Connection For NEC Versa 2650CDT CD Drive?
What kind of connection does this laptop use for it's cd drive? I've never seen one like it.
It does not boot from cd
Hi. Keep on tapping F12 key while computer is booting up. It should gives you boot options. Select the DVD Rom drive and make sure that the bootable disk is inserted to the DVD drive.
Sep 01, 2010 | NEC Versa VX Notebook
I have a laptop NEC versa Note serial: 116700069, part no: PC-709HB211552X I want to ask is, why the laptop is not in use to connect to the Internet. I have been using MODEM (local) type CM300 Cheers. if I...
OK when you use external modem you have to creat a new net connection. and there you make it default modem. but follow the. 1st uninstall your external modem, restart, then run external modem set up after a while your system ask for modem that time you connect your modem and follow the instruction. then restart your pc. after that create a new connection point for net connecting and make a default with these modem, restart ur system. after that you can connect your net i wish.
Jan 30, 2010 | NEC Versa Note NB 6/233 (VN230020-000000)...
Nec versa want to downgrade from vista to xp but booting from xp cd it does not detect harddrive, why? what can I do about it?
Sometimes booting from XP disk wont detect your hard disk,the problem is because the IDE driver which is needed for the identification of the hard disks are not at all avaible with the XP CD. So u have to download the corresponding IDE driver for your hard disk and then u can install that from the floppy drive during the installation . I think on installation XP set up will ask for a driver installation (third party installation). U can do this by using a floppy disk . If the floppy drive is not all available in your laptop then u can use softwares which can mix the IDE driver along with the XP set up U have. A lot of softwares are available for download for this purpose
Thank u and please rate my solution
Oct 22, 2009 | NEC Versa FX Notebook
Need to get photos from floppys to CD ? My NEC Versa PB100 does not have floppy drive , does have CD Burner Regards Kevin
A USB Floppy Drive can be purchased and used with a Laptop. I bought mine at Best Buy. Another way would be if you have both computers on a network and have enabled File Sharing!
Oct 11, 2009 | Computers & Internet
Hi... i lost my cd and i cant find any drivers for my nec versapro VY22S/RF-L laptop.. please tell me where to get the graphic driver of this??? thank you
If you still have the recovery partition on your hard drive, boot whilst holding the f11 key, this will start NEC recovery and will allow you to reinstall the system, drivers included. If not, you'll have to visit:
to download the drivers you need. Good luck!
Jun 06, 2009 | NEC Versa Premium Notebook
I want to restore to factory state but boot cd won't work
I think your hard drive which is a SATA drive, needs to be formatted specially for Vista.
you need to find out the make and model of your hard drive,and then you can download a hard drive formatting utility program from the hard drive manufacturers website.
The hard drive is accessed from under the keyboard on this model.
Jan 30, 2009 | NEC Versa VX Notebook
How to take the Operation System back?
You cannot do anything but to get a Windows cd and reinstall your os.
Simply get a cd, put it in the cd drive, put on the pc and press either f8 or escape or even f12 to get to the boot selection mode, then choose your cd drive and let it boot to the cd.
When the windows install comes up, choose your desired options and let it install, when it reboots let it boot to your hard drive and let it do it`s thing.
Any info it needs, provide it and soon you will have a new windows installation.
Oct 30, 2008 | NEC Versa FX Notebook
Formate window xp in NEC laptop
I suppose the upgrade was a success. Then go to the boot sequence on the bios and set it to the cd rom. but make sure that the cdrom is working fine, meaning try to install it on a differn computer and see if you can play audio cd on it to see if its working or not.
Aug 22, 2008 | NEC Versa LX Notebook
Nec versa sx dvd upgrade
just check the jumper drive should be master and one should be slave.if you have two empty ide slots then you can put one on each.
Mar 26, 2008 | NEC Versa SX Notebook
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
