Question about Xerox Phaser 8400 Laser Printer
Xerox 3545 offline
Just add fios yesterday and now I can not print on either my pc or mac.
    President:
  • 2,072 Answers
Did you set the IP address to Manual ( Static) to set up a permanant IP address? If you left it on auto and DHCP settings wrong, it will search and reset the IP address. Run a configuration report and check to see if you IP address has changed, I bet it has.
Posted on Jan 22, 2009
  • Rick Kasper Jan 22, 2009
    Ahhh I forgot also. Look in the network settings make sure ON line is selected, also turn the IP filter OFF.
    That machine does not have a seperate NIC card, it is built into the network. If your data lights are on, and the machine prints out reports, I can guarantee the problem is NOT the machine, that is an exceptionaly reliable network board, any problems in it booting up would result in a fault code displayed on the machine.
    Can you ping the printer ? I suspect an address change.
HOW TO RESET ERROR CODE 04-562
Not a copier guy here BUT came up with this
1) From here
http://www.copytechnet.com/forums/xerox/43094-error-04-562-workcenter-pro-c3545-print.html
It sounds like 'Image Belt Transfer' whatever that is.
'you can enter in serice mode on this model only with laptop and xerox wcp diagnostic navigator'
2) from Zerox here. http://www.support.xerox.com/support/workcentre-pro-c2128-c2636-c3545/support/enus.html click on fault code search , put in code.and......
'Needs further customer support.'
Sounds like a 'belt' inside the machine broken or faulty.
Hope this assists you.
Sep 16, 2014 | Xerox Copier Toner, C2128, 2636, 3545...
Printers driving me crazy; I have three HP printers and none will print for me now
To Add and set as Defult Printer Go to system Preferences>Print and Scan > "+" symbol on left corner and add the printer.
when you give a command of print there you can see the list of printers and you can select the printer you want to print from.
Oct 29, 2011 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
I have a mac book and have always successfully been able to print wireless. The scanner however would never work. Yesterday I needed to scan a document so i plugged the printer into my mac and scanned...
Check the settings on the printer to see if you have to switch from scanning to printing, also if you have the original setup disk for the printer just run it again and that will solve the problem.
Mar 19, 2011 | Computers & Internet
Printer says offline
Try to refresh the Print Queue. Go to System preferences then select Print and Fax. Highlight NX100 and click on the minus sign ( - ) to delete the printer. Re-add the printer by clicking on the plus sign ( + ).
Apr 10, 2010 | Epson Stylus NX100 InkJet Printer
Mac OS 10.6 Snow Leopard: Printer Driver Update for Xerox Phaser 6110 does not work ! Xerox/Apple is providing a most complicated instruction to circumvent the problem that I am not able to...
    1) Change the “Xerox” Folder Permissions:
    • Navigate to Applications > Utilities and open a Terminal window.
      • Type the following command: sudo chown -R root:admin /Library/Printers/Xerox
    • You will be prompted to enter your password.
    2) Install Rosetta from the Snow Leopard DVD:
    • Insert the Snow Leopard Install DVD
      • Select Optional Package
      • Select “Rosetta only” from the list of optional packages
      • Click install and follow instructions to complete installation; there is no need to reboot
    3) Reset Printing System:
      • Navigate to: System Preferences> Print & Fax> Xerox Phaser [6100, 6110, 6110MFP]
      • Right click on the printer
      • Select Reset Printing System
    4) Install Printer (without removing the driver):
      • Select +: add the available Xerox printer
Mar 18, 2010 | Xerox Phaser 6110 Laser Printer
After one print, it goes Offline
Turn off the SNMP option in the TCP/IP printer port Properties
Right-click the printer, select properties
Select port tab, highlight port, click Configure Port
UnCheck SNMP status Enabled.
This fix was given to me from Xerox Tech support.
Good luck
Nov 18, 2008 | Xerox Phaser 3200MFP/N Laser Printer
Printer is offline.
hi iam kishan from india do one thing if u have a driver cd of your priner disconnect printer and go to control panel clik on add/remove program remove all driver oand sofftware of your printer and restart ypur pc and after restarting insert cd in install software of your printer do no connect printer untill computer want or connect after finnish i
Jan 12, 2007 | HP Deskjet F340 All-In-One Printer
Xerox Phaser 8400 Laser Printer Logo
476 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
