Question about Samsung SyncMaster 204B (Silver, Black) 20.1 inch LCD Monitor
My P2270 HD monitor suddenly only shows picture for few seconds when switched on then goes blank but has sound??
jitenok
  • 151 Answers
SOURCE: 174v monitor not weorking
check power section.check pf capacitors in this section for ok or replace them.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Posted on Mar 21, 2008
peping
  • 99 Answers
SOURCE: screen suddenly goes blank
when you open your pc now,do you still hear a click sounds like you hear before ,when your computer has no problem yet? now there is no sounds .do the ff..
1.try to press the numlock key and observe it ,if the indicator LED lite on and off,the problem of your computer is your video card,
2.if you can't hear anything, when you open your unit and the indicator of your monitor goes the color orange,pls..check your memory .clean the memory and the memory slots using the contact cleaner .before you replace a new memory.
3. and try to use a another monitor,maybe your monitor has the problem.
Posted on Apr 01, 2008
  • 1684 Answers
SOURCE: i have a samsung monitor when we switch off the
This is a very common problem on many LCD monitors after a few years of use. If you can solder you should be able to repair the monitor yourself. The problem is caused by blown capacitors on the power board. Go to our web site at : www.ccl-la.com/badcaps.htm We have pictures of what to look for. Open your monitor and look at the power supply board for any blown capacitors, replace all that you find. The replacement parts can be ordered from several places on the internet or we can supply them for you. The replacement parts will need to be high temp and will be marked 105c. The values you need to get will be marked on the sides of the ones you take out but will be something like 220uf, 470uf, or 1000uf etc. and then a voltage rating. When you install the new ones be sure to insert them with the polarity stripe going the same direction as the old ones come out. If you don't want to do the repair yourself we do offer a repair service for $35 plus return shipping. If you have any questions just let us know
I hope this helps if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Posted on Oct 24, 2009
SOURCE: Monitor goes blank after 3 seconds -Samsung SyncMaster 920NW
hello i have the same problem, there are 4 lamps (bulbs) inside the monitor when some of them falls the system turn off, cheks and good look
Posted on Oct 27, 2009
  • 541 Answers
SOURCE: When turn on, get a picture for a fraction of a second then blank
you need your power supply repaired. you have bad capacitors.
Posted on Jan 01, 2010
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - CCM.net
ccm.net > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from ccm.net
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
Dec 20, 2015 | LG Televison & Video
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
Source(s): http://lcdmonitorrepair.annics.com
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
Monitor flickers and goes blank after 5 seconds and keep repeating this very often.
If you turn the monitor off then about 1020 sec turn it back on and have a picture for five sec again it sound like the power supply in the monitor. but if that did not solve the problem, the picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault and will need to be replace.
I advice you replace the picture board on the screen of your monitor to solve the problem of the blank screen.
Take care.
Jul 26, 2010 | Acer AL2016W 20" LCD Monitor
Screen goes blank when first turned on, have to keep restarting m
Take care.
Jul 24, 2010 | Dell E153FP 15" LCD Monitor
Picture comes on for a couple seconds, then goes blank
You may have bad 24vdc power supply or bad back light inverter boards.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jun 29, 2010 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
PL 9 19" CRT Monitor: my mag innovision lt716s 700p monitor screen keeps...
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 06, 2010 | CTX PL 9 19" CRT Monitor
Screen goes blank after 5 seconds switching on
The picture board on your monitor is bad, since it goes blank after five seconds, it shows that the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 25, 2010 | Proview PX 780 Monitor
Samsung SyncMaster  204B (Silver, Black) 20.1 inch LCD Monitor Logo
18 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
