Question about NetGear WGR614 Wireless Router
Netgear WGR614 v6 router drops connection
Ok, so I've had this router for about 1 and a half years. Just recently the internet connection started dropping like every 5 minutes so i have to power cycle it and it works for about another 5 minutes. The wireless light, internet light, and the 1 port light will al be on....and then the internet light starts flashing and then drops the connection....the wireless light goes out but the internet light stays on and all 4 port lights are on when it drops the connection. I tried changing the channel and that didnt work so I don't know what to do.
  • 55 Answers
Hi, what ISP are you using (aol,tiscali...?), and how are you connecting to the router? Wired or wireless? I had similar problems with mine, it wouldn't connect or would drop connection, or loose all the settings. I updated the firmware to the latest from here:-
http://kbserver.netgear.com/products/WGR614v6.asp
Be sure this is the correct model as firmware differes from model to model.
Then I had to manually configure my ISP settings etc. Or you may have software from your ISP which configures for you.
Hope this helps.
Posted on Jan 25, 2009
Cannot restore factory settings
You need to consult a qualified Technician.
Apr 17, 2017 | NetGear WGR614 Router
Trying to set up a netgear access point with a moterola surfboard
Try doing a hard reset on the Netgear router then powercycle it together with the modem
Mar 07, 2010 | NetGear WGR614 Wireless Router
WGR614 v6 Fails to connect to internet, no wirelss signal
mabey there is a problem with the LAN cable or a connection error
Dec 12, 2009 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Could not make router to work, Netgear modem adding router.
i suppose you have to connect modem to router's "source" socket and modem to socket "in wall" then reset and reconfig router and you should be ok
Nov 10, 2009 | NetGear WGR614 Wireless Router
Drops the internet connection and has to be rebooted at least once a day.
Try to reduce the MTU of the router. If you're on DSL, set the MTU size to 1492, for Cable connection size is 1400 or 1463. You can do it on the router's admin page http://192.168.1.1
May 11, 2009 | Belkin (F5D7230-4) Router (587009)
Netgear wgr614 v6 As Bridge for XBOX
I'll take a stab at this. It's a bit difficult because I don't know what your level of expertise is. You're actually using the Netgear wireless ROUTER not a bridge. Your ISP can use a couple of methods to give you service. DSL companies like Verizon probably use PPPoE which require you to login and provide a password and VZ is notorious for closing down port 25.
O.K. Did I mention I don't like them very much? Anyway, I'm going to give you a link to Netgear's excellent web site for configuring a router and the XBOX connection. This is the whole list of v6 compatible instructions. Note the very bottom link to use Netgear routers with XBOX.
http://kbserver.netgear.com/products/wgr614v6.asp
Note under the Troubleshooting topic that there is a configuration and two setup files, depending on what you're connecting to, and some tips on what to do if it doesn't work.
It's not as bad as it looks.
Carl
Jan 04, 2009 | NetGear WGR614 Router
Losing connection with WGR614 v6 router
Well, glad I found someone with the same problem, the answer will certianly surprise you.
The answer is cordless phones and satellite interent.
if you have cordless phones and/or satellite internet it will lose signal.
They run on the same frequency.
To fix it log into your router, goto wireless settings, then check the box for enable channel settings. You may have to reboot the router and PC.
Should help.
Good luck and have a happy new year.
Dec 27, 2007 | NetGear WGR614 Wireless Router
How to install with out the cd?
Are you using XP? You shouldn't need the CD.
http://www.netgear.com/Home/Products/Adapters/GWirelessAdapters/WG111.aspx
Gives you information about the USB adapter.
http://www.netgear.com/Products/RoutersandGateways/GWirelessRouters/WGR614.aspx
That gives you information about your wireless router.
Do you need a manual to set this up? It looks like there are different version of this wireless router. Which one do you have? This can be identified on the package or the unit's bottom label.
Once we know which version you have we can continue.
Dec 11, 2007 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Logo
932 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
