Question about Maximatic Deluxe Popcorn Trolley Popcorn Maker
Kettle for popcorn machine model # epm400 - Maximatic Deluxe Popcorn Trolley Popcorn Maker
Why is my gold medal popcorn model # 2552 machine not heating to pop popcorn anymore?
A kettle not heating is either a switch, kettle wires, thermostat, or kettle heater.
Check that the kettle is plugged in tight, notice if the switch lights up when switched, then contact your local gold medal dealer for repairs. It is always cheaper to repair a gold medal kettle than replace.
http://www.gmpopcorn.com/domestic-dealers.cfm
Oct 01, 2014 | Gold Medal Kitchen Appliances - Others
Gold Medal Deluxe Pinto Pop Popcorn Machine Model 2147 will not heat up
If the switch is OK and you have. Power at the kettle plug and you are not getting any heat it's one of 3 things. Burned wire inside the kettle. this is common. Or it could be the thermostat is bad or the element itself is out?
May 07, 2014 | Gold Medal Products Gold Medal 2147 120208...
Will thermostat stop kettle from overheating and blowing thermal fuse
The thermostat built into the kettle stops the kettle from heating at a prescribed temperature. usually around 425 F. This is hot enough to smoke and cause instant burns, but is the required temp for popping popcorn.
I do not know of a "thermal fuse" built into popcorn machines. Mechanical thermo stats are not flawless. they can and do malfunction, either too cold or too hot. the model popper you have is not adjustable, or repairable.
If you are tripping a electrical circuit breaker that is a different problem not related to kettle heat. It is a symptom of an overloading problem of your outlet, or a ground fault in the popcorn popper.
Jan 09, 2014 | Nostalgia Electrics KPM-508 Popcorn Maker
My BELLA Theatre Popcorn Maker is not heating up. The popcorn kernels dont pop and the kettle is not heating up This is just the second time I used it. What is the problem???! Thanks
double check the kettle is firmly plugged in. If it is and not heating return to store. there are no repairs for that model machine.
Nov 26, 2013 | Kitchen Appliances - Others
I DO NOT HAVE COOKING INSTRUCTIONS FOR MY KPM-508 POPCORN POPPER
The instructions say make sure kettle motor is plugged in. Turn unit ON with switch on crown of machine. Allow unit to run for 3-5 minutes to heat up kettle. Turn unit off. Add 2 teaspoons of your favorite popcorn cooking oil to the kettle. Then add 1/4 cup of popcorn kernels to the kettle. Turn the unit on and close the door. When popping sound slows down turn the unit OFF. Flip the kettle over with the crank handle to empty the kettle. Repeat process until desired amount of popcorn has been popped.
Jun 09, 2011 | Nostalgia Electrics Helman Group KPM-508...
The popcorn gets stuck in the kettle until it burns
I have a Popcorn machine from Nostalgia too that had this problem. I cleaned it out and everything but it still had the problem of the it getting stuck. After days of analizing, I found the solution. after a while the ceiling of the popcorn machine starts to fall in, lowering the handles of where the kettle goes. making the knob that turns being lower that the one that makes it turn, causing it to get stuck, all I did is add so leverage so the kettle is once again at the same level or higher. Making it turn with greater force and not getting stuck. In other words make sure the turning mechanism is leveled and not one lower than the other. preferably the kettle part being higher.
Jan 09, 2011 | Nostalgia Electrics Helman Group CCP-509...
Need model number for Gold Medal popper
http://www.concessionpalace.com/concession-tutorials/P-60_60_Special_Uncle_Walts-1866_2085_2086_2656-popcorn-machines.pdf
Sep 01, 2009 | Gold Medal Kitchen Appliances - Others
Part for Echols popcorn machine
I Have A Echols Popcorn Popper and Would like to know how old it is the serial no. is 86P101
Feb 28, 2009 | Cretors Goldrush Popcorn Maker
Maximatic Deluxe Popcorn Trolley Popcorn Maker Logo
Top Maximatic Kitchen Appliances - Others Experts
George Merkley
George Merkley
raysaw
Irene Tulloch
Are you a Maximatic Kitchen Appliances - Other Expert? Answer questions, earn points and help others
