Question about Whirlpool LER4634J Electric Dryer
A white piece of insulation or maybe a gasket came out of the dryer, how do i fix it.
    Novelist:
  • 161 Answers
This sounds like the drum seal gasket, about 2 in. wide. The drum has a black rubber type gasket and the gasket you found is attached to the dryer. You will have to remove the drum to replace this gasket.
If you want to DIY, I can give more info.
Posted on Jan 22, 2009
My 1990 ford ranger 4 speed w overdrive keeps overheating. thermostat good waterpump good. when overheating overflow is boiling and bubbling
maybe bad head gasket causing bubbling in over flow tank
if level is going down you might see white smoke from tail pipe,
wet spark plugs or engine oil looking like coffee.
hope this helps
Apr 17, 2016 | Ford Cars & Trucks
I can see a piece of insulation hanging down in between glass on the oven's front door. Is this dangerous?
No this will not be a problem.
That insulation will not set fire, maybe blacken but the heat inside the glass is actually less than anywhere else the insulation maybe.
Do not try to fix this yourself as the glass is very fragile when handled incorrectly.
Leave it as is if it doesn't bother you.
Apr 05, 2013 | Kitchen Ranges
Changed O2 sensors and white smoke starts pouring out of exhaust
White smoke is usually steam which would indicate a blown head gasket or crack in block. Hope it's something easier.
Jan 15, 2013 | 1999 Ford Taurus
97 Saturn sc1 fixed haed gasket and it's still blowing white smok, what could it be?
water getting into cylinders causes white smoke maybe a crack in cylinder head any misfiring from engine
Oct 21, 2012 | 1997 Saturn SL
Need to repair a cut wire going from the left ear cup to the right ear cup
In fact the insulated inner wire (the white tube) is the signal carrying wire.
The outer wires without insulation are connecting ground (GND).
Both wires have to be connected to the speaker in the ear piece in order to (re-) build a circuit.
Jul 12, 2017 | Audio Technica ATH-A900 Professional...
I have an error 04 showing on my dishwasher, and the cycle will not run. Please help!
dryer damper problem. there is another post that will help from electrolux personnel.
Thank you in advance for allowing Electrolux to assist you in
this matter.
I apologize for the inconvenience and concerns this dishwasher unit has been causing you. Unfortunately the error "E04" code does indicate an issue with the drying damper. Now this is something that a technician would have to assess because wiring is needed to be checked.
Check wiring between Main Control Board and upper fan. If correct, replace upper fan.
If your unit is brand new it is covered under warranty and you can choose to contact your dealer for a repair technician, or visit www.electroluxappliances.com/servicelocator to find a listing in your area.
Kindest Regards,
Chris Polk
Online Outreach Representative
Electrolux Major Appliances
Er 01
Leak Detector - When water is detected under
the tub.
Er 02
Thermistor - When thermistor/turbidity module
fails
Er 03
Wash Pump - Wash pump not operating
Er 04
Drying Damper - Drying damper not operating
Er 05
Upper Fan - When in the dry cycle, the control
board does not receive proper speed feedback
from the upper fan
Er 06
Lower Fan - When in the dry cycle, the control
from the lower fan
Er 07
Drain Valve - When in the drain mode, the control
board does not receive proper position feedback
from the drain valve
Er 08
Tactile or touch switch - Control board has
verified a switch on the user interface is bad or
shorted
Er 09
Communications - Communication failure between
main user board and power supply
Er 10
Mains Relay - Failure in the mains power relay
Er 11
Drain Valve - Time out before finding a state for
the drain valve
Er 12
Drain Valve - The drain valve is running when it
should be off
Er 13
System wide - Lost control of the State Machine
Jun 23, 2011 | Electrolux Dishwashers
My 2004 grand prix gtp is loosing anti freeze some where. I topped it off and filled the overflow tank about 3 weeks ago. The over flow tank is now empty and the check engine light is on for low coolant. I...
A head gasket would mean white smoke out the exhaust.
You may have to change the thermostat.
Check water pump flowing fluid thru radiator.
See my tips section for heat troubles.
Feb 08, 2011 | 2004 Pontiac Grand Prix
New gasket but no screws on door
I would purchase a new gasket and that will tell me how it is fixed on either glue or screw.
Apr 12, 2017 | Kenmore 53603 / 53606 Stainless Steel Side...
Engine is overheating ,radiator is bubbling, and white smoke from my rear head. blown gasket? or cracked head. and what is the best stuff to use to fix blown gaskets
Blown head gaskets for sure, no way of knowing if heads are cracked without taking it apart, there no quick fix for this, only fix is to take it apart and repair as needed.
Jul 08, 2010 | 1997 Buick.5 Regal
I have a Porcher one-piece toilet with a bad gasket. How do I take it apart and replace the gasket?
if you are talking about the wax ring you remove the floor mounting bolts and replace the wax ring under it. first you want to shut water off then flush to empty tank and with a wet dry vac remove any water left . now you can remove it without any mess.
Jan 05, 2010 | Porcher 40050 Classic Elongated Toilet...
Whirlpool LER4634J Electric Dryer Logo
62 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
