Question about RCA P52937 52" Rear Projection Television
No power when the TV is plugged in the only thing that happens is a chirping noise coming from the pack of the TV. The noise seems to come from a transformer although I suppose the problem could be the HV Block since that seems to be the big proble area for these TV's.
  • Jeff Murray
    Jeff Murray Jul 08, 2007
    It doesn't make a sqeeling noise it chirps, just a small chirp then a pause then a chirp and it continues to do this for as long as it is plugged in. It is a CTC195M26B Chassis, at least that is what is what the label says. The model is a P52937YX2, Do you still think it is the Flyback and and output transistor?
  • Anonymous Mar 29, 2008
    rca p52937 52in
Simalar problem on my 58 inch it was the transformer.ran me three hundred at tv clinc parts a labor
Posted on Apr 13, 2008
  • 398 Answers
The P52937 uses the PTK195 series chassis. If the TV makes a squeeling noise the instant it is plugged in then unplug it immediately and do not plug it back in. I have seen this many, many times. The flyback (high voltage) transformer has shorted out and the extra current it was drawing has shorted out the horizontal output transistor, so the B+ supply is dead shorted and the power supply squeels as a result. This is very common in that chassis. The flyback and output transistor will have to be replaced by someone with experience in RCA projection TV's. The HV block in the PTK169 sets is the one known to be bad a lot - the block in the 195 is very reliable and I have never seen one of those bad.
Posted on Jul 06, 2007
  • Mike Longo
    Mike Longo Jul 10, 2007
    It could still be the flyback but it probably does not have a shorted transistor. This actually depends on whether the chirp is coming from the flyback transformer or from the switching power supply transformer. I would first need to determine if the main B+ from the power supply is always up and running or if it going up and down with the chirp sound. This does sound like one of the more complicated problems with that chassis, so the set should be looked at by someone experienced with the RCA 195 chassis.
RCA p46732ba projection TV no power.
This is a common problem and the set is in shutdown mode. It attempts to fire up three or four times (the chirp you hear) if it detects a fault it shuts down - the most likely cause is the HV (high voltage) block- caution working on it since HV is present - The repair generraly costs $200-400 P# 205064
Google your model # and HV block to see what I mean.
Oct 06, 2009 | Televison & Video
RCA 31" TV pakes high pitched chirping noise
Did you check the Horizontal Output transistor to see if it were shorted, and also check the MOSFET of the switching power supply.
Jul 25, 2008 | Televison & Video
Samsung PCL542R Chirping noise
There is problem in sound IC. First check it
Feb 17, 2008 | Samsung PCL5415RB 54" Rear Projection...
TV makes chirping noise, won't turn on!
That usually means a problem in the start up or deflection circuits. Diode, Horizontal ouput or driver transformer. What Chassis is this set, and I will be ableto give you some better information. Rca , GE and phillips need to be diagnosedwith the chassis number. Let me know the chassis.
Jan 25, 2008 | Televison & Video
No picture on screen, chirping noise every second from back
again a good set the deflection modules on these sets are pretty reasonable you need to have a tech swap it but i highly suggest that than a new one the chirping is the set trying to start up but going into shut down
Dec 02, 2007 | Samsung HC-P5241W 52" Rear Projection...
TV wont come on
some electronic components inside your TV had shorted out! you might be hearing a slight CHIRPING! like the sound of crickets! or maybe whining! the sound migth be coming from the transformer/inductor with a shorted component on its output!
Nov 16, 2007 | RCA F32650 32" TV
No picture or sound - TV makes chirping noise
Rich that chirpin noise is somthing over loding it try checking your horzotal output for short and diodes around the transformer...
May 20, 2007 | RCA P60921 60" Rear Projection Television
TV will not switch on
It sounds like you may be on the right track. Also you could have a problem in your Horizontal Deflection circuit. Since you say it flickered, you may have a solder joint that was arcing. Probably in the horizontal circuit. I found a capacitor which was arcing in this circuit. I was a small disk type. NOW since it is chirping, the horizontal output transistor may have shorted placing too much of a load on your power supply. The noise you hear is the power suppply trying to start. Stargazer
Jan 29, 2007 | Philips 32PW6506 32" TV
RCA P52937 52" Rear Projection Television Logo
152 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
