Question about Channel Master (9537) Remote Control
How to reset the rotator - Channel Master (9537) Remote Control
Remove c-24 errorminolta di450/500
Sir/Mam,
C0F24 Code is the code for the sensor that monitors the drum. I would remove the drum cartridge two black screws pull out the drum assy. Remove the drum be careful do not nick or harm the drum the sensor is located on the left side of the to the rear of the of the drum looks like to little eye of a bug. Dust with a brush NO VACUUM static could destroy it. Re-install drum and re-install cartridge. When the last time a PM was done Developer replaced and Drum replaced?
Dec 14, 2014 | Minolta Office Equipment & Supplies
Rca vh126r rotator has stopped working
This should have a reset to it. If not then it got thrown off in the gearing and my have to be manually reset by taking it apart.
Apr 14, 2014 | RCA VH126N Programmable Antenna Rotator...
Shark rotator reset button
If shut off may be motor heated when it cools it should start buy its self
Dec 30, 2013 | Euro-Pro NV22 Shark Navigator Bagless...
Resetting convenience features after battery replacement
put key in drivers door lock, rotate and hold in unlock position until all windows open. then rotate and hold in lock position until all windows close.
Dec 15, 2013 | 2009 Volkswagen Tiguan
My tablet screen won't rotate
Make sure you have enabled screen-rotation in your tablet settings.
Nov 17, 2013 | ASUS MeMO Pad HD 7
Screen won't rotate. And it starts rotating after I reset. And then it stops rotating after couple of hours The screen rotate has been checked and unchecked. And the g sensor has been.calibrated lot if...
If you've already resetted your phone, its sounds like a hardware issue, a loose contact or something. You'll need to take it to a service center.
Cheers.
Mar 18, 2011 | HTC Inspire 4G Smartphone
How to reset the combination, GE Hide a Key Storage Lock Box (GE Access Point Series)
Step 1. With the cap closed, set the numbered dials to the combination line. The factory preset combination is "000".
Step 2. While maintaining the combination in place, rotate the "RESET" dial indicator beneath the letters approximately 90 degrees to line-up with the combination line. If the correct combination is not set, the "RESET" dial will not rotate.
Note: Using excessive force can damage the dials.
Step 3. Set the new combination while maintaining the position of the "RESET" dial.
Step 4. While maintaining the combination in place, rotate the "RESET" dial back to the original position. The combination has been changed.
Sep 07, 2010 | GE Home Security
My speedaire compressor hasn't been turning on automatically to keep the tank filled with air, The reset breaker pops and so I have to rotate the pullys a few times and then push the reset button which...
Sounds like the release valve is not working. When the compressor shuts off, you should hear a slight hiss, draining residual air in the cylinder. If the motor starts up and can't rotate, it will blow the breaker. When you rotate the pulleys, you take the load off giving the motor a fighting chance.
Cabinetman54
Nov 18, 2009 | Air Tools & Compressors
I am unable to reset the timer on my Grundfos UP
You were able to rotate it before and you cannot rotate
it now?? Is this the situation??
Then, the programmer is stucked up. Sorry, but you may need to replace it.
Jul 08, 2009 | Plumbing
Channel Master (9537) Remote Control Logo
99 people viewed this question
Top Channel Master Televison & Video Experts
Peter Privates
Level 1 Expert
Are you a Channel Master Televison and Video Expert? Answer questions, earn points and help others
