Question about Kenmore Washing Machines
Reset kenmore 800 washer - Kenmore Washing Machines
My kenmore 800 series washer started draining but stopped 3/4 of the way and now won't do anything at all
Put the machine into the spin cycle and start as normal. Then with the lid open take a item like a pencil and depress into the lid switch where the lid pushes down on a switch. If machine starts spinning remove and replace lid switch. Let me know.
Feb 01, 2015 | Kenmore 2982 800 3.5 cu. ft. Top Load...
My kenmore 800 washer is off cycle for example when i start a load of clothes it starts agitating before filling, and doesn't always spin all the water out of the clothes
I have the exact same problem with my Kenmore 800 top loader, Model # 110.29822800. It is only 1.5 years old. Any suggestions?
Jan 19, 2011 | Kenmore 22422 Top Load Washer
Kenmore 800 washer no water comes in turn dial and it only goes into spin cycle
check water supply to the machine if you have water check the inlet valve screens located at the back of the washer where the supply hoses hook up at
Nov 17, 2010 | Kenmore 22422 Top Load Washer
My kenmore 800 washer stops mid fill. i push in
sounds like the timer has a bad spot in it probaby a factory thin spot in the dial
it's where the coil or filiment has a gap even a micro gap or wear spot can cause this
Jul 29, 2009 | Washing Machines
Are you happy with the Kenmore 800 4.0 cu.ft. top load washer?
For large capacity, a front loader would be your best bet. An HE2 by Kenmore should be sufficient. If a toploader is overloaded, it's more likely to do damage. Also a Whirlpool Duet would work. Whirlpool makes Kenmore, so shop for the best price, (they are the same inside)
Apr 15, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
Sal DeAngelo
fordexpert
Ed Mac
