 02
try those on your sharp remote.
Another way
If you don`t have codes,I can tell you how to find the code on your remote without pressing any numbers!
Hold the code search button until the red light on the remote remains on. Then, press "TV". After this, point the
remote at your television and press the power or on/off button over and over again SLOWLY (one time every second) until
the TV turns off. DO NOT PRESS THE POWER BUTTON AFTER THE TV TURNS OFF!!! Once it does, press the "enter" button on the remote. Then, the remote should work on the TV.
Hope i`v helped!
Dec 02, 2009 | Televison & Video
Remote codes
http://www.oneforall.com
Hope this helps.
Len
Feb 27, 2009 | Televison & Video
My grandmother needs the code her GE universal remote to operate her Sharp TV. Thanks
MANUALLY ENTERING CODES
1. Manually turn on the device (TV, VCR, DVD, etc.) you wish to
program.
2. Press and hold the CODE SEARCH/SETUP button on the remote
until the INDICATOR LIGHT lights, then release.
3. Press and release the button for the device you are programming
(TV, VCR, DVD, etc.). For AUX, press AUX then the device button
you are assigning to AUX. The INDICATOR LIGHT will blink then
remain lit.
4. Enter the three or four digit code for your device using the number
buttons in the GE Universal Remote. After your code is entered the
INDICATOR LIGHT will turn off.
5. Aim the remote at the device (TV, VCR, DVD, etc.) and press the
POWER button. Your device should turn off.
Note: If your device does not respond to the first code listed,
repeat steps with the next code. If none of the codes listed for your
device work for your device or your brand is not listed, try the Code
Search method described below.
Possible codes, seeing as each tv is different you will have to try until one works, the third list is for models bought before August 2002
found all of the below info at http://www.jascoproducts.com/support/universal-Remote-codes.asp
SHARP .... 0079 0123 0063 0020 0004
....... 0009 0226 0266 0006 0095 0122
SHARP
591, 604, 729, 671, 679, 684, 809
Sharp
004, 006, 012, 029, 095, 111, 112, 113, 122, 171, 173
Let me know if you have any questions, please don't forget to rate my solution after you fix the problem
Apr 25, 2008 | Televison & Video
RCA RCR3273 3 DEVICE SNOWBOARD UNIVERSAL REMOTE
Answer for how to program the RCA RCR3273 3-DEVICE SNOWBOARD UNIVERSAL REMOTE:
Make sure the device is on. Hold down the tv (or whichever device you're trying to program) button and the power button simultaneously until the red light stays on solid. Then press the power button, it will flash one time, and keep pressing slowly, letting it flash until the device turns off. Then press the stop button...and it is programmed.
phoenixx100@hotmail.com
http://www.angelfire.com/journal/archer/index.html
Oct 12, 2007 | Televison & Video
Toshiba 35A44 35" TV Logo
176 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
