Question about Gaggia Paros Espresso Machine
Spout for frothing milk pops out
I cleaned the spout for frothing milk in my gaggia paros espresso machine and had a hard time making the plastic spout "snap back" in place such that when i froth milk, the plastic spout pops into the cup of milk.
  • 1 more comment
  • Anonymous Mar 15, 2014
    my milk frother is spouting out hot water, with some milk. was working yesterday, today its not! Ive descaled and tried soaking the spouts.
  • Anonymous Mar 25, 2014
    Coming from spout in thin stream,have cleaned thoroughly, still not working dehlonghi
  • Anonymous Mar 29, 2014
    Milk boils but doesn't froth
I am from Puerto Rico and got my Handpresso through Coffee World Puerto Rico: www.coffeeworldpuertorico.ecrater.com I received my Handpresso about a week ago. The first expression is that this Handpresso is just nicely built, as well as the case. Making espresso is very easy, and it takes a minute or so to make a cup. I was impressed with the coffee. Believe me for a portable machine, coffee was great. Now my Handpresso substituted my Krups machine. I use Island Joe's ESE pods and Lavazza Grand Crema. A good hint is: to make sure the espresso has an ok temperature, I heat up my cup as well as the water container adding the boiling water and then adding the water to make the coffee. I always fill a bit more water (a few drops more) so the ESE pods gets soaked before extraction. And it really takes about 30-38 pumps, no big deal. With this I get a great espresso and crema too. I recommend buying ESE pods buy bulks of 100 or 150, it gets cheaper. The unit works best with the standard 7g E.S.E pod.
Posted on Jul 01, 2009
  • 944 Answers
You can get the user manual on this link if you need it; http://www.gaggiaparos.co.uk/ Check page 6 of the download, page 12 of the manual - the spout should just pull off and push back on. If it wont, then either something needs cleaning more, something is stuck in the tube or more likely the part of the nozzle that comes off, something is broken, or you need to use a little bit more force. If it appears broken, (check in particular for a fine crack that is only visible when the nozzle is stretched i.e. when in place. This type of plastic often will close a crack enough to be near invisible when not under tension.) then you could try gluing it although i doubt if this would work. You could just put a stainless steel hose clamp around it, tighten up just enough to make the nozzle spout stay on (bit of a pain, but may work). You can contact gaggia for a replacement - in the USA; Importika 596 Fishers Station Dr. 14564, Victor, NY Mr. Salzman Ph. 585.742.5178 Fax 585.924.1499 web site: www.importika.com e-mail: [email protected] Hope this helps - if you can post back a photo or two close up of the problem area, i may have more ideas :)
Posted on Jul 05, 2007
SOURCE:
Cafe barista not frothing
the frother gradually gets milk buildup and loses suction- an air blast through the milk tube and up the spout (can get an aerosol at hardware store) will help as well as the cleaning cycle. Also I used a q tip to the top of the spout several times but just had the q tip top come off and may have blocked it completely
May 05, 2014 | Sunbeam Mr. Coffee Cafe Barista Espresso...
DISPENSING SPOUT ON ECM20 IS CLOGGED
It's probably clogged up with hard water deposits. Fill the water reservoir with plain white vinegar and put the espresso pot in place as usual, but do not load coffee! Run as usual for making espresso.You may have to run a couple of tanks, until the vinegar is pretty much colorless. Then run a couple of tanks of water to flush the vinegar. If your machine has a steam valve for frothing milk, put the steamer pot under it and open the valve as well. Over time, the steam valve can clog up with milk solids, called casein, which is actually a form of organic plastic.
Dec 08, 2013 | Mr. Coffee ECM20 Espresso Machine
My Gaggia classic has suddenly stopped frothing
Hi There,
You are not getting enough steam, to produce the froth and there no blockage. I suggest you replace the thermostats. Takes 10 min max.. Gaggia thermostat set
Sep 28, 2017 | Gaggia Classic Espresso Machine
Delonghi magnifica promblems with water and milk
Frothing jug
For milk frothing issues, soak the milk jug cover in hot water and rinse several times. If it has a froth control that can be removed by sliding in the direction of travel towards the edge whilst jiggling it gently up and down. Clean off the little o-ring with a toothpick, be gentle. The control should easily slide and click back in place when done.
Froth still no good? Examine the milk coupling to ensure the o-rings are in the right spot and are pliable and undamaged. There should be an o-ring (usually green) on the top spigot, a (black) o-ring at the front of the bottom spigot and a (red) oring at the rear. The groove halfway along the spigot should be clear. Now with the toothpick and a hot moist cloth clean all the crud from the milk coupling, especially inside the smaller spigot. Check the tiny hole at the back of the larger spigot is not blocked.
Check the flow from the hot water spout is good. If not, there are internal issues, try descaling. If it is, test the frothing jug, if it is still weak either the jug cover or the milk coupling needs to be replaced. Get them to try a known good test jug at your local coffee service center to find out which, most will be happy to do this at the counter.
Jan 19, 2012 | DeLonghi Esclusivo Magnifica ESAM3300...
Hi, the steam from the wand is not frothing the milk like it used to, hardly any froth at all.
If the frother is warming the milk, but is not frothing, then you want to make sure the panarello is clean.
Slide the cover off the frother and check the pin hold on the top edge of the cover. If this hole is blocked the milk will not froth. Rinza is great clean to help prevent these issues. http://www.cerinicoffee.com/rinza_urnex.asp
Also recommend frothing water instead of milk to clean the frother well.
For more information visit: http://www.cerinicoffee.com/Coffee_cleaning_supplies.asp
Jun 07, 2011 | Gaggia Brera Coffee Maker
My cva 4070 is only providing steam when I request milk froth. How can I fix this problem
your frothing mechanism is clogged with dried milk. The chrome spout and black rubber hose come off by turning the plastic collar and pulling down. refer to your manual for pictures and step by step cleaning and maintenance instructions. your machine came with a cheat sheet card that is yellow and has a clear plastic laminate over it. it was in the box with the accessories. refer to that for an exploded view of your frothing mech.
May 10, 2011 | Miele CVA4070 Coffee Maker
The milk frother just boils the milk and does not froth it up any more
Hold the frother arm and pull the lower section off (It is in two pieces ) With the lower part off use a chopstick or something similar to push the small plastic nozzle out from the lower section,push from the narrow end .It will come out with a click,you will probably find it is blocked with dried ?congealed milk. Leave it to soak inhot water/wash up liquid and then use a nail brush to clean it also clean inside nozzle . Press nozzle back into sleeve untill it clicks into place and replace
Jan 21, 2011 | Gaggia Classic Espresso Machine
The steam wand is bubbling the milk, not frothing
THere is a little black tube inside - make sure its pushed out enough - about 1/16 an inch from the bottom. And you may have to clean it out. Happens to us too and after I do the above it works
Feb 13, 2010 | Gaggia Titanium Espresso Machine
Gaggia Paros Espresso Machine Logo
287 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ekse
Marvin
Marvin
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
