Question about Logitech 967437-0403 Keyboard
How do I set the clock and date on my MX 3200 keyboard?
  • Robert Alesiani
    Robert Alesiani Feb 11, 2009
    Thanks to those who replied... I figured it out. One must:
    1) Push and hold down the function key (to the right of the space bar) while hitting the F10 key. This will start the hour LED flashing.
    2) Using the number pad, one can type in the hour.
    3) Use the right arrow button () or F10 key to tab over to the minute LED.
    4) Again, use the number pad to type in the minutes after the hour
    5) Use the right arrow button () or F10 key which will take you to the 12 hour or 24 hour (military) mode for showing the time (3:51pm vs 15:51)
    6) Use the right arrow button () or F10 key again which will flash the month LED. You can use the up or down arrows (↑↓) to change the month.
    7) Use the right arrow button () or F10 key to tab over to the date. One can use the number pad to type in the date, or the up or down arrows (↑↓) to scroll to the date.
    8) Lastly, use the right arrow or F10 key to close the application.
  • 51 Answers
Easy go down to the right bottom corner of your screen and right click on the time and hit set date and time and do it.
Posted on Feb 11, 2009
How can I set the correct date and time on my Logitech MX 3200 wireless keyboard?
"To enter time/date setting format on the keyboard LCD, press the FN key and F10 key simultaneously." Also "LCD: Mode (F9): switch mode from Time/Date to Alarm to Timer to Character Count. Set (F10): press to set Time/Date, Alarm and Timer. Change batteries one by one to keep LCD settings. Remove the 4 keyboard batteries to reset Character Count to "o." Bell (f11): put Alarm On or Off. START/STOP (F12): start 01 pause Timer." The Logitech program group (should be on your Start menu) will give you further information for identifying keys, and for formatting the keyboard and mouse. Good luck.
Nov 10, 2009 | Logitech Wireless Access Duo Optical...
Tip
How to adjust the LCD's time and date on Logitech MX 3200
To adjust the LCD's time and date:
  1. Make sure that the time and date are shown on the LCD. If necessary, press (FN + F9) until the time and date are shown on LCD.
  2. Press (FN + F10). You are now in 'Set mode' (you can exit this at any time by pressing the Esckey).
  3. Set the correct hour by either typing the numbers on the numeric pad or using the cursor up and down keys, followed by Tab or Enter.
  4. Set the correct minutes by either typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
  5. Choose either 12-hour clock or 24-hour clock by pressing the cursor up or down keys to switch between the options. Then press Tab or Enter.
  6. Set the correct month either by typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
  7. Set the correct day either by typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
The time and date on the LCD should now be displayed properly.
on Nov 10, 2008 | Logitech Cordless Desktop MX3200 Laser...
CLOCK RESET
Press the FN + F9 keys until the time and date appear on the LCD display.
press the FN + F10 keys to go into the Set Mode.
Use the left or right arrow keys to select the hour.
Change the hour by using the number keys on the keyboard or by up and down arrow keys
Use the right arrow key to select the minutes and change the hour by using the number keys or by using the up and down arrow keys Press the right arrow key again to choose the 12-hour or 24-hour format with the up and down arrow keys.
To change the date, use the right arrow key again and use the up and down arrow to select the month. To change the day, use the right arrow to select and the up and down arrows to change the day.
When you are finished, press Enter on the keyboard to exit Set Mode.
hope this helps
Apr 02, 2009 | Logitech Cordless Desktop MX3200 Laser...
How do i set the clock on my mx 3200 keyboard?
To set the clock and date all you nee to do is have it on the clock and date mode. If you have it on a different mode hold the function (FN) key and press mode (F9) to toggle through each of the modes until you get to the one you want.
Then, to set it hold the function (FN) key and press set (F10). Next type in the numbers that you need for the hour time, then the min, then select 12hr clock or 24 hour clock with arrows, then select the month with the arrows, and finally select the day with the arrows. pressing enter to get to each step respectively. don't forget to rate me
Feb 02, 2009 | Logitech Cordless Desktop MX3200 Laser...
I can't set the date and time on the keyboard
1st, if your time display is not shown on the LCD, press FN and F9 at the same time until the display appear. Then press FN key and F10 key at the same time to go into SET mode. Use the arrow key to select and set your correct time. Press ENTER when done.
YBC (/\)
Jan 23, 2009 | Logitech Cordless Desktop MX3200 Laser...
I cant set the clock on my keyboard
To enter the time/date setting you must press the FN key
then to set the date/time press the F10 key.
I hope this solves your problem. If not please check the forums.
Dec 15, 2008 | Logitech Cordless Desktop MX 3000...
Set correct time on Logitech MX 3200 wireless keyboard
Cordless Desktop MXTM 3200 Laser
Dec 31, 2007 | Logitech Wireless Access Duo Optical...
MX 3200 Cordless Laser Keyboard - Logitech
Press the FN key and *at the same time* press the F10 key for 1 second.
The first part of the time should start to flash.
Use the up / down keys to change the hour, then press TAB. The minute figs. should now flash. Use up/down to change the minutes and press TAB.. do the same with the date and month etc, you can also set 12h or 24h clock.
When you are finished press ENTER.
Nov 24, 2007 | Logitech Cordless Desktop MX3200 Laser...
Mx3200 clock re setting
Hold down FN and F10 which says set in blue. This allows you to reset the clock.
Nov 04, 2007 | Logitech Cordless Desktop MX3200 Laser...
Logitech 967437-0403 Keyboard Logo
238 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
