Question about Creda W100FW Front Load Washer
Machine keeps stopping
My machine keeps stopping mid cycle with the run and end lights flashing do you know what the problem is please
I bought a new washing machine but thanks anyway
Posted on Jan 24, 2009
3 Suggested Answers
  • 10 Answers
SOURCE: CREDA W200FW
DOES IT STILL HAVE WATER IN IT,IF SO IT COULD BE THE SUMP HOSE BLOCKED OR THE PUMPITSELF BLOCKED,OR THE PUMP MAY HAVE FAILED (LEAST LIKELEY)
FIRST DISSCONECT IT FROM THE MAINS,THEN
SHOULD BE AN EASY FIX,TURN THE MACHINE AROUND AND TILT IT FORWARD,REMOVE THE BACK PANEL AT THE REAR OF THE MACHINE,IF IT STILL HAS WATER IN IT THEN PUT A BOWL UNDER IT,AFTER REMOVING THE PANNEL YOU WILL SEE A BLACK HOSE WITH A JEWBILIE CLIP AROUND IT,UNDO THE CLIP AND SEE IF IT HAS ANYTHING IN IT (KIDS SOCKS ARE COMMON),IF SO REMOVE IT AND SECURE THE SUMP HOSE,IF NOT THEN THE NEXT THING TO CKECH IS THE PUMP ITSELF FOR BLOCKAGES,IF ANY FOUND THEN REMOVE THEM SECURE AND CHECK ALL PARTS ARE CORRECTLEY SECURED THEN TEST THE MACHINE,LET ME KNOW IF THIS SOLVES IT
Posted on Feb 07, 2009
blueextc3221
  • 15935 Answers
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Why does my 5 year old machine keep stopping mid-cycle?
Check the door sensor and clean it. Or one or more(i believe there are three) of your tub sensors may be bad.
Sep 11, 2015 | Washing Machines
Stop in mid cycle
washing machine hotpoint hvl211 stops in mid cycle and wouldn't take the conditioner This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Aug 03, 2012 | Washing Machines
Washer stops at the same point every time which is after it fills with water. After several hours it will then restart. Do you know what the problem might be? Thank You
Hi.
There are different faults that result in machine stopping mid cycle, hanging or not completing the cycle. Thermostat and element, pressure switch, balance switch, control module, door switch and motor must be tested. Common faults when machine stops mid cycle always at same time concern pressure switch and heating system. Some are described here (I know your machine properly stops and does not hang like the one in example): Washing machine takes a long time to end cycle.
To know what the problem is you need to run a test cycle. Instructions on how to run a test cycle are described in the tech sheet that is normally placed inside the machine. The tech sheet is usually tucked in an envelope hidden inside the control panel. It is necessary to remove the control panel held by screw to see if the document is still there. Power must be disconnected first.
Regards.
Ginko
Sep 07, 2011 | Kenmore Washing Machines
Stops mid cycle. Light flashes, cant get it to move on so have to start all over again
Hi there.
I have the same problem with my machine. Whatever program I select, the machine runs fine until it reaches 54 mins of the cycle remaining. To overcome the problem just to select a cycle that will not stop mid cycle, select a program which is less than 54 mins. I think the 40 degrees and quick wash select is the one to run with. The cycle is 45 mins, obviously less that 54 mins. The LED timer will display the cycle time. No problems with this cycle whatsoever. Not the total solution, but at least you're able to complete a cycle. After it's completed, I also run the spin program at 1200rpm. I hope this helps.
Regards, Ian.
Nov 22, 2010 | AEG Lavamat 72640 Front Load Washer
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
CREDA W200FW
Feb 04, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Kenmore he2 front load washer
remove bottom panel open pump port and ck for foreign objects lean washer toward rear wall this will help help keep water toward rear and reduce flooding floor might try opening door first and dipping out as much water as possible with bottom panel removed reach up to lock area there is a tear shaped plastic peace pull it down to release door
Jun 02, 2008 | Washing Machines
Creda W100FW Front Load Washer Logo
139 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
sonic boom...
sonic boom...
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
